afcwestwarrior
- 457
for OCL-
and HOCL
and HOCL
Delta s (Δs) is the change in entropy of a system, while delta h (Δh) is the change in enthalpy. Entropy is a measure of the disorder or randomness in a system, while enthalpy is a measure of the total energy in a system.
Delta s and delta h can be calculated using the following equations: Δs = Sfinal - Sinitial and Δh = Hfinal - Hinitial. S represents the entropy, and H represents the enthalpy. The initial and final values for S and H can be obtained experimentally or through theoretical calculations.
Delta s and delta h are important thermodynamic parameters that describe the energy changes that occur in a chemical reaction. Delta s and delta h can determine whether a reaction is spontaneous (favorable) or non-spontaneous (unfavorable).
Gibbs free energy (G) is a measure of the energy available to do work in a system at constant temperature and pressure. Delta s and delta h are used to calculate the Gibbs free energy using the equation G = H - TS, where T is the temperature in Kelvin.
Yes, delta s and delta h can be negative. A negative value for delta s indicates a decrease in disorder, while a negative value for delta h indicates a decrease in energy. This can occur in exothermic reactions where heat is released, or in reactions that lead to more organized products.
