The definition of velocity in the de Broglie relation
In summary, there is a distinction between velocity in classical physics and quantum physics. In classical physics, velocity is defined as the derivative of position with respect to time. However, in quantum physics, position and momentum are Fourier conjugates and velocity is a function of momentum rather than position. This is illustrated through the De Broglie relation and the use of operators in the Schrodinger picture. Additionally, there are two types of velocity in quantum mechanics: group velocity and phase velocity. Group velocity is related to the derivative of frequency with respect to wave number, while phase velocity is related to the ratio of frequency to wave number. Despite their differences, these two velocities are often used interchangeably in quantum mechanics, leading to confusion.
redtree
298
I apologize ahead of time for the simplicity of the question, but this has really been bothering me.Given the de Broglie relation, assuming natural units, where ##\hbar = 1##:
\begin{equation}
\begin{split}
\vec{k} &= M \vec{v}
\end{split}
\end{equation}My question regards velocity and what is meant by ##\vec{v}##. In classical physics, ##\vec{v}=
\frac{d \vec{x}}{dt}##. However, in quantum physics, position and momentum are Fourier conjugates, whose variance is related by the Uncertainty Principle. Mathematically, I don't see how it is possible that a variable and its derivative can be Fourier conjugates. Therefore, it seems ##\vec{v}## represents a different type of velocity. My understanding is that it represents group velocity (##\vec{v}_G##) related to phase velocity ##\vec{v}_P## as follows:
\begin{equation}
\begin{split}
\vec{v}_P &= \frac{\omega}{\vec{k}}
\end{split}
\end{equation}And:
\begin{equation}
\begin{split}
\vec{v}_G &= \frac{d \omega}{d \vec{k}}
\end{split}
\end{equation}Such that, in this case, ``velocity'' is a function of momentum (rather than position), and there is no problem with velocity and position as Fourier conjugates.Unfortunately, I don't think I have ever seen this distinction in velocity mentioned in discussions of quantum physics, and worse, I have often seen classical and group velocity used interchangeably in the mathematics of quantum physics.What am I missing?
Yes, you're right, that the velocity ##v = \frac{p}{m}## in quantum mechanics is the group velocity, rather than the phase velocity. Are you asking how to understand that?
I think that you can see it by thinking of velocity as an operator. In quantum mechanics, observables such as momentum, position, etc., are associated with operators, and the expectation value of the observable depends on the wave function as follows:
##\langle O \rangle = \int \psi^* \hat{O} \psi\ dx##
So if you have a wave function that varies with time, then the expectation value of position is given by:
##\langle x(t) \rangle = \int \psi^*(x,t) \hat{x} \psi(x,t)\ dx##
If you want to have a velocity operator ##\hat{v}##, then presumably you would want to have its expectation value relate to that of ##\hat{x}## as follows:
##\langle v(t) \rangle = \frac{d}{dt} \langle x(t) \rangle##
This implies that
##\langle v(t) \rangle = \int [(\frac{d \psi}{dt})^*\ \hat{x} \psi + \psi^*\ \hat{x}\ (\frac{d \psi}{dt})]\ dx## (using the convention that the operators are constants, while the time dependence is in the wave function---that's the Schrodinger picture).
