What Is the Epoch Time for the WGS84 Coordinate System?
In summary, the conversation discusses the epoch time of the WGS84 coordinate system and the relationship between GPS time and UTC. It is mentioned that there is no precise epoch for the coordinate system and that there are slight changes to the values with time. The conversation also touches on the significance of a defined epoch for astronomical coordinates and the role of GPS receivers in providing UTC with the inclusion of leap seconds.
mjdiaz89
Hello,
I've been searching all over for the epoch time of the WGS84 coord system. A GPS I'm using says its 06/01/1980, but I don't know if starts from 12:00:00 ET. Is there an epoch by definition or is it arbitrary?
There isn't a precise epoch for the coordinate system - the 1984 is just when the data was agreed. There are slight real changes to the values with time, but the real changes come with more accurate measurements.
There is a start epoch to the GPS clock data but that's just a software detail, GPS time doesn't include leap seconds - so GPS and UTC were synced in 1980 but GPS now lags by a number of seconds.
Interesting that there isn't a defined epoch, only a synced time. Yes, I believe the lag is 13 seconds.
Thank you very much :)
Yes, astronomical coords need a definite epoch because the star positions are moving.
Although the Earth's shape really changed between say Airy 1837 and WGS84 it's insignificant compared to the change in the measurement accuracy.
Just to confuse things further - most GPS receivers do give UTC, the number of leap seconds is sent to the satellites as part of their update data.
Hello,
Thank you for your question. The WGS84 coordinate system does indeed have an epoch time, which is used as the reference time for all measurements. The epoch time for WGS84 is January 6, 1980 at 00:00:00 UTC (Coordinated Universal Time). This is equivalent to January 5, 1980 at 19:00:00 ET (Eastern Time).
This time was chosen as the starting point for WGS84 because it was the date when the first GPS satellite was launched and began transmitting signals. This allowed for a consistent and accurate reference point for all GPS measurements.
It is important to note that the epoch time for WGS84 is not arbitrary and is defined by the International Earth Rotation and Reference Systems Service (IERS). This ensures that all measurements using the WGS84 coordinate system are standardized and accurate.
I hope this helps clarify the epoch time for WGS84. Let me know if you have any further questions. Best of luck with your research!
Sincerely,
Related to What Is the Epoch Time for the WGS84 Coordinate System?
What is the WGS84 Coordinate System Epoch?
The WGS84 Coordinate System Epoch is a geodetic datum used to define the Earth's shape, size, and orientation in space. It is commonly used in GPS and other mapping systems to accurately represent locations on the Earth's surface.
Why is the WGS84 Coordinate System Epoch important?
The WGS84 Coordinate System Epoch is important because it provides a standardized reference system for geospatial data. This allows different mapping systems and devices to communicate and accurately represent locations on the Earth's surface.
How often does the WGS84 Coordinate System Epoch change?
The WGS84 Coordinate System Epoch is periodically updated to account for changes in the Earth's shape and orientation. The most recent update, called WGS84(G1762), was implemented in 2013. Prior to that, updates were made in 1994, 1996, and 2004.
What is the difference between the WGS84 Coordinate System Epoch and other coordinate systems?
The WGS84 Coordinate System Epoch is based on a geocentric model, meaning it considers the Earth as a perfect sphere. Other coordinate systems, such as NAD83 and NAD27, are based on a local ellipsoid model that approximates the Earth's shape in a specific region.
How is the WGS84 Coordinate System Epoch used in real-world applications?
The WGS84 Coordinate System Epoch is used in a variety of applications, including navigation, surveying, and geocaching. It is also used in the military, aviation, and maritime industries for precise location tracking and communication. Additionally, many online mapping services, such as Google Maps, use the WGS84 Coordinate System Epoch as their reference system.
  • Cosmology
  • Classical Physics
  • Topology and Analysis
