- #36
russ_watters
Mentor
- 23,193
- 10,413
When boiling. Not when not boiling.pisluca99 said:But bubbles are made of vapor, and they are generated from the bottom of the container...
Vapor pressure is the pressure exerted by the vapor of a substance in a closed system at equilibrium with its liquid or solid form.
Vapor pressure and boiling point are directly related. As vapor pressure increases, the boiling point of a substance decreases. This means that a substance with a higher vapor pressure will boil at a lower temperature.
Water still boils at 100°C in an open pot because the atmospheric pressure is exerting a force on the surface of the water, preventing it from turning into vapor. This is why water boils at a lower temperature at higher altitudes, where the atmospheric pressure is lower.
The temperature of the water directly affects its vapor pressure. As the temperature increases, the vapor pressure also increases. This is because at higher temperatures, more molecules have enough energy to escape the liquid and become vapor.
Yes, water can boil at a temperature other than 100°C. As mentioned before, the boiling point of water is dependent on the atmospheric pressure. If the pressure is increased, the boiling point also increases, and if the pressure is decreased, the boiling point decreases. This is why water can boil at different temperatures in different environments.
