This Week's Finds in Mathematical Physics (Week 259)
Butelliptic curves are important for many other reasons, and they're agreat place to get started learning algebraic geometry.But now, let's skip over the real numbers and talk briefly aboutfinite fields. These are fields with a finite number of elements.The simplest one is F_2, the field with 2 elements. It's thesmallest nonzero field, and it's a big deal in computer science,cryptography, coding theory, and various other subjects.The rational numbers, real numbers and complex numbers are allinfinite fields. But there's no reason to stop at just 2 elements
John Baez
Also available as http://math.ucr.edu/home/baez/week259
December 9, 2007
John Baez
This week I'll talk about the "field with one element" - even though
it doesn't exist. It's a mathematical phantom.
But first: the Egg Nebula.
In "week257" and "week258" I talked about interstellar dust.
As I mentioned, lots of it comes from "asymptotic giant branch"
stars - stars like our Sun, but later in their life, when they're
big, red, pulsing, and puffing out elements like hydrogen, helium,
carbon, nitrogen, and oxygen.
The pulsations grow wilder and wilder until the star blows off its
entire outer atmosphere, forming a big cloud of gas and dust
misleadingly called a "planetary nebula". It leaves behind
its dense inner core as a hot white dwarf. Intense radiation from
this core eventually heats the gas and dust until they glow.
Back in "week223" I showed my favorite example of a planetary
nebula: the Cat's Eye. And I quoted the astronomer Bruce Balick
on what will happen here when our Sun becomes a planetary nebula
6.9 billion years from now:
Here on Earth, we'll feel the wind of the ejected gases
sweeping past, slowly at first (a mere 5 miles per second!),
and then picking up speed as the spasms continue - eventually
to reach 1000 miles per second! The remnant Sun will rise as
a dot of intense light, no larger than Venus, more brilliant
than 100 present Suns, and an intensely hot blue-white color
hotter than any welder's torch. Light from the fiendish blue
"pinprick" will braise the Earth and tear apart its surface
molecules and atoms. A new but very thin "atmosphere" of free
electrons will form as the Earth's surface turns to dust.
Eerie!
Here's a "protoplanetary nebula" - that is, a planetary nebula that's
just getting started:
1) Rainbow image of a dusty star, NASA,
http://hubblesite.org/newscenter/archive/releases/nebula/planetary/2003/09/
It's called the "Egg Nebula". You can see layers of dust coming out
puff after puff, shooting outwards at about 20 kilometers per second,
stretching out for about a third of a light year. The colors - red,
green and blue - aren't anything you'd actually see. They're just
an easy way to depict three different polarizations of light. I
don't know why the light is polarized that way.
You can see a dark disk of thicker dust running around the star. It
could be an "accretion disk" spiralling into the star. The "beams"
shining out left and right are still poorly understood. Maybe they're
jets of matter ejected from the north and south poles of the disk?
This idea seem more plausible when you look at this photo taken by
NICMOS, which is Hubble's "Near Infrared Camera and Multi-Object
Spectrometer":
2) Raghvendra Sahai, Egg Nebula in polarized light, Hubble Heritage
Project, http://heritage.stsci.edu/2003/09/supplemental.html
This near-infrared image also shows a bright spot called "Peak A" about
500 AU from the central star. An "AU", or astronomical unit, is the
distance from the Sun to the Earth.
Nobody knows what this bright spot is. Some argue that it's just a
clump of dust reflecting light from the main star. Others advocate a
more exciting theory: it's a white dwarf orbiting the main star, which
exploded in a "thermonuclear burst" after accreting a bunch of dust.
3) Joel H. Kastner and Noam Soker, The Egg Nebula (AFGL 2688): deepening
enigma, to appear in Asymmetrical Planetary Nebulae III, eds. M. Meixner,
J. Kastner, N. Soker, and B. Balick, ASP Conference Series. Available
as arXiv:astro-ph/0309677.
I hope to say more about planetary nebulae in future Weeks, mainly
because they're so beautiful.
But now: the field with one element!
A field is a mathematical structure where you can add, multiply,
subtract and divide in ways that satisfy these familiar rules:
x + y = y + x (x + y) + z = x + (y + z) x + 0 = x
xy = yx (xy)z = x(yz) 1x = x
x(y + z) = xy + xz
every element x has an element -x with x + (-x) = 0
every element x that's not 0 has an element 1/x with x (1/x) = 1
You'll note that the last clause is the odd man out. Addition,
subtraction and multiplication can all be described as everywhere
defined operations. Division cannot, since we can't divide by 0.
