What are the lowest two frequencies of the sound?
In summary, the problem is to find the lowest two frequencies of sound emitted by a loudspeaker at the origin. The speed of sound on the given day is 340 m/s. A crest of the wave passes two listeners at (40m,0m) and (0m,30m). To find the frequency, you need to first find the wavelength by placing the coordinates on a graph and determining if they represent a quarter or half of a wavelength.
Yoda13
I am having a problem finding where to start. The problem is this: A loudspeaker at the orgin emits sound waves on a day where the speed of sound is 340 m/s. A crest of the wave simultaneously passes listeners at the (x,y) coordinates (40m,0m) and (0m,30m). What are the lowest two frequencies of the sound? If the question asks for do different frequecies then there must be two different waves, right? I am having trouble thinking how to relate anything to finding the frequecy. Thanks for your help.
Well, you know the speed, you have enough info to find the wavelength, and all you need to find is the frequency. To find the wavelength, place the 2 coordinates on a graph. (You know that waves travel in sinusoidal fashion, right?) Now, there are 2 possibilities for attaching the 2 points together. They could represent a quarter of a wavelenth, or half a wavelength. Now that I gave you a hint, you should be able to solve the problem.
To find the lowest two frequencies of the sound, we need to first understand the concept of frequency. Frequency is defined as the number of cycles or vibrations per second, and is measured in Hertz (Hz). In the context of sound, frequency is related to the pitch of the sound, with higher frequencies producing higher pitched sounds.
In this problem, we are given the speed of sound (340 m/s) and the coordinates of the listeners (40m,0m) and (0m,30m). This means that the distance between the loudspeaker and the first listener is 40m, and the distance between the loudspeaker and the second listener is 30m.
To find the frequency of the sound, we can use the formula: frequency = speed of sound / wavelength. The wavelength is the distance between two consecutive crests or troughs of a wave. In this case, we have two listeners at different distances from the loudspeaker, so we will have two different wavelengths.
For the first listener at (40m,0m), the distance between the loudspeaker and the listener is 40m. This means that the wavelength is also 40m. Plugging in the given values into the formula, we get:
Frequency = 340 m/s / 40m = 8.5 Hz
Similarly, for the second listener at (0m,30m), the distance between the loudspeaker and the listener is 30m. This means that the wavelength is 30m. Plugging in the given values into the formula, we get:
Frequency = 340 m/s / 30m = 11.3 Hz
Therefore, the lowest two frequencies of the sound are 8.5 Hz and 11.3 Hz. This means that the sound waves emitted by the loudspeaker have two different frequencies, which are heard by the two listeners at different distances from the loudspeaker.
In summary, to find the lowest two frequencies of the sound, we need to use the formula frequency = speed of sound / wavelength and take into account the different distances between the loudspeaker and the listeners. I hope this helps in understanding how to approach this problem.
Related to What are the lowest two frequencies of the sound?
1. What are the lowest two frequencies of the sound?
The lowest two frequencies of sound are known as the fundamental frequency and the first harmonic. The fundamental frequency is the lowest frequency at which a sound wave can vibrate, and the first harmonic is twice the frequency of the fundamental frequency.
2. How do you measure the lowest two frequencies of sound?
The lowest two frequencies of sound can be measured using a device called a frequency meter, which measures the number of vibrations or cycles per second of a sound wave. This measurement is known as the frequency and is typically measured in Hertz (Hz).
3. What factors affect the lowest two frequencies of sound?
The lowest two frequencies of sound can be affected by several factors, including the size and shape of the vibrating object, the medium through which the sound travels, and the temperature of the medium. Additionally, the lowest frequency of sound can also be affected by the tension and density of the medium.
4. What are some examples of low frequency sounds?
Some examples of low frequency sounds include the rumbling of thunder, the deep sound of a large bell, and the low notes of a bass guitar. These sounds have frequencies below 200 Hz, which is typically considered the lower limit of human hearing.
5. Why are the lowest two frequencies of sound important?
The lowest two frequencies of sound are important because they help us to understand and recognize different types of sounds. They also play a crucial role in music, as they determine the pitch of a sound. Additionally, low frequency sounds can have physical effects, such as causing objects to vibrate or creating a feeling of pressure in the ears.
10K
