Temperature rise in power transformers atheistrical
In summary, the post discussed the difference between winding temperature and winding temperature rise in power transformers. It clarified that a winding temperature of 73 deg C is safe, but if it is a temperature rise of 73 deg C, there may be problems. The thermal capability of a transformer is determined by the KVA load applied to the output and the hot-spot temperature limit, which is based on a loss-of-life criterion. The KVA rating of a transformer is simply the steady-state load applied to the output at the voltage rating that produces an average temperature rise of 65 degrees C. Advances in insulating materials have allowed for a 10 degree C increase in average temperature.
Carl Pugh
384
The post "Temperature rise in power transformers was locked, however there may be a simple safe answer.
The post said the winding temperature was 73 deg C.
73 deg C is safe for winding temperature.
If it was winding temperature RISE of 73 deg C, then there may be problems.
So which was it?
The thermal capability of a transformer is defined in a slightly different way from the rated KVA. Thermal capability is the KVA load applied to the output of a transformer that causes the hottest area in the windings, called the winding hot spot, to reach some limiting temperature. The hot-spot temperature determines the rate of loss of life of the transformer as a whole, which is a cumulative effect. Therefore, the hot-spot temperature limit is usually based on a loss-of-life criterion. The KVA rating of a transformer is simply the steady-state KVA load applied to the output of the transformer at the voltage rating of the output winding that produces an average winding temperature rise (above the ambient temperature) equal to 65 (degree C.). Advances in insulating materials allowed a 10 (degree C.) increase in average temperature.
Creative thinking is enjoyable, Then think about your surrounding things and other thought products. http://electrical-riddles.com
I would like to clarify that the term "temperature rise" in power transformers refers to the difference between the operating temperature and the ambient temperature. In this case, if the winding temperature was 73 degrees Celsius and the ambient temperature was, for example, 25 degrees Celsius, the temperature rise would be 48 degrees Celsius.
It is important to note that the safe operating temperature for power transformers can vary depending on their design and materials used. However, a temperature rise of 73 degrees Celsius would generally be considered high and may indicate potential problems with the transformer. It is important to monitor and regulate the temperature of power transformers to ensure their safe and efficient operation.
Related to Temperature rise in power transformers atheistrical
1. What is the main cause of temperature rise in power transformers?
The main cause of temperature rise in power transformers is the internal losses of the transformer, which include resistive losses in the windings and core losses due to hysteresis and eddy currents.
2. How does temperature rise affect the performance of a power transformer?
Temperature rise can significantly affect the performance of a power transformer. Higher temperatures can cause increased resistance in the windings, leading to higher losses and decreased efficiency. It can also cause degradation of the insulation materials, potentially leading to breakdown and failure of the transformer.
3. How is temperature rise measured in power transformers?
Temperature rise in power transformers is typically measured using resistance thermometers or thermocouples placed in strategic locations within the transformer. These sensors provide continuous monitoring of the temperature and can trigger alarms if the temperature rises above safe levels.
4. What are some methods for controlling temperature rise in power transformers?
One common method for controlling temperature rise in power transformers is through the use of cooling systems, such as fans, radiators, or oil pumps. The design and quality of the insulation materials used in the transformer also play a crucial role in controlling temperature rise. Regular maintenance and monitoring of the transformer's condition can also help prevent excessive temperature rise.
5. How does the load on a power transformer affect its temperature rise?
The load on a power transformer can significantly impact its temperature rise. Higher loads will result in higher internal losses and, therefore, a higher temperature rise. It is essential to ensure that the transformer is not overloaded to prevent excessive temperature rise and potential damage to the transformer.
  • Electrical Engineering
17K
  • DIY Projects