This is the funny thing about fields, which is what causes the
problem we'll run into.
Everyone who has studied math knows three examples of fields:
the rational numbers Q, the real numbers R and the complex numbers C.
There are a lot more, too - for example, function fields, number
fields, and finite fields.
Let me say a tiny bit about these three kinds of fields.
The simplest sort of "function field" consists of rational functions
of one variable - that is, ratios of polynomials, like this:
(2z^3 + z + 1)/(z^2 - 7)
Here the coefficients of your polynomials should lie in some field
F you already know about. The resulting field is called F(z).
If F is the complex numbers, we can think of F(z) = C(z) as consisting
of functions on the Riemann sphere. In "week201", I explained how
the symmetries of this field form a group important in special
relativity: the Lorentz group!
It's also very interesting to study the field of functions on a
surface fancier than the sphere, but still defined by algebraic
equations, like the surface of a doughnut or n-holed doughnut.
Number theorists and algebraic geometers spend a lot of time
thinking about these fields, which are called "function fields
of complex curves".
For example, different ways of describing the surface of a doughnut
by algebraic equations give different "elliptic curves". This is a
great example of terminology that's bound to mislead beginners!
They're called "curves" even though it's 2-dimensional, because it takes one
*complex* number to say where you are on a little patch of a surface,
just as it takes one *real* number to say where you are on an
ordinary curve like a circle. That's the origin of the term
"complex curve". And, they're called "elliptic" because they first
showed up when people were studying elliptic integrals, which are
generalizations of trig functions from circles to ellipses.
I explained more about elliptic curves in "week13" and "week125".
Lurking behind this, there's a lot of fascinating stuff about
function fields of elliptic curves.
The simplest sort of "number field" comes from taking the rational
numbers and throwing in the solutions of a polynomial equations.
For example, in "week20" I talked about the "golden field", which
consists of all numbers of the form
a + b sqrt(5)
where a and b are rational.
One of the most beautiful ideas in math is the analogy between
number fields and function fields - the idea that numbers are like
functions on some sort of "space". I began explaining this in
"week205", "week216" and "week218", but there's much more to say
about what's known... and also many things that remain mysterious.
In particular, it's pretty well understood how number fields
resemble function fields of complex curves, and how this relates
number theory to *2-dimensional* topology. But, there are also many
analogies between number theory and *3-dimensional* topology, which
I began listing in "week257". It seems these analogies are doomed to
remain mysterious until we get a handle on the field with one element.
But more on that later.
The simplest sort of "finite field" comes from choosing a prime number
p and taking the integers modulo p. The result is sometimes called
Z/p, especially when you're just concerned with addition. But when you
think of it as a field, it's better to call it F_p.
The reason is that there's a finite field of size q whenever q is a
*power* of a prime, and this field is unique - so it's called F_q. You
build F_q sort of like how you build the complex numbers starting from
the real numbers, or number fields starting from the rational numbers.
Namely, to construct F_{p^n}, you take F_p and throw in the roots of a
well-chosen polynomial of degree n: one that doesn't have any roots in
F_p, but "wants" to have n different roots.
Okay: that was a tiny bit about function fields, number fields and finite
fields. But now I need to point out some slight lies I told!
I said there was a finite field with q elements whenever q was a prime
power. You might think this should include q = 1, since 1 is the
*zeroth* power of *any* prime.
So, is there a field with one element?
If so, it must have 1 = 0. That doesn't violate the definition of
a field that I gave you... does it? The definition said any element
that's not 0 has a reciprocal. In this particular example, 0 also has
a reciprocal, since we can set 1/0 = 1 and not get into any contradictions.
But that's not a problem: in usual math practice, saying "we can divide
by anything that's not zero" doesn't deny the possibility that we can
divide by 0.
Unfortunately, allowing a field with 1 = 0 causes nothing but grief.
For example, we can define vector spaces using any field (people say
"over" any field), and there's a nice theorem saying two vector spaces
are isomorphic if and only if they have the same dimension. And normally,
there's one vector space of each dimension. But the last part isn't true
for a field with 1 = 0. In a vector space over such a field, every
vector v has
v = 1 v = 0 v = 0
So, every vector space is 0-dimensional!
To prevent such problems, people add one extra clause to the definition
of a field:
1 is not equal to 0
This clause looks even more tacked-on and silly than the clause
saying everything *nonzero* has a reciprocal... but it works fairly
well.
