Thermodynamics (final temperature, ice mixed with steam)
In summary, a 10-kg mass of ice at 0 degrees Celsius is added to a 2-kg mass of steam at 100 degrees Celsius, resulting in a temperature of 40 degrees Celsius when using Joules. The specific heats for ice and steam are 2060 and 2020, respectively. The latent heats for water melting and boiling are 3.33x10^5 and 2.26x10^6, respectively. The temperature of the mixture is found by accounting for the phase changes from ice to water and from steam to water, and then equilibrating the temperatures of the two water masses.
SigFig
If 10-kg of ice at 0 degrees Celsius is added to 2-kg of steam at 100 degrees Celsius, the temperature of the resulting mixture is? Use Joules. ANSWER: 40
Specific Heats:
Ice = 2060
Steam = 2020
Latent Heats:
Water melting = 3.33x10^5
Water boiling = 2.26x10^6
Q1=mL
Q1=10(3.34x10^5)
Q1=3.34x10^6
Q2=(2)(2.26x10^6)
Q2=4.52x10^6
Q2-Q1=1.18x10^6
Q=MCΔT
1.18x10^6 = (2+10)(4180)(T-0)
1.18x10^6 = 5.0x10^4T
T=23.6
Sadly 23.6 =/= 40
I've been trying to do this problem for over an hour now using every method I remember, stumped.
I'm confused by the question. Steam is a suspension of water droplets in air, basically a cloud. Presumably you mean water vapour not steam?
In this system there will a phase change from ice to water that costs an amount of latent heat. There will also be a phase change from vapour to liquid, which releases an amount of latent heat.
Perhaps it is easier to think about in too stages. 1) The vapour releases its latent heat and becomes water. This heat is sufficient to provide the latent heat required to melt the ice to water at 0C, and then heat up the mass of water that was ice. So finally you're left with two blobs of water, 2kg at 100C and 10kg at some temperature above 0C.
The second stage (that you missed out): the temperature of the two water masses equilibrate.
Specific Heats:
Ice = 2060
Steam = 2020
Latent Heats:
Don't forget your units.
Q1=mL
Q1=10(3.34x10^5)
Q1=3.34x10^6
Q2=(2)(2.26x10^6)
Q2=4.52x10^6
Q2-Q1=1.18x10^6
This is correct so far, :approve: except for the lack of units.
Q=MCΔT
Your approach *would* be correct, *if* the entire 12 kg of [liquid] water started from 0 deg C, and increased its temperature from there. But that's not the case for this problem.
Here, there is only 10 kg of [liquid] water, starting at 0o C, rising to temperature T, absorbing energy as it goes.
There is also 2 kg of [liquid] water, starting at 100o C, falling to temperature T (making a temperature change of 100 - T), releasing energy as it goes.
You'll need to re-set up your equation to account for both of these things. :wink:
That's really a matter of semantics. But commonly, water in gaseous form is called steam. (In which case -- you are correct insofar that -- H2O is transparent when in truly gaseous form.)
It would also be nice if some units were included in the calculations.
As a scientist, it is important to check for any errors in the calculations and make sure all units are consistent. In this case, there seems to be an error in the calculation for Q1, the heat absorbed by the ice. The correct calculation should be Q1 = 10(2060)(T-0) = 20,600T. This would result in a different final temperature, T = 36.2 degrees Celsius. Therefore, the answer of 40 is not correct and further review and correction of the calculations is needed. Additionally, it is important to note that this calculation assumes ideal conditions and does not account for any heat loss or gain from the surroundings.
Related to Thermodynamics (final temperature, ice mixed with steam)
1. What is the final temperature when ice is mixed with steam?
The final temperature when ice is mixed with steam will depend on the initial temperature of the ice and steam, as well as the amount of each substance. In general, the final temperature will be somewhere in between the initial temperatures of the ice and steam.
2. How does thermodynamics explain the final temperature of ice mixed with steam?
Thermodynamics is the study of energy and its transformations. When ice and steam are mixed, energy is transferred between the two substances until they reach thermal equilibrium, meaning they have the same temperature. The final temperature is determined by the amount of energy transferred and the specific heat capacities of the ice and steam.
3. Why does the final temperature of ice mixed with steam sometimes result in liquid water?
The final temperature of ice mixed with steam can result in liquid water if the initial temperature of the ice is below 0°C and the initial temperature of the steam is above 100°C. In this case, the energy transferred from the steam is enough to melt the ice and raise the temperature of the resulting water to its boiling point.
4. Is there a specific formula to calculate the final temperature of ice mixed with steam?
Yes, there is a formula to calculate the final temperature of ice mixed with steam. It is the energy conservation equation, which states that the total energy of the system (ice and steam) before mixing is equal to the total energy of the system after mixing. This formula takes into account the mass, specific heat capacities, and initial temperatures of the substances.
5. Can the final temperature of ice mixed with steam be lower than 0°C or higher than 100°C?
Yes, the final temperature of ice mixed with steam can be lower than 0°C or higher than 100°C. This can happen if the initial temperatures of the ice and steam are far enough apart and/or the amount of each substance is significantly different. In these cases, the resulting temperature may be outside the range of 0°C to 100°C.
