Vanishing Hamiltonian for quantum path integral
In summary, the path integral in quantum mechanics involves a factor ##e^{iS_{N}/\hbar}##, where ##S_{N}## is the sum of the change in position and the Hamiltonian of the system. In the limit ##N \rightarrow \infty##, ##S_{N}## becomes the usual action ##S## for a given path. When the Hamiltonian is zero, the propagator becomes the integral of momentum through distance, which is linked to Maupertuis' principle of least action. This classical formulation provides a physical justification for the final answer.
spaghetti3451
1,344
33
The path integral in quantum mechanics involves a factor ##e^{iS_{N}/\hbar}##, where
##S_{N}\equiv \sum\limits_{n=1}^{N+1}[p_{n}(x_{n}-x_{n-1})-\epsilon H(p_{n},x_{n},t_{n})].##
In the limit ##N \rightarrow \infty##, ##S_{N}## becomes the usual action ##S## for a given path.When the Hamiltonian vanishes, the potential energy of the system offsets the kinetic energy of the system and in the limit ##N \rightarrow \infty## the propagator ##\langle x_{b}, t_{b}|x_{a}, t_{a}\rangle## becomes
##S_{N} \equiv \sum\limits_{n=1}^{N+1}\epsilon\bigg[p_{n}\bigg(\frac{x_{n}-x_{n-1}}{\epsilon}\bigg)\bigg]=\int\ dt\ p\dot{x}##
I would like to think of a physical argument to justify this answer. Thoughts?
Well, for an intuitive physical argument you could consider the classical formulation. Leaving aside various caveats, L = 2T - H (T = kinetic energy; 2T is what Leibniz called "vis viva"). When H = 0 then L = 2T which (integrated through time) is precisely your final answer, representing "action". I.e., (ignoring factor of 2) the integral of energy through time, or integral of momentum through distance.
So the answer makes perfect sense classically. I don't know if that's what you're looking for? Perhaps you already knew that and want a physical argument for the principle of least action? There are a few of those.
What you have there seems to be the abbreviated action ##S_{0} \equiv \int \mathbf{p} \cdot d\mathbf{q}##, which is linked to Maupertuis' principle of least action - i.e. "shortest" path.
Related to Vanishing Hamiltonian for quantum path integral
1. What is the Vanishing Hamiltonian for quantum path integral?
The Vanishing Hamiltonian for quantum path integral is a mathematical tool used in quantum mechanics to simplify the calculation of quantum path integrals. It involves setting the Hamiltonian, which describes the total energy of a system, to zero in order to eliminate the time dependence and make the calculation more manageable.
2. How does the Vanishing Hamiltonian affect the path integral?
The Vanishing Hamiltonian simplifies the path integral by removing the time dependence, making the calculation of the path integral more straightforward. It essentially reduces the problem to a static system, making it easier to solve.
3. When is the Vanishing Hamiltonian method useful?
The Vanishing Hamiltonian method is particularly useful when dealing with complex quantum systems that have a time-dependent Hamiltonian. It allows for a more efficient and accurate calculation of the path integral.
4. What are the limitations of the Vanishing Hamiltonian method?
The Vanishing Hamiltonian method is limited to systems where the Hamiltonian is time-dependent. It also may not be suitable for certain types of quantum systems, such as those with strong interactions or highly entangled states.
5. How does the Vanishing Hamiltonian method relate to other methods in quantum mechanics?
The Vanishing Hamiltonian method is closely related to other methods in quantum mechanics, such as the path integral formulation and the operator formalism. It is a useful tool for simplifying calculations in these other methods and can be combined with them to solve more complex problems.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
