What diode do I need for automobile turn signals with LED's
In summary, the speaker has LED lights installed all over their vehicle and has a HYPERFLASH harness to prevent hyperflash. They recently changed their clear corners to ones with a LED strip and now experience hyperflash when turning off their lights. They were advised to add diodes to the turn signal and parking light leads to stop the backflow of current, but they are unsure of the appropriate size and wattage for the diodes. The speaker also clarifies that all their lights are legal and the hyperflash harness helps prevent the LEDs from flashing too quickly.
wascapsfan
Hello,
I have LED's all over my vehicle. I have them as tail lights, in the climate control,door switches, and several more throughout my car.
I have this piece called a HYPERFLASH harness hooked up in the system that was recommended to prevent hyperflash, and it has done a perfect job. I just added what they call clear corners (turn signals) that have had LED's in them also with no issues. Yesterday I changed those corners for a set that had an LED strip along the bottom of the turn signal housing that has 3 wires that get hooked into the system:
A ground, a lead for the parking light that turns the white LED's on the strip on when the lights are on, and another lead that goes to the turn signal that over rides the previous lead when the turn signal gets turned on and turns on the amber led's in the same strip.
I now have hyperflash when I turn the lights off (for example, when it's daytime). ALL of my LED's inside and outside the car are now hyperflashing like a Christmas Tree. I was told that I needed to add Diodes to both the left and right side turn signal lead AND the parking light lead to stop the backflow of current.
My problem is...I haven't a clue of which size, wattage, etc... that I will need. The car is 12 volts that can go as high as 14.4 volts and there are a total of 18 LED's (9 white parking light and 9 amber turn signal) in each turn signal (one on each side of the car). I was also told to run the diode along side the leads (tapping into the existing wires as opposed to cutting the wires and putting the diode in between the 2 cut wires).
Any suggestions?
Please advise
Thanks
Dave
wascapsfan said:
Hello,
Any suggestions?
Please advise
Thanks
Dave
Welcome to the PF.
I'm not understanding what the Hyperflash does. It flashes LEDs or keeps them from flashing?
Does it come with some application notes or installation instructions that show where the diodes should go? You will size the diodes based on the the forward current that they will carry, and the ~ 0.7V forward voltage drop. The product of those two P = I * V gives you the power that they will be dissipating. That determines the size diode that you will choose.
BTW, are all of the lights street-legal, or is this just for car shows? Some lights aren't allowed to blink per the Vehicle Code...
Welcome to the PF.
OK. Sorry. The lights are legal. The hyperflash harness STOPS LED's from flashing too fast when you turn the turn signals on.
I have LED's EVERYWHERE in my car. With the help of this hyperflash harness, all systems worked normally like every other car.
Now I installed my new corners with a two tone LED strip (amber for the turn signal, and white for the parking lights). I previously had normal corners with SWITCHBACK LED bulbs which worked perfectly. ( I have LED taillights, Climate Control, door switches, etc.. all over my car and have never had any issues until this new corner light). Enter the new corners with 3 wires (the previous bulbs fit into the new unit as it did the old unit) going to the strip that has been installed in the corner lights. One wire is connected to the turn signal that makes the amber led's light up when the turn signal is on (works nicely), the next wire connects to the parking light, which makes the white led's in the strip light up( it works perfectly), and the last wire goes to ground. ALL WORK PERFECTLY as they should. My trouble lies when I start the engine and do NOT have the lights on. All of my LED's inside the car and out start flashing. It all stops and everything goes to normal if I just turn on my parking lights or headlights. Then there is no hyperflash. It only happens with the car running and the lights off.
Related to What diode do I need for automobile turn signals with LED's
1. What is a diode and why is it needed for automobile turn signals with LED's?
A diode is an electronic component that allows current to flow in only one direction. In automobile turn signals with LED's, a diode is needed to prevent the LED's from blinking too quickly or causing a "hyperflash" effect. It helps regulate the current and ensures that the LED's blink at the correct rate.
2. How do I determine the correct diode to use for my automobile turn signals with LED's?
The correct diode to use for your automobile turn signals with LED's will depend on the specific make and model of your vehicle. It's important to consult your vehicle's manual or speak with a professional to determine the correct diode for your specific application.
3. Can I use any diode for my automobile turn signals with LED's?
No, you cannot use just any diode for your automobile turn signals with LED's. The diode needs to be specifically designed for use with LED's and must have the correct voltage and current ratings. Using the wrong diode can cause damage to your LED's or your vehicle's electrical system.
4. Is it necessary to install a diode for each LED in my automobile turn signals?
In most cases, a single diode will be sufficient to regulate the current for all LED's in the turn signal. However, if you are using a large number of LED's or have a complex setup, it may be necessary to use multiple diodes. Again, it's important to consult a professional to determine the best setup for your specific application.
5. Can I install the diode myself or do I need a professional?
If you have experience with electronics and are familiar with your vehicle's electrical system, you may be able to install the diode yourself. However, if you are unsure or uncomfortable with the process, it is best to consult a professional. Improper installation can result in damage to your vehicle or create a safety hazard.
  • Electrical Engineering
9K
16K
