The Michelson-Morley experiment
  • Thread starter arbol
  • Tags
    Experiment
In summary, the Michelson-Morley experiment observed the behavior of light in a moving coordinate system and found that the time intervals t1 and t2 were equal, regardless of the velocity of the moving system. This result was expected to be different, as it was assumed that the velocity of the moving system would have an effect on the time intervals. However, the experiment showed that the time intervals were independent of the velocity, suggesting that there is no absolute reference frame. This result was unexpected and challenged the previous understanding of classical mechanics.
arbol
50
Let S' be an x'y'-coordinate system. Let the x'-axis of S' coincide with the x-axis of an xy-coordinate system S, and let the y'-axis of S' be parallel to the y-axis of S. Let S' move along the x-axis of S with velocity v in the direction of increasing x, and let the origin of S' coincide with the origin of S at t = t' = 0s.
Let a ray of light depart from x'0 = 0m at the time t'0 = 0s towards x' = x'1 and reach x' = x'1 at the time t' = t'1, and let it be reflected back at x' = x'1 and reach x' = x'0 at the time t' = t'2. Let x'1 - x'0 = |x'0 - x'1| = L. Then with respect to the moving system S',
t'1 - t'0 = L/c, and
t'2 - t'1 = L/c = t'1 - t'0, and with respect to the stationary system S,
t1 - t0 = L + v*(t'1 - t'0)/(c + v) = t'1 - t'0, and
t2 - t1 = L - v*(t'2 - t'1)/(c - v) = t'2 - t'1.
Now let the ray of light depart from y'0 = 0m at the time t'0 = 0s towards y' = y'1 and reach y' = y'1 at the time t' = t'1, and let it be reflected back at y' = y'1 and reach y' = y'0 at the time t' = t'2. Let y'1 - y'0 = |y'0 - y'1| = L. Then with respect to the moving system S',
t1 - t0 = sqrt(sq(L) + sq(v*(t'1 - t'0)))/sqrt(sq(c) + sq(v)) = t'1 - t'0, and
t2 - t1 = sqrt(sq(L) + sq(v*(t'2 - t'1)))/sqrt(sq(c) + sq(v)) = t'2 - t'1.
The result of the Michelson-Morley experiment confirmed that
t2 - t0 = (L + v*(t'1 - t'0))/(c + v) + (L - v*(t'2 - t'1))/(c - v) = 2*(c*L - sq(v)*(t'2 - t'0/2))/(sq(c) - sq(v)) = sqrt(sq(L) + sq(v*(t'1 - t'0)))/sqrt(sq(c) + sq(v)) + sqrt(sq(L) + sq(v*(t'2 - t'1)))/sqrt(sq(c) + sq(v)) = 2*sqrt(sq(L) + sq(v*(t'2 - t'0/2)))/sqrt(sq(c) + sq(v)).
The result of the experiment is described as negative because it was expected to confirmed that
T1 = 2*L*c/(sq(c) - sq(v)) was not equal T2 = 2*sqrt(sq(L) + sq(v*(T2/2)))/c.
Moreover, the result of the Michelson-Morley experiment is actually independent of the value of v. Thus it did not reflect at all that the velocity v of the moving system S' with respect to the stationary system S is 0m/s, where S' is to be taken as the Earth and S as the assumed ether.
I made some mistakes in the quote above. I apologize for the confusion. The quote above ought to be written as follows:
t2 - t0 = (L + v*(t'1 - t'0))/(c + v) + (L - v*(t'2 - t'1))/(c - v) = 2*(c*L - sq(v)*(t'2 - t'0)/2))/(sq(c) - sq(v)) = sqrt(sq(L) + sq(v*(t'1 - t'0)))/sqrt(sq(c) + sq(v)) + sqrt(sq(L) + sq(v*(t'2 - t'1)))/sqrt(sq(c) + sq(v)) = 2*sqrt(sq(L) + sq(v*(t'2 - t'0/2)))/sqrt(sq(c) + sq(v)).
T1 = 2*L*c/(sq(c) - sq(v)) was not equal to T2 = 2*sqrt(sq(L) + sq(v*(t'2-t'0)/2)))/c.
Here I elaborate further the subject of this post.
let t' = L/c.
If t1 = 2*(c*L-v^2*t')/(c^2 - v^2) = 2*t'*(c^2 - v^2)/(c^2 - v^2) = 2*t', and
t2 = 2*sqrt(L^2+(v*t')^2)/sqrt(c^2 + v^2) = 2*t'*sqrt(c^2 + v^2)/sqrt(c^2 + v^2) = 2*t', then
t1/t2 =1.
The following programs return the following values respectively:
def t():
L=input("L: ")
c=299792458.0
t=L/c
print t
L: 299792458.0
t: 1.0
def t():
L=input("L: ")
c=299792458.0
t=L/c
v=input("v: ")
t=(L+v*t)/(c+v)
print t
L: 299792458.0
v: 29800.0
t: 1.0
def t():
L=input("L: ")
c=299792458.0
t=L/c
v=input("v: ")
t=(L-v*t)/(c-v)
print t
L: 299792458.0
v: 29800.0
t: 1.0
def t():
L=input("L: ")
c=299792458.0
t=L/c
v=input("v: ")
t=(L**2.0+(v*t)**2.0)**0.5/(c**2.0+v**2.0)**0.5
print t
L; 299792458.0
v: 29800.0
t: 1.0
def t():
L=input("L: ")
c=299792458.0
t=L/c
v=input("v: ")
t=2*(L**2.0+(v*t)**2.0)**0.5/(c**2.0+v**2.0)**0.5
print t
L: 299792458.0
v: 29800.0
t: 2.0
def t():
L=input("L: ")
c=299792458.0
t=L/c
v=input("v: ")
t=2*(c*L-v**2.0*t)/(c**2.0-v**2.0)
print t
L; 299792458.0
v: 29800.0
t: 2.0
let t' = L/c.