That isn't of the form ##\int \psi^* \hat{O} \psi\ dx##, so it's not obvious what the velocity operator should be. However, we can manipulate the integral using Schrodinger's equation:
##i \hbar \frac{d\psi}{dt} = H \psi##
##-i \hbar \frac{d \psi^*}{dt} = H \psi^*##
where ##H## is the hamiltonian operator. Rewriting the integral in terms of ##H##, we have:
##\langle v(t) \rangle = \int [\frac{1}{-i \hbar} (H \psi^*)\ \hat{x} \psi + \frac{1}{i\hbar} \psi^*\ \hat{x}\ (H \psi)]\ dx##
At this point, we use a fact about Hermitian operators (and ##H## is one):
##\int (H \psi^*) \phi\ dx = \int \psi^* (H \phi)\ dx##
(assuming ##\psi## and ##\phi## are well-behaved). So letting ##\phi = \hat{x} \psi##, we have:
##\int (H \psi^*)\ \hat{x} \psi\ dx = \int \psi^*\ H (\hat{x}\ \psi)]\ dx##
Plugging this into our equation, we get:
##\langle v(t) \rangle = \int [\frac{1}{-i \hbar} \psi^*\ (H \hat{x} \psi) + \frac{1}{i\hbar} \psi^*\ \hat{x}\ (H \psi)]\ dx##
##= \int \psi^*\ \frac{1}{-i \hbar} (H \hat{x} - \hat{x}\ H) \psi\ dx##
So now we have our ##\hat{v}## operator:
##\langle v(t) \rangle = \int \psi^*\ \hat{v}\ \psi\ dx##
where ##\hat{v} = \frac{1}{-i \hbar} (H \hat{x} - \hat{x}\ H) ##
That combination, ##H \hat{x} - \hat{x} H## is called a commutator, and is written: ##[H,\hat{x}]##.
Obviously, the same reasoning goes for any operator other than ##\hat{x}##. For any time-independent operator ##\hat{O}##, we have:
##\hat{\frac{dO}{dt}} = \frac{1}{-i \hbar} [H,\hat{O}]##
For a free particle, we can use ##H = \frac{- \hbar^2}{2m} \frac{\partial^2}{\partial x^2}##, and the commutator gives: ##\hat{v} = \frac{1}{m} (-i \hbar \frac{\partial}{\partial x})##
Likes Mentz114, PeterDonis and vortextor
I guess my long-winded explanation doesn't actually explain the original ideas behind the De Broglie relations. That was before Schrodinger's equation and the idea of observables as operators.
I think that De Broglie was just trying to understand quantum phenomena in terms of waves, and assumed that a particle traveling at a constant velocity had an associated wave ##\psi(x,t) = e^{i (kx - \omega t)}##. Generalizing from Planck's and Einstein's quantization condition for monchromatic light, ##E = \hbar \omega##, De Broglie assumed that momentum had a similar rule: ##p = \hbar k##. Then I think it was just a matter of assuming that the classical velocity-momentum relation held: ##v = \frac{p}{m} = \frac{\hbar k}{m}##. The fact that this turns out to be the group velocity, ##\frac{d\omega}{dk}## doesn't seem immediately obvious to me. I don't know, historically, whether De Broglie assumed ##v = \frac{p}{m}## and then showed that this was the group velocity, or assumed that ##v## was the group velocity and then showed that this was ##\frac{p}{m}##.
My real question is why in Quantum Mechanics it so often seems that velocity as ##\vec{v}=\frac{d \vec{x}}{dt}## and as ##\vec{v}=\frac{d \omega}{d \vec{k}}## seem to be used interchangeably, when it seems so obvious that they cannot be. One blatant example is the time slicing derivation of the path integral.
##v = \frac{dx}{dt}##
is true by definition of velocity. To interpret the equation in quantum mechanics is not immediate, because ##v## and ##x## become operators, not values, but you can recover that definition in quantum mechanics by using the Heisenberg picture (where the state is considered time-independent and the operators are considered time-dependent). In the Heisenberg picture, you have the time evolution for an operator given by: ##\frac{dx}{dt} = \frac{1}{-i\hbar} [H,x] = \frac{1}{+i\hbar} [x,H]##
So this definition leads to ##v = \frac{dx}{dt} = \frac{1}{i\hbar} [x,H]##
If ##H = \frac{-\hbar^2}{2m} \frac{\partial^2}{\partial x^2} + V(x)##, then this leads to:
So: ##\v = \frac{-i \hbar}{m} \frac{\partial}{\partial x} = \frac{\hat{p}}{m}##
The fact that ##v = \frac{d\omega}{dk}## is not true by definition, but instead is derivable. If you write ##E = \hbar \omega## and ##p = \hbar k##, then it is equivalent to ##v = \frac{\partial E}{\partial p}##, which is true classically. Quantum-mechanically, you can make that into an operator equation by replacing ##E## by the operator ##H## and by using the following fact: If ##A(p,x)## is an operator that involves both momentum and position, then
##\frac{\partial A}{\partial p} = \frac{1}{i \hbar} [\hat{x}, A]##
##\frac{\partial A}{\partial x} = \frac{1}{-i \hbar} [\hat{x}, A]##
So: ##\frac{d\omega}{dk} \rightarrow \frac{dE}{dp} \rightarrow \frac{\partial H}{\partial p} \rightarrow \frac{1}{i \hbar} [x,H]##
So the two equations for ##v## agree as operator equations.
