What conditions must be met before star becomes a black hole?
In summary, the main factor that sets stars apart and determines if they will become black holes is their mass, not their size. As stars evolve and exhaust their fuel, they will eventually reach a point where fusion reactions can no longer sustain and support the star, leading to a collapse. In the case of massive stars, this collapse can cause a supernova, and if the remaining core has a mass greater than 30 solar masses, it can collapse further to form a black hole. The critical size for a black hole to form is its Swarzschild radius, which is determined by its mass. Therefore, it is the mass of a star that ultimately determines if it will become a black hole, not its size.
Stu21
If only some stars become black holes what sets them apart from other stars, is it just size?
Astronomy news on Phys.org
To be precise, rather than size, it is mass. Massive stars evolve to a supergiant star after it's main sequence. That's because of it's large mass, which ignites furthermore reactions and after the formation of iron, a supernova occurs. The leftover core may become a neutron star or a black hole, depending on it's mass.
Right, mass, should have been more specific, so giant stars at the end of their life go supernova, this is due to the fusion of Iron in the core sending out a massive shock wave. So what then is so special about Iron, I believe it was the cosmos series by Carl Sagan where I heard that all elements tend to want form Iron, that is they will gain or loose protons or undergo fission or fusion, to attain this state. So if black holes come from supernovas, then could the Iron be crushed to a single dense enough point to be considered a black hole, does Iron have the mass for this?
When a core of iron forms at the heart of the supergiant, and other elements required for fusion exhaust, no more reactions take place. (because iron is a stable element with respect to fusion or fission. The energy needed to trigger an iron fusion reaction is greater than that it gives out while fusing, thus consuming all heat and energy in the star). Now the gravity overpowers the radiation outburst (since there is no radiation outburst), and the star collapses greatly, crushing the core where the protons are fused into electrons, forming neutrons. Thus generated shock wave rips the outer layers apart, blowing the star off in a supernova. The remaining core is not of iron but neutrons which contract to form a neutron star. But, if the initial mass was even more greater (about 30 suns), the neutron star collapses further to form a black hole, a singularity in space.
Mass.
Size is not the determining factor. The sun will become a red giant yet it lacks the mass necessary to become a black hole. So it will wind up as a white dwarf instead.
Some additional details about your question:
The first collapse into a neutron star occurs because the electron degeneracy pressure can no longer withstand the gravitational force
If it collapses again, it is now because neutron degeneracy pressure can no longer
What you are left with in a black hole, after a neutron star collapses, is a quark-gluon plasma.
Typically, a Red Super Giant will burn through its hydrogen, helium, carbon, oxygen, neon, magnesium, and sillicon layers, in that order, and will then collapse because no fusion reactions are keeping it from doing so.
Related to What conditions must be met before star becomes a black hole?
1. What is a black hole?
A black hole is a region in space where the gravitational pull is so strong that nothing, including light, can escape from it. This is due to the extreme density and compactness of matter within the black hole.
2. How does a star become a black hole?
A star becomes a black hole when it runs out of nuclear fuel to burn and can no longer support its own weight. This causes the star to collapse under its own gravity, creating a black hole.
3. What are the conditions necessary for a star to become a black hole?
The star must be massive enough, at least three times the mass of our sun, to create enough gravitational force to overcome the nuclear forces that keep it from collapsing. It must also have used up all of its nuclear fuel, causing it to collapse and form a black hole.
4. Can any star become a black hole?
No, only stars that are large enough and have used up all of their nuclear fuel have the potential to become black holes. Smaller stars, like our sun, may turn into white dwarfs or neutron stars instead.
5. How do we detect black holes?
Black holes cannot be detected directly because they do not emit any light. However, their presence can be inferred by observing the effects of their strong gravitational pull on nearby objects, such as stars and gas clouds. Scientists also use specialized instruments, such as X-ray telescopes and gravitational wave detectors, to indirectly detect and study black holes.
  • Astronomy and Astrophysics
