The peak of the thermal radiation power spectrum (dR/dλ)
In summary, the peak of the thermal radiation power spectrum (dR/dλ) is at a wavelength of about λm=hc/5kT, while the peak of the same power spectrum plotted as dR/df is not at fm=c/λm= 5kT/h. This is due to the relationship between df and dλ, which is not linear or inverse.
Andres123
The peak of the thermal radiation power spectrum (dR/dλ) is at a wacelength of about λm=hc/5kT. Why is the peak of the same power spectrum plotted as dR/df not at fm=c/λm= 5kT/h?
dR/dλ= 2πhc2/(λ5(e(hc/λkT)-1))
f=c/λ
Hello Andres, welcome to PF :smile:
The idea at PF is that you post your efforts under attempt at solution and that helps us to guide you further as best we can. After all, you don't want someone else to do the exercise for you -- you want to learn by doing the exercise. See the guidelines for more info.
In the mean time: how do you find a peak ? What is the expression for dR/df ?
the equation for dR/df= 2πhf3/(c2(ehf/kt-1))
I am currently trying to differentiate both equation and setting them equal to zero to see if i find a relationship or reason for this. so far no success
Also think about the relationship between df and d##\lambda##
I strongly advise you not to fall for this and explore by yourself. Spoilers are exactly what the name says.You are much better of thinking this over than getting the answer on a plate
Here is a thread from before you joined -- same subject. You see it's causing some confusion with others too...:wink:
Related to The peak of the thermal radiation power spectrum (dR/dλ)
1. What is the peak of the thermal radiation power spectrum?
The peak of the thermal radiation power spectrum refers to the wavelength at which the emitted radiation has the highest intensity. It corresponds to the maximum amount of energy being radiated by a heated object.
2. How is the peak of the thermal radiation power spectrum determined?
The peak of the thermal radiation power spectrum is determined by the temperature of the object emitting the radiation. As the temperature increases, the peak shifts towards shorter wavelengths, indicating a higher intensity of radiation.
3. What is the significance of the peak of the thermal radiation power spectrum?
The peak of the thermal radiation power spectrum provides important information about the temperature and energy output of an object. It can also be used to identify the type of object emitting the radiation, as different materials have different peak wavelengths.
4. How does the peak of the thermal radiation power spectrum relate to blackbody radiation?
The peak of the thermal radiation power spectrum is a characteristic of blackbody radiation, which is the theoretical perfect emitter and absorber of radiation. The peak wavelength of a blackbody is determined solely by its temperature, according to Planck's law.
5. Can the peak of the thermal radiation power spectrum be manipulated?
Yes, the peak of the thermal radiation power spectrum can be manipulated by changing the temperature of the object or by altering the material it is made of. This can be useful in various applications, such as in designing more efficient solar panels or in thermal imaging technology.
10K
  • Quantum Physics
