Underground continent info needed
  • Thread starter sentrynox1
In summary, it sounds like you are looking for information on a 1994 discovery of a 320km long and 130km thick slab of earth under North America. This discovery was made by USGS and is mentioned in Science et vie No907 Avril 1993. Unfortunately, the article does not mention the depth of the slab, and as you are graduating and entering into a field that relies heavily on empirical data, I suggest you contact USGS to ask them for more information.
sentrynox1
Underground "continent" info needed...
Hello, I am new here and I am looking for about 15 years to get more information from a discovery published in April 1993 that says to have found a high density mass of about 320km long by 130km thick at 3200km deep under the North-American continent... I have made numerous research online, and it look like that nobody's have every heard of this... :cry:
I would be very greatful if somebody could help me get more information about what was this phenomenon.
Thanks in advance!
Evo said:
Is this it? I found this by accident some time ago when I was reading about the "ocean" beneth Beijing called the "Beijing anomaly" which you might also be interested in.
Giant Slab of Earth's Crust Found Near Core
http://www.livescience.com/forcesofnature/060517_inside_earth.html
Beijing anomaly
http://news-info.wustl.edu/news/page/normal/8222.html
This is not the same thing, as what I am talking is situated under our Continent, and is much deeper at about 2000miles deep! So if it was a molten Earth crust like described in the article it could place this piece of Earth as old as 500 million years! Which should have got plenty of time to melt away!
This is in North America.
Sorry, was referring to the Beijing anomaly.
The information I got were made in 1993, and the information at that time, was pretty much different that what is described here.
Here's my reference (in french, sorry) : Science et vie No907 Avril 1993)
Are you sure about the depth? That would put it in the outer core. I've not studied it in great detail but had the impression the core was fairly homogeneous and well mixed. Something like that in the mantle on the other hand wouldn't be at all surprising.
Yup I am sure of the depth, it is actually situated at the delimitation of the outercore and the mantle, which is indeed very unusual. It is why I do look for more information about this. I have contacted USGS and they promised me to come back with more info about this, and since THEY are the ones who discover it, I was expecting an answer... I got a reply that they could not find any info in their database, but the guy that replyied me, did remember it.
Look like I am alone stuck with this one...:confused:
Thanks in advance!
At that depth how would you determine it was "high density"? I can think of no geophysical method that would tell you this (especially as gravity cannot easily distinguish small shallow objects from large deep objects - unless perhaps you developed some kind of 'gravity-gradiometry'?), and as I am about to graduate I would appreciate it if you could fill me in so I don't feel like a complete klutz in my voce viva. Cheers.
EDIT: I'm graduationg for a masters degree in geophysics.
I have quite a few lecture notes on the CMB (which for the record is at ~2890 km), I might be able to find something beneath America for you. From memory I recall that there is some kind of anomaly there which is thought might act as the path for one of the magnetic poles as it reverses. I believe it may have been detected by seismic tomography as an anomalously fast region, and is often quoted as being "cold".
It is quite simple, in this case the high density mass as been detected by calculating the path of seismic waves after the explosion of a nuclear bomb in the goby desert. The explosion was strong enough (0.66Mt) to create such seismic waves and the way (propagation) they have traveled through the planet.
You can find much more detailled information's about this by surfing on the USGS geophysic website... They are the one's who are the pioneer in this field.
By the way, when I talk about high density, I just litterally translate it from French, so it might not sound like what you are used to hear... Sorry...
I think that you are on the right path! When you say cold, it can mean some sort of solid metal?? Actually, I also remember about the news on TV talking about this too, and if I remember right, they were talking about the fact that this mass was made of solid metal. But of course, I cannot rely on my memory for those facts, as if it was true (at that time I did not have enough knowledge in the field), it would mean that this mass could be made of solid metal at 3200km deep in the Earth, which is REALLY an anomaly! And it is what I need to confirm!