However, the field with one element still wants to exist! Not the
silly field with 1 = 0, but something else, something more mysterious...
something that Gavin Wraith calls a "mathematical phantom":
4) Gavin Wraith, Mathematical phantoms,
http://www.wra1th.plus.com/gcw/rants/math/MathPhant.html
What's a mathematical phantom? According to Wraith, it's an object
that doesn't exist within a given mathematical framework, but
nonetheless "obtrudes its effects so convincingly that one is forced
to concede a broader notion of existence".
Like a genie that talks its way out of a bottle, a sufficiently powerful
mathematical phantom can talk us into letting it exist by promising to
work wonders for us. Great examples include the number zero, irrational
numbers, negative numbers, imaginary numbers, and quaternions. At one
point all these were considered highly dubious entities. Now they're
widely accepted. They "exist". Someday the field with one element
will exist too!
Why?
I gave a lot of reasons in "week183", "week184", "week185", "week186"
and "week187", but let me rapidly summarize.
It's all about "q-deformation". In physics, people talk about q-deformation
when they're taking groups and turning them into "quantum groups". But it
has a closely related aspect that's in some ways more fundamental. When
we count things involving n-dimensional vector spaces over the finite field
F_q, we often get answers that are polynomials in q. If we then set q = 1,
the resulting formulas count analogous things involving n-element sets!
So, finite sets want to be finite-dimensional vector spaces over the
(nonexistent) field with one element... or something like that. We can
be more precise after looking at some examples.
Here's the simplest example. Say we count lines through the origin
in an n-dimensional vector space over F_q. We get the "q-integer"
q^n - 1
------- = 1 + q + q^2 + ... + q^{n-1}
q - 1
which I'll write as [n] for short.
Setting q = 1, we n. This is the number of points in an n-element set.
Sure, that sounds silly. But, I'm trying to make a point here! At
q = 1, stuff about n-dimensional vector spaces over F_q reduces to stuff
about n-element sets, and the q-integer [n] reduces to the ordinary
integer n.
This may not be the best way to understand the pattern, though.
Lines through the origin in an n-dimensional vector space are the
same as points in an (n-1)-dimensional projective space. So, the
real analogy may be between "points in a projective space" and
"points in a set".
Here's a more impressive example. Pick any uncombed Young diagram D
with n boxes. Here's one with 8 boxes:
X 1 box in the first row
X X 3 boxes in the first two rows
X X X 6 boxes in the first three rows
X X 8 boxes in the first four rows
Then, count the "D-flags on an n-dimensional vector space over F_q".
In our example, such a D-flag is:
a 1-dimensional subspace
of a 3-dimensional subspace
of a 6-dimensional subspace
of a 8-dimensional vector space over F_q
If you actually count these D-flags you'll get some formula, which is
a polynomial in q. And when you set q = 1, you'll get the number of
"D-flags on an n-element set". In our example, such a D-flag is:
a 1-element subset
of a 3-element subset
of a 6-element subset
of a 8-element set
For details, and a proof that this really works, try:
5) John Baez, Lecture 4 in the Geometric Representation Theory
Seminar, October 9, 2007. Available at
http://math.ucr.edu/home/baez/qg-fall2007/qg-fall2007.html#f07_4
These examples can be generalized. In "week187" I showed how to get
one example for each subset of the dots in any Dynkin diagram! This
idea goes back to Jacques Tits, who was the first to suggest that there
should be a field with one element. Dynkin diagrams give algebraic
groups over F_q... but he noticed that these groups reduce to "Coxeter
groups" as q -> 1. And, if you mark some dots on a Dynkin diagram you
get a "flag variety" on which your algebraic group acts... but as q -> 1,
this reduces to a finite set on which your Coxeter group acts.
If you don't understand the previous paragraph, don't worry - it's
over now. It's great stuff, but my main point is that there seems to
be an analogy like this:
q = 1 q = a power of a prime number
n-element set (n-1)-dimensional projective space over F_q
integer n q-integer [n]
permutation groups S_n projective special linear group PSL(n,F_q)
factorial n! q-factorial [n]!
This opens up lots of questions. For example, if projective spaces over
F_1 are just finite sets, what should *vector spaces* over F_1 be?
