What is phase in material science
In summary, the rules for nomenclature of phases in materials typically refer to the relative molar amounts of each component, with the numbers corresponding to the number of elements in the compound. For example, LaFeAsO is a 1111 family compound because it contains one atom each of La, Fe, As, and O. FeTe is considered an 11 phase because it is a binary compound, and Fe(1)Se(0.5)Te(0.5) is also considered an 11 phase because from a crystal structure standpoint, selenium can substitute for tellurium without changing the composition significantly.
Shriphysics
What is 1111 phase in material science
Hi Guys,
I wonder if someone tells me about what are the rules for nomenclature of phases in materials.
Generally I read like 1111 phase, 122 family, 11 system. I don't understand completely about this. Does they talk about composition or something else?
for ex.- BaFe2As2 is 122 phase material, LaFeAsO is 1111 family compound.
Kindly guide me in any related context.
Thanks in advance.
Shriphysics
Hi, Shriphysics, welcome to PF. Looks like just the relative molar amounts of each component, no? That is, LaFeAsO is 1111 because it's La1Fe1As1O1.
Hi Mapes,
Thanks for reply...I was also thinking same but wanted to confirm from someone.
Anyway now I wonder if you know FeTe is 11 phase no problems about it, but when we prepare a composite Fe(1)Se(0.5)Te(0.5) then also we say it as 11 phase, why its not like 1 1/2 1/2 phase??
I haven't worked with this particular material, but my best guess is that FeX is a binary compound between iron and X, and that selenium can substitute for tellurium in the crystal structure. From a crystal structure standpoint, therefore, things don't change much for FeTexSe1-x as x varies from 1 to 0. But this is just my speculation.
Phase in material science refers to the physical state of a material at a certain temperature and pressure. This can include solid, liquid, gas, or even a combination of these states. In material science, the term "phase" is often used to describe the structural arrangement of atoms or molecules in a material.
The 1111 phase in material science refers to a specific type of crystal structure known as the tetragonal structure. This structure is characterized by a four-fold symmetry and is commonly found in materials such as iron-based superconductors. The numbers in the term refer to the ratio of elements in the material, in this case, one atom of La (lanthanum), one atom of Fe (iron), one atom of As (arsenic), and one atom of O (oxygen).
The nomenclature of phases in materials is based on the chemical composition and crystal structure of the material. This helps to identify and differentiate between different materials and their properties. For example, the 122 phase refers to a structure with two atoms of Ba (barium), two atoms of Fe (iron), and one atom of As (arsenic). Similarly, the 11 system refers to a material with one atom of Ba (barium) and one atom of Fe (iron).
I hope this helps to clarify the concept of phases in material science. If you have any further questions, please let me know.
Related to What is phase in material science
1. What is phase in material science?
Phase in material science refers to the distinct physical and chemical state of a material. This can include solid, liquid, gas, or plasma phases. It is determined by factors such as temperature, pressure, and composition.
2. How many phases can a material have?
A material can have multiple phases, depending on the conditions it is subjected to. For example, water can exist in three phases - solid (ice), liquid (water), and gas (water vapor) - depending on temperature and pressure.
3. What is the role of phase in material properties?
The phase of a material can greatly influence its properties, such as strength, conductivity, and reactivity. For example, a metal in its solid phase may be strong and conductive, but in its liquid phase, it may have lower strength and conductivity.
4. How does phase transition occur in materials?
Phase transition occurs when a material undergoes a change in its physical or chemical state due to changes in temperature, pressure, or composition. This can result in the material changing from one phase to another, such as from a liquid to a solid.
5. Can phase transitions be reversible?
Yes, some phase transitions can be reversible, meaning the material can change back to its original phase under certain conditions. For example, water can transition from a liquid to a solid (ice) and back to a liquid through changes in temperature.
  • Materials and Chemical Engineering
  • STEM Academic Advising
  • New Member Introductions
