They physics of phase inversion in Grover's algorithm
In summary, the operator used in Grover's algorithm, also known as "phase inversion", is a solution checker that inverts the phase of the states we're looking for. It uses the feature of quantum mechanics that allows for inputting a superposition of all possible states and acting upon them simultaneously with operators. The physical implementation of this operator on a quantum computer depends on the specific problem being solved, but in general it involves a combination of gates and uncomputation.
dreamspy
41
How would this operator be implemented physically if we had a quantum computer?
In Grover's algorithm this magical operator is often called "phase inversion". Here is the operator from wiki:
https://wikimedia.org/api/rest_v1/media/math/render/svg/07fb23bffa787430b084971c6a108a8f6ff6c2b3
It’s an operator that does nothing to most of the states, except it inverts the phase of the states we’re looking for. (for all states x where f(x) = 1).
I assume we are using the feature of quantum mechanics that we can input a superposition of all possible states, and acting upon them all at the same time with our operators, then at the end, measuring the state of the system, giving us the state we're looking for with high probability (p > 1/2).
So I repeat my question:
Thanks
Frímann Kjerúlf
BSc Physics - University of Iceland
You need to give a lot more context. Please give a link to the full article. Or, even better, to a textbook or peer-reviewed paper that discusses this operator.
The black box in Grover's algorithm depends on the problem you're trying to solve. But generally it's just a "solution checker" that checks if a given input is correct, hits the "is it correct?" bit with a Z gate, then uncomputes all the junk it created while doing that.
A simple example is searching for a 3-SAT solution. Suppose we want to find boolean values for x, y, and z that satisfy:
$$(x \lor y \lor z) \land (\lnot x \lor \lnot y \lor \lnot z) \land (\lnot x \lor y \lor \lnot z)$$
To check a solution, you need to check if each clause is satisfied then combine those answers into one big 'all clauses satisfied' answer. Which, combined with the Z gate and uncomputation, looks something like exactly this:
Of course this is a very simple case. In more complicated cases, like checking if the input encodes a valid proof of a theorem, the circuit can get very complicated. You would want to use a tool to generate the circuit, based on some C code or whatever.
Related to They physics of phase inversion in Grover's algorithm
1. What is Grover's algorithm and how does it work?
Grover's algorithm is a quantum algorithm designed to search through an unstructured database for a specific item in a significantly faster time than classical algorithms. It works by iteratively amplifying the probability of finding the desired item through a process called amplitude amplification.
2. What is phase inversion in Grover's algorithm?
Phase inversion is a key step in Grover's algorithm where the amplitude of the desired item is amplified while suppressing the amplitudes of all other items in the database. This is achieved through the use of an oracle that flips the phase of the desired item in the quantum state.
3. How does phase inversion contribute to the efficiency of Grover's algorithm?
Phase inversion is crucial to the efficiency of Grover's algorithm as it allows for the amplification of the desired item's amplitude while suppressing the amplitudes of all other items. This reduces the number of iterations needed to find the desired item, making the algorithm significantly faster than classical algorithms.
4. How is phase inversion implemented in quantum computers?
Phase inversion is implemented in quantum computers using quantum gates, specifically the Controlled-NOT (CNOT) gate. This gate flips the phase of the desired item in the quantum state, while leaving the phases of all other items unchanged.
5. What are the potential applications of phase inversion in Grover's algorithm?
Phase inversion in Grover's algorithm has potential applications in a variety of fields, such as cryptography, data search and optimization problems. It can also be used as a subroutine in other quantum algorithms to improve their efficiency.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