People have thought about this, and the answer seems to be "pointed
sets" - sets with a distinguished point, which you can think of as
the "origin". A pointed set with n+1 elements seems to act like
For more clues, and an attempt to do algebraic geometry using the
field with one element, try this:
6) Christophe Soule, On the field with one element, Talk given at the
Arbeitstagung, Bonn, June 1999, IHES preprint available at
http://www.ihes.fr/PREPRINTS/M99/M99-55.ps.gz
Soule tries to define "algebraic varieties" over F_1, namely curves
and their higher-dimensional generalization. And, he talks a lot about
zeta functions for such varieties. He goes into more detail here:
7) Christophe Soule, Les varietes sur le corps a un element, Moscow
Math. Jour. 4 (2004), 217-244, 312.
The theme of zeta functions - see "week216" - is deeply involved in
this business. For more, try these papers:
8) N. Kurokawa, Zeta functions over F_1, Proc. Japan Acad. Ser. A
Math. Sci. 81 (2006), 180-184.
9) Anton Deitmar, Remarks on zeta functions and K-theory over F1,
available as arXiv:math/0605429.
But instead of talking about zeta functions, I'd like to talk about
two approaches to giving a formal definition of the field with one
element. Both of them involve taking the concept of field and
modifying it so it doesn't necessary involve the operation of addition.
The first one, due to Deitmar, simply throws out addition! The second,
due to Anton Durov, allows for a wide choice of operations - and thus
a wide supply of "exotic fields".
For Deitmar's approach, try these:
10) Anton Deitmar, Schemes over F1, available as arXiv:math/0404185.
F1-schemes and toric varieties, available as arXiv:math/0608179.
The usual approach to fields treats fields as specially nice commutative
rings. A "commutative ring" is a gadget where you can add and multiply,
and these rules hold:
x(y + z) = xy + xz
Deitmar throws out addition and treats fields as specially nice
commutative monoids. A "commutative monoid" is a gadget where you can
multiply, and these rules hold:
For Deitmar, the field with one element, F_1, is just the commutative
monoid with one element, namely 1. A "vector space over F_1" is just
a set on which this monoid acts via multiplication... but that amounts
to just a plain old set. The "dimension" of such a "vector space"
is just its cardinality.
All this so far is quite trivial, but Deitmar makes a nice attempt at
redoing algebraic geometry to include this field with one element.
One reason to do this is to understand the mysterious 3-dimensional
aspect of number theory.
To explain this, I need to say a bit about "schemes". In ordinary
algebraic geometry, we turn commutative rings into spaces to think
about them geometrically. I explained this back in "week199" and
"week205", but let me review quickly, and go further:
We can think of elements of a commutative ring R as functions on
certain space called the "spectrum" of R, Spec(R). This space has
a topology, so we can also talk about functions that are defined,
not on all of Spec(R), but just *part* of Spec(R) - namely some open set.
Indeed, for each open set U in Spec(R), there's a commutative ring O(U)
consisting of those functions defined on U. These commutative
rings are related in nice ways:
A) If the open set V is smaller than U, we can restrict functions from
U to V, getting a ring homomorphism O(U) -> U(V)
B) If U is covered by a bunch of open sets U_i, and we have a function
f_i in each O(U_i), such that f_i and f_j agree when restricted to
the intersection of U_i and U_j, then there's a unique function f in O(U)
that restricts to each of these functions f_i.
Something satisfying condition A) is called a "presheaf" of commutative
rings; something also satisfying condition B) is called a "sheaf" of
commutative rings.
So, Spec(R) is not just a topological space, it's equipped with a
sheaf of commutative rings. People call this a "ringed space".
Whenever we have a ringed space, we can ask if it comes from a
commutative ring R in the way I just sketched. If so, we call
it an "affine scheme". Affine schemes are just a fancy geometrical way
of talking about commutative rings!
More interestingly, whenever we have a ringed space, we can ask if
it's *locally* isomorphic to one coming from a commutative ring.
In other words: does every point have a neighborhood that, as a
ringed space, looks like Spec(R) for some commutative ring R?
Or in other words: is our ringed space *locally* isomorphic to an
affine scheme? If so, we call it a "scheme".
A classic example of a scheme that's not an affine scheme is the
Riemann sphere. There aren't any rational functions defined on the
whole Riemann sphere, except for constants - the rest all blow up
somewhere. So, it's hopeless trying to think of the Riemann sphere
as an affine scheme.