The path integral approach to quantum mechanics is very different. You don't start out with ##x## and ##v## and ##p## as operators, but instead are considering paths of the form ##x = f(t)##. Along a path, ##v## is just defined to be ##\frac{df}{dt}## and ##p## is just defined to be ##m v## (or more generally, ##p = \frac{\partial L}{\partial x}## where ##L## is the Lagrangian). I'm not sure where ##v = \frac{d\omega}{dk}## comes into play in path integrals.
##p = \hbar k##, ##E = \hbar\omega## and ##E = p^2/2m##,
So, ##\hbar\omega = \hbar^2 k^2/2m##
##\omega = \hbar k^2/2m##
##\frac {d\omega} {dk} = 2\hbar k/2m = p/m = v##
Likes redtree
I like this. I've got to think on this one. Thanks!
redtree said:
Time slicing derivation of the path integral: http://hitoshi.berkeley.edu/221a/pathintegral.pdf
Momentum used as ##m \vec{v}## and ## \hbar \vec{k}## interchangeably, where ##\vec{v} = \frac{d\vec{x}}{dt}##.
I only mention this because no one else has. You do, in fact, have the relation:
##\langle p \rangle = m\frac{d\langle x \rangle}{dt}##
In terms of the path-integral formulation, the link above says "by identifying ##\dot{x} = \frac{x_1 - x_0}{\Delta t}##". At each step in the limiting process, they take the classical path as the best guess for filling in the gaps.
The book I have, Sakurai, justifies this to some extent by showing that in this way he gets the same propagator for the free particle as he has already derived directly from the Schroedinger equation.
Sakurai also says: "... this is not meant to be a derivation. Rather we (or Feynman) have attempted a new formulation of QM based on paths ...".
He then shows that the path integral formulation so generated is equivalent to the Schroedinger equation.
So, I think Sakurai is clear that he has borrowed an idea from classical mechanics to motivate the path integral formulation. But, once he has his formulation, he then proves that is is equivalent to Schroedinger. Whatever dirty tricks he used to get the formulation in the first place don't matter then!
Likes Mentz114
Related to The definition of velocity in the de Broglie relation
What is the de Broglie relation?
The de Broglie relation is a fundamental principle in quantum mechanics that describes the relationship between a particle's wavelength and its momentum. It states that the wavelength of a particle is equal to Planck's constant divided by its momentum.
What is the significance of the de Broglie relation?
The de Broglie relation is significant because it provides a link between the wave-like and particle-like behaviors of matter. It also helps explain phenomena such as diffraction and interference in quantum systems.
How is velocity defined in the de Broglie relation?
In the de Broglie relation, velocity is defined as the speed at which a particle travels. It is related to the particle's momentum and wavelength through the equation v = p/m = h/λ, where v is velocity, p is momentum, m is mass, h is Planck's constant, and λ is wavelength.
What is the difference between velocity and speed in the de Broglie relation?
In the de Broglie relation, velocity and speed are used interchangeably to describe the rate at which a particle is moving. However, velocity is a vector quantity, meaning it has both magnitude and direction, while speed is a scalar quantity that only has magnitude.
How does the de Broglie relation relate to other principles in quantum mechanics?
The de Broglie relation is closely related to other principles in quantum mechanics, such as Heisenberg's uncertainty principle and the Schrödinger equation. It also plays a fundamental role in understanding the behavior of particles in wave-like systems, such as atoms and molecules.
  • Quantum Interpretations and Foundations
  • Classical Physics
  • Differential Geometry
  • Classical Physics