If t1 = 2*c*L/(c^2 - v^2) = 2*c^2*t'/(c^2 - v^2), and
t2 = 2*sqrt(L^2 + (v*t')^2)/c = 2*t'sqrt(c^2 + v^2)/c, then
t1/t2 = c^3/((c^2 - v^2)*sqrt(c^2 + v^2)).
def t():
L=input("L: ")
c=299792458.0
t=L/c
v=input("v: ")
t=2*c*L/(c**2.0-v**2.0)
print t
L: 299792458.0
v: 29800.0
t: 2.00000001976.
def t():
L=input("L: ")
c=299792458.0
t=L/c
v=input("v: ")
t=2*(L**2.0+(v*t)**2.0)**0.5/c
print t
L: 299792458.0
v: 29800.0
2.00000000988.
The experiment confirmed that there was no absolute reference frame.Do you agree or disagree?
Let S' be an x'-coordinate system. Let the x'-axis of S' coincide with the x-axis of an x-coordinate system S, and let S' move along the x-axis of S with velocity v in the direction of increasing x, and let the origin of S' coincide with the origin of S at t = t' = 0s.
Let a ray of light depart from x'0 = 0m at the time t'0 = 0s towards x' = x'1 and reach x' = x'1 at the time t' = t'1, and let it be reflected at x' = x'1 back to x'0 = 0m, and reach x' = 0m at the time t' = t'2. Let x'1 - x'0 = |x'0 - x'1| = L. Then with respect to the moving system S',
t1 - t0 = L + v*(t'1 - t'0)/(c + v), and
t2 - t1 = L - v*(t'2 - t'1)/(c - v), where by the Michelson-Morley experiment, it was established that
t1 - t0 = t2 - t1 = L/c.
Therefore, I think the following question is more appropriate:
By the Michelson-Morley experiment, were we able to established a common time between the moving system S' and the stationary system S?
Yes.
That t'1 - t'0 is the time, with respect to the moving system S', the ray of light takes to move along its own x'-axis from x'0 = 0m to x' = x'1 while t1 - t0 the time, with respect to the stationary system S, the ray of light takes to move along the x'-axis of the moving system S' from x'0 = 0m to x' = x'1 implies that in order to establish a common time between the moving system S' and the stationary system S, an absolute frame of reference is not necessary.
At best it showed that the experiment is not suited to prove the existence of an absolute reference frame or isolate it by measurement. This is not sufficient to prove that the absolute reference frame does not exist. Interestingly an absolute reference frame is indeed completely consistent with special relativity, but usually ruled out by occams razor.
See, for example, "How to teach relativity" from http://en.wikipedia.org/wiki/John_Stewart_Bell" .
Nice to read your statement, birulami. I thought I was alone in that opinion.
While that's true, it also says that such a reference frame could show no unique properties. So it really is completely pointless to consider the possibility. You may as well assume it doesn't exist, because it does nothing for you to assume it does. Just like the invisible/undetectable dragon living in my garage.
Russ, how could one experiment involving the behavior of light propagating within one reference frame show that a potential absolute reference frame would show no unique properties? Come on. No unique properties for light maybe. What about all the properties of matter?
When you start learning geometry, you draw points and lines and triangles on paper despite the fact that those crude pictures have nearly nothing to do with the concepts introduced by the axioms about points and lines.
Similarly, the absolute reference frame would make people feel at home, for a start, when learning about special relativity. Basic geometry and algebra can then easily show why and how no observer is actually able to nail down the absolute frame with any measurement possible. Even more, all the perceived paradoxes just disappear. The only postulate necessary is the constant speed of light, and the absolute frame gets redundant without much fuss.
Harald.
Related to The Michelson-Morley experiment
What is the Michelson-Morley experiment?
The Michelson-Morley experiment was a scientific experiment conducted in 1887 by Albert A. Michelson and Edward W. Morley to measure the speed of light. It aimed to detect the existence of the luminiferous ether, a medium that was believed to be responsible for the propagation of light.
What was the purpose of the Michelson-Morley experiment?
The purpose of the Michelson-Morley experiment was to measure the speed of light in different directions to determine if the speed of light was affected by the motion of the earth through the proposed luminiferous ether. This would either confirm or disprove the existence of the ether.
What were the results of the Michelson-Morley experiment?
The results of the Michelson-Morley experiment were unexpected and controversial. The experiment showed that the speed of light was constant in all directions, regardless of the motion of the earth. This contradicted the prevailing belief that the speed of light would be affected by the motion of the earth through the ether.
What impact did the Michelson-Morley experiment have on scientific theories?
The results of the Michelson-Morley experiment had a significant impact on scientific theories, particularly in the fields of physics and astronomy. It challenged the idea of the existence of the luminiferous ether and paved the way for the development of Albert Einstein's theory of relativity.
Why is the Michelson-Morley experiment considered a landmark experiment in physics?
The Michelson-Morley experiment is considered a landmark experiment in physics because it provided evidence that contradicted the prevailing theories of the time and paved the way for new and groundbreaking theories. It also demonstrated the importance of rigorous experimentation and the need to constantly challenge and refine scientific theories.