But, for any open set U there's a commutative ring O(U) consisting of
rational functions that are defined on U. So, the Riemann sphere
becomes a ringed space. And, it's *locally* isomorphic to the complex
plane, which is the affine scheme corresponding to the commutative ring
of complex polynomials in one variable. So, the Riemann sphere is a
scheme!
For more on schemes, try this nice introduction, which actually
has lots of pictures:
11) David Eisenbud, The Geometry of Schemes, Springer, Berlin, 2000.
Now, we can talk about schemes "over a field F", meaning that each
commutative ring O(U) is also a vector space over F, in a well-behaved
way, giving us a "sheaf of commutative rings over F". For example,
the Riemann sphere is a scheme over C.
There's a secret 3-dimensional aspect to the affine scheme Spec(Z),
where Z is the commutative ring of integers. As explained in the
Addenda to "week257", we might understand this if we could see Spec(Z)
as a scheme over the field with one element! For more, see this:
12) 7) M. Kapranov and A. Smirnov, Cohomology determinants and
reciprocity laws: number field case, available at
http://wwwhomes.uni-bielefeld.de/triepe/F1.html
So, we really need a theory of schemes over the field with one element.
The problem is, F_1 isn't really a field. In Deitmar's approach, it's
just a commutative monoid.
So, let me sketch how Deitmar gets around this. In a nutshell, he takes
advantage of the fact that a lot of basic algebraic geometry only requires
multiplication, not addition!
He starts by defining a "commutative ring over F_1" to be simply a
commutative monoid. The simplest example is F_1 itself.
Now, watch how he gets away with never using addition:
He defines an "ideal" in a commutative monoid R to be a subset I for
which the product of something in I with anything in R again lies in I.
He says an ideal P is "prime" if whenever a product of two elements in
R is in P, at least one of them is in P.
He defines the "spectrum" Spec(R) of a commutative monoid R to be the
set of its prime ideals. He gives this the "Zariski topology". That's
the topology where the closed sets are the whole space, or any set of
prime ideals that contain a given ideal.
He then shows how to get a sheaf of commutative monoids on Spec(R).
He defines a "scheme" to be a space equipped with a sheaf of
commutative monoids that's *locally* isomorphic to one of this sort.
If you know algebraic geometry, these definitions should seem very
familiar. And if you don't, you can just replace the word "monoid"
by "ring" everywhere in the previous three paragraphs, and you'll get
the standard definitions in algebraic geometry!
Deitmar shows how to build a scheme over F_1 called the "projective
line". The projective line over C is just the Riemann sphere. The
projective line over F_1 has just two points (or more precisely, two
closed points). This is good, because the projective line over the
field with q elements has
[2] = 1 + q
points, and we're doing the q = 1 case.
Deitmar's construction seems like a lot of work to get ahold of the
2-element set, if that's all it secretly is. But, I need to think
about this more. After all, he doesn't just get a space; he gets a
sheaf of commutative monoids on this space! And what's that like?
I should work it out.
Deitmar also shows how to relate schemes over F_1 to the usual sort
of schemes.
From a commutative ring, we can always get a commutative monoid just
by forgetting the addition. This process has a kind of reverse, too.
Namely, from a commutative monoid, we can get a commutative ring
simply by taking formal integral linear combinations of elements.
Using this, Deitmar shows how we can turn ordinary schemes into
schemes over F_1... and conversely. He says an ordinary scheme is
"defined over F_1" if it arises in this way from a scheme over F1.
Okay, that's a taste of Deitmar's approach. For Durov's approach,
try this mammoth 568-page paper:
13) Anton Durov, New approach to Arakelov geometry, available as
arXiv:0704.2030.
or read our discussions of it at the n-Category Cafe, starting here:
14) David Corfield, The field with one element,
http://golem.ph.utexas.edu/category/2007/04/the_field_with_one_element.html
Durov defines a "generalized ring" to be what Lawvere much earlier
called an "algebraic theory". What is it? Nothing scary! It's just a
gadget with a bunch of abstract n-ary operations closed under composition,
permutation, duplication and deletion of arguments, and equipped with
an identity operation.
So, for example, if our gadget has a binary operation
(x,y) |-> f(x,y)
we can compose this with itself to get the ternary operation
(x,y,z) |-> f(f(x,y),z)
and the 4-ary operation
(w,x,y,z) |-> f(w,f(x,f(y,z)))
and so on. We can then permute arguments in our 4-ary operation
to get one like this:
(w,x,y,z) |-> f(z,f(x,f(w,y)))
or duplicate some arguments to get a binary operation like this
(x,y) |-> f(x,f(x,f(y,y)))
From this we can then form a 3-ary operation by deleting an argument,
for example like this:
(x,y,z) |-> f(x,f(x,f(y,y)))
If you know about "operads", this kind of gadget is just a specially
nice operad where we can duplicate and delete operations.
