Uniform Motion Review - Boat travelling
In summary: The distance traveled is the magnitude of the displacement, not the direction. Thanks for catching that!
anneku
A boat travelling close to the coast is heading in
an unknown direction. The captain contacts an
observer on the shore to help her determine the
direction the boat is heading. The observer on the
shore reports that the horizontal displacement of the
boat is 750 m [E] and that the boat travelled north
an unknown distance. The captain has measured a
total distance of 1100 m that the boat moved. How far
north did the boat travel and in what direction is the
boat travelling?
total displacement = change in position on x axis + change in position on y axis
displacement (x) = 750 m [E]
distance = 1100 m
I drew a diagram. Now what??
anneku said:
Homework Statement: A boat traveling close to the coast is heading in
boat is 750 m [E] and that the boat traveled north
boat travelling?
Homework Equations: total displacement = change in position on x-axis + change in position on y axis
distance = 1100 m
Show your work. You have the wrong answer.
I got the correct answer as the displacement on the y-axis is 805 m [N] as this is a right-angled triangle (using Pythagorean theorem). The boat is also traveling [ E 47 N ] as cosΘ =750/1100 and therefore the angle would be 47°.
Why would the length of the hypotenuse be 1100 m though? 1100m is distance. It would be wrong to assume that the distance and displacement are the same.
Anneku did not quote an answer, merely restated the given data.
It does not say they are the same, and they cannot be because displacement is a vector.
There is an assumption that the direction is constant, so the distance traveled is the magnitude of the displacement.
Ah. You're right. I missed that (obviously).
Related to Uniform Motion Review - Boat travelling
1. What is uniform motion?
Uniform motion is the movement of an object at a constant speed in a straight line. This means that the object is not accelerating or changing direction.
2. How is uniform motion different from non-uniform motion?
In uniform motion, the object maintains a constant speed and direction, while in non-uniform motion, the object's speed or direction changes over time. In other words, uniform motion has a constant velocity, while non-uniform motion has a changing velocity.
3. How does a boat traveling on water demonstrate uniform motion?
A boat traveling on water at a constant speed and direction demonstrates uniform motion. As long as the boat is not accelerating or changing direction, it is considered to be in uniform motion.
4. What is the formula for calculating uniform motion?
The formula for uniform motion is velocity = distance/time, where velocity is the speed at which an object is moving, distance is the total distance traveled, and time is the amount of time it took to travel that distance.
5. What is the significance of uniform motion in physics?
Uniform motion is important in physics because it is the basis for understanding more complex motion, such as acceleration and forces. It also helps us make predictions about the future position of an object based on its current velocity and direction.