I am not convinced that seismology can tell you density, even if you use Birch's Law which sayas that velocity is proportional to density, and you invert your travel-time data perfectly so that you resolve the seismic velocity in that material, you still need to know what material you are looking at before you can infer the density.
The D" layer which is a couple of hundred km thick layer at the base of the mantle is very heterogeneous, it contains ultra low velocity zones (ULVZ) (which are smaller than the thing you're after), it also contains phase changes - in cold regions I believe you get perovskite (the same as the lower mantle), in hot regions you get a phase change to post-perovskite and if it's hot enough it may even change back to perovskite!
Some people think slabs end up there, one elegant mechanism to explain ULVZs is that perhaps they are subducted banded iron formations (BIF), incidentally some people also think ULVZs are where hotspots originate from. As for a slab of metal down there, never heard of it, this is because no one knows what's down there so they just have to guess, it just so happens that the people I know that study the Deep Earth either haven't made that guess, or perhaps they just haven't told me if they have. Any lateral heterogeneity will only be detected as a seismic anomaly, and until people know what it is for sure, they should only really describe it for what it is seismically to avoid confusion.
You are right about this, and it may explained why the two scientists of the USGS that have claimed this discovery have not gone public with further study about this phenomenon. If this really solid metal, it may explained the abnormal oscillations in the Earth magnetic field... But wether or not this anomaly is a consequence of the abnormal oscillations or, more troubling is causing them, will be even more difficult to figure out.
So the fact that you were the only one responding to this question, even among senior geophysicists that I know, mean that you are a genius of some sort! So I guess your master degree will be succesful! CONGRATULATION!:wink:
Good luck and thank you for your input!
So what do they do then? And why can't they "guess and check?"
In elementary school I was taught the core was guessed to be made of heavy metals and solid, from the pressure of the world squeezing on it. Is that right?
But the core spins faster than the rest of the Earth, doesn't it?
http://www.geology.uiuc.edu/~xsong/papers/zhangetal05_science.pdf
So that would mean that the slab's location translated to the Earth's surface could never be pinpointed to "under North America" because of the spinning core. I assume in the core's spinning it would drag material with it.
Does that make sense? Tell me what you think.
Well, I must admit I don't know enough about it, but there are ways in which geophysicsts can constrain density at these depths, although I believe that the seismology alone cannot be used. Difference in s and p wave arrivals can tell you something about the bulk and shear moduli, but this alone does not tell you density. Birch's Law (which is only really approximate) cannot tell you density if you don't know the composition. I believe that thermodynaimc and ab initio simulations are used to constrain density, exactly how it works is beyond me, and besides, there remains a high degree of uncertainty. It's quite easy to guess, but it is technically impossible to check, the deepest borehole is what, 14 km? We're talking depths of 2800 km or more here, so for obvious reasons you can't just check.
Related to Underground continent info needed
What is an underground continent?
An underground continent is a large landmass that is located beneath the Earth's surface. It is made up of rocks, minerals, and other materials that are located beneath the Earth's crust.
How is an underground continent formed?
An underground continent is formed through a process called subduction, where one tectonic plate slides underneath another. This creates a large landmass beneath the Earth's surface.
Where are underground continents located?
Underground continents are located all around the world, but they are mostly found beneath the Earth's oceans. Some examples of underground continents include the Zealandia continent beneath New Zealand and the Kerguelen Plateau beneath the Indian Ocean.
What is the significance of underground continents?
Underground continents are important for understanding the Earth's geological history and plate tectonics. They also play a role in the formation of natural resources such as oil and gas deposits.
Are there any ongoing studies or research on underground continents?
Yes, there are ongoing studies and research on underground continents, particularly in the field of geology and plate tectonics. Scientists are constantly learning more about the formation, composition, and role of underground continents in the Earth's history.
  • General Discussion
  • Electrical Engineering
  • STEM Academic Advising
  • STEM Career Guidance