Now, a generalized ring is said to be "commutative" if all the
operations commute in a certain sense. (I'll let you guess what
it means for an n-ary operation to commute with an m-ary operation.)
We get an example of a commutative generalized ring from a commutative
ring R if we let the n-ary operations be "n-ary R-linear combinations",
like this:
(x_1, ..., x_n) |-> r_1 x_1 + ... + r_n x_n
We also get a very similar example from any "commutative rig", which is
a gizmo satisfying rules like those of a commutative ring, but without
negatives:
x(y + z) = xy + xz
And, we get an example from any commutative monoid, where we only
have 1-ary operations, coming from multiplication by elements of
our monoid:
(x_1) |-> r x_1
So, Durov's framework generalizes Deitmar's! But, it includes a lot
more examples: exotic hothouse flowers like the "tropical rig", the
"real integers", and more. He develops a theory of schemes for all
these generalized rings, and builds it "up to construction of algebraic
K-theory, intersection theory and Chern classes" - fancy things that
algebraic geometers like.
What I don't yet see is how either Deitmar's or Durov's approach
helps us understand the secret 3-dimensional nature of Spec(Z).
I may just need to read their papers more carefully and think about
them more.
Finally, here's yet another approach to the field with one element:
15) Bertrand Toen and M. Vaquie, Under Spec(Z), available as
arxiv:math/0509684.
In short, a mathematical phantom is gradually materializing before our
very eyes! In the process, a grand generalization of algebraic
geometry is emerging, which enriches it to include some previously
scorned entities: rigs, monoids and the like. And, this enrichment
holds the promise of shedding light on some otherwise impenetrable
mysteries: for example, the deep inner meaning of q-deformation, and
the 3-dimensional nature of Spec(Z).
Quote of the Week:
"The analogy between number fields and function fields finds a basic
limitation with the lack of a ground field. One says that Spec(Z)
(with a point at infinity added, as is familiar in Arakelov geometry)
is like a (complete) curve, but over which field?" - Christophe Soule
Previous issues of "This Week's Finds" and other expository articles on
mathematics and physics, as well as some of my research papers, can be
obtained at
For a table of contents of all the issues of This Week's Finds, try
http://math.ucr.edu/home/baez/twfcontents.html
A simple jumping-off point to the old issues is available at
http://math.ucr.edu/home/baez/twfshort.html
If you just want the latest issue, go to
http://math.ucr.edu/home/baez/this.week.html
baez@math.removethis.ucr.andthis.edu (John Baez) writes:
> (x,y) |-> f(x,y)
> and so on.
That's not an 'and so on'. 'And so on' would have been
(w,x,y,z) |-> f(f(f(w,x),y),z)
Or similarly you could have seeded the process with
(x,y,z) |-> f(x,f(y,z)))
Phil
Dear aunt, let's set so double the killer delete select all.
-- Microsoft voice recognition live demonstration
Related to This Week's Finds in Mathematical Physics (Week 259)
1. What is "This Week's Finds in Mathematical Physics"?
"This Week's Finds in Mathematical Physics" is a weekly online column written by John Baez, a mathematical physicist at the University of California, Riverside. The column discusses recent developments and interesting topics in the fields of mathematics and physics.
2. How long has "This Week's Finds in Mathematical Physics" been running?
The column was first published in 1993 and has been running for over 25 years.
3. Who is the target audience for "This Week's Finds in Mathematical Physics"?
The column is aimed at a wide range of readers, including mathematicians, physicists, and anyone interested in the intersection of these two fields. The language used is accessible to non-experts, but the topics covered may still be of interest to experts in the field.
4. How is the content of each week's column chosen?
John Baez selects the content of each column based on recent developments and interesting topics in the fields of mathematics and physics. He also takes into account suggestions and submissions from readers.
5. Is "This Week's Finds in Mathematical Physics" peer-reviewed?
No, the column is not peer-reviewed. However, John Baez is a respected researcher in the field of mathematical physics and the content of the column is carefully researched and fact-checked.
  • STEM Educators and Teaching
  • Topology and Analysis
  • Linear and Abstract Algebra
