Understanding Jackson - calculation of coefficients
In summary, Jackson is discussing how to determine a function's form in terms of a particular basis of functions. The first expression defines the function f as a series of Legendre polynomials. The second expression is the inversion of the first, and allows you to find the coefficients that must appear in front of each of the P's. This is analogous to the Fourier expansion in terms of sines and cosines, which form a basis of functions.
Old Guy
103
After demonstrating that a set of functions are orthogonal and complete, Jackson presents equations like the ones shown below. I've used the equations for the Legendre series representation as an example, but he does almost the exact same thing with the Bessel functions, too. This isn't a homework problem, I'm just trying to understand what he means. The first expression defines a function f as a series of (in this case) Legendre polynomials with coerricients [tex]A_l [/tex]. He then defines the coefficients, but the definition of the coefficients is based on the integral of f which seems to be a circular definition. I'd like to know what this means, and how something like this could be used.
[tex]f\left( x \right) = \sum\limits_{l = 0}^\infty {A_l P_l \left( x \right)} {\rm{ where }}A_l = \frac{{2l + 1}}{2}\int\limits_{ - 1}^1 {f\left( x \right)P_l \left( x \right)dx} $
[/tex]
The second expression is not really a definition of the A's. You can define them by the first expression alone: They are defined to be the coefficients in the expansion of a function in terms of the basis of P functions. There are some cases in which you have a function already, and determine that you want to find out its form in terms of a particular basis of functions like the P's. The second expression is the inversion of the first where that allows you to determine the coefficients that must appear in front of each of the P's. This is all completely analogous to Fourier expansions in terms of sines and cosines, which form a basis of functions like the P's.
I think he's saying that Legendre Polynomials form a sort of "function" space that you can make any function out of the Legendre Polynomials with that sum you wrote.
The integral you wrote is just a method of how to find out "how much of f(x) is in Pl(x)," so you can construct f(x) purely as a sum of legendre polynomials.
Different people have their ways of understanding this, but here is one I like to think of:
Think of the legendre functions sort of like vectors in some way. When you do that integral, you can think of it as a dot product (the limits never change and are important). If you think of it this way, this means that you are making f(x) a linear combination of "legendre polynomial" vectors. The neat thing about orthogonal functions is that their "dot product" (or integral : [tex]\int_{-1}^{+1} P_l(x) P_m(x) dx = \frac{2}{2m+1} \delta_{l,m}[/tex]) is zero unless if it is with itself.
This way you can make an orthogonal function space where you can do some neat mathematical tricks. I have not done much electromagnetism, but I know a good example is in quantum mechanics where you need the eigenvalues of an operator. I don't know if you've seen this before but when an operator acts on its eigenvector, it gives an eigenvalue. So if you have an operator acting on an arbitrary vector, you need to break it into a sum of its eigenvectors (which by nature are orthogonal) to get the answer.
Typically, in quantum mechanics, the operators act on functions, so these "eigenvectors" are then functions, but usually sines and cosines (of the form cos(npix/L) for example, for a space from 0 to L), not legendre polynomials.
I don't want to go too much into this if you haven't seen this, but I do believe most likely what is happening is that it must be easier to tell something about the system if you break it up into its legendre polynomial "components."
Another example is with sines and cosines. By the Maxwell's equations, you know that electric signals are in the form of sines and cosines. If you receive a signal that looks like some arbitrary f(x), you can make an orthogonal space of sines and cosines and find out "how much f(x)" is in each sine or cosine component.
For example consider:
[tex]\sqrt{\frac{L}{2}}sin(\frac{n \pi x}{L})[/tex]
on the interval 0 to L. Each value of n is a different sine function. This integral with find the sum that follows:
[tex]C_n = \int_0^L F(x) \sqrt{\frac{L}{2}} sin(\frac{n \i x}{L}) dx[/tex]
for
[tex] \Sigma_{n = 0}^{\infty} C_n \sqrt{\frac{L}{2}} sin(\frac{n \i x}{L})[/tex]
I hope this helps
So, practically speaking, f(x) is the general series expression; you would normally use f(a) in the expression for the coefficient, where a would come from (for example) a given boundary condition, correct?
Ordirules, thanks for the clarification; the different perspective makes sense. I just wanted to say that I was responding to javierR's post before I saw yours. Anyway, I think I got it now - thanks to you both.
no problem, I am glad to help :-)
Related to Understanding Jackson - calculation of coefficients
1. What is the purpose of calculating coefficients in the Jackson method?
The coefficients in the Jackson method are used to determine the relative importance of each queue in a multi-queue system. They help to allocate resources and optimize the overall performance of the system.
2. How are the coefficients calculated in the Jackson method?
The coefficients are calculated by dividing the arrival rate of each queue by the sum of all arrival rates in the system. This provides a ratio that represents the relative weight of each queue in the system.
3. Can the coefficients change over time in a multi-queue system?
Yes, the coefficients can change over time as the arrival rates of each queue may vary. It is important to regularly recalculate the coefficients to ensure efficient resource allocation.
4. What happens if one queue has a significantly higher coefficient than the others?
If one queue has a much higher coefficient, it means that it is receiving a larger share of the resources in the system. This could lead to longer wait times and decreased performance for the other queues. Adjustments should be made to balance out the coefficients and optimize the system.
5. Are there any limitations to using the Jackson method for calculating coefficients?
Yes, the Jackson method assumes that the arrival rates for each queue are stable and independent of each other. It also assumes that the system operates under a first-come, first-served (FCFS) scheduling policy. If these assumptions do not hold, the accuracy of the calculated coefficients may be affected.
  • Electromagnetism
