What is the temperature at the joint between the two rods?
In summary, the thermal contact between two pieces of metal leads to a temperature of 673 degrees Celsius at the joint.
mlostrac
83
The thermal conductivity of aluminum is twice that of brass. Two rods, one of
aluminum and the other of brass, are joined together end to end in excellent
thermal contact. They are of equal lengths and radii. The free end of the brass
rod is maintained at 0°C while the free end of the aluminum rod is kept at 200°C.
Under these conditions of steady heat flow, what is the temperature at the joint
Q/t = KA (T1-T2)/L
I was thinking I had to set the rate of heat flow in the brass and aluminum to be equal and then isolate to find T1, but that turned out to be way wrong.
How should I start? I read a similar problem that said we should add the conductivities of the two metals. For example, conductivity of brass = x, conductivity of aluminum = 2x, therefore overall conductivity is 3x.
I think your idea to set the heat flow rates to be equal is correct. I'm not sure why you got wrong answer. Did you notice that for the brass rod, T is the temperature of the hotter end and for the aluminum rod, it's that of the cooler end, where T is the temperature at the joint (and so, T is at the place of T1 for one rod but at the place of T2 for the other rod)?
I don't think adding thermal conductivities here is helpful.
This sounds like solid reasoning. Where did it go wrong? Did you write a conduction equation for each metal and set them equal?
Not for two materials connected end to end.
K here's what I did:
[kA (T1-T2)]/L = [2kA (T1-T2)]/L
Since Areas and lengths are the same, the A's and L's cancel:
k(T1-T2) = 2k(T1-T2)
k(273 - T2) = 2k(473 - T2)
273k - KT2 = 946k - 2kT2
kT2 = 673k
T2 = 673 Kelvin or 400 degrees celsius
Which has got to be wrong because the original temp of the aluminum (the hotter material) is 200 degrees celsius
What do you think?
I don't know where the 2k came from; if aluminum has twice the thermal conductivity, why multiply it by two again? Try setting an energy balance: the heat flow coming in equals the heat flow going out.
Assume the aluminum rod is on the left, and the temperatures at measured at the left end, the midpoint, and right end ([itex]T_\mathrm{l}[/itex], [itex]T_\mathrm{m}[/itex], and [itex]T_\mathrm{r}[/itex]). The heat flow is the positive x direction is always
[tex]-kA\frac{\Delta T}{\Delta x}=-k_\mathrm{Al}A\frac{T_\mathrm{m}-T_\mathrm{l}}{L}=-k_\mathrm{Br}A\frac{T_\mathrm{r}-T_\mathrm{m}}{L}[/tex]
Try solving this.
Thermal conductivity of aluminum (2k) is 2 times that of brass (k). Thank you, I'll try now...
If a person with height X is twice as tall as a person with height Y, does Y = 2X?
OK, so I ended up getting 133 degrees celsius after using your equation which sounds like it could be right. I used the thermal conductivity values found in my text to plug into the following equation:
Tm = (Kal473 + Kbr273) / (Kal + Kbr)
* the numbers for Kal and Kbr were 200 and 100 respectively.
Look good?
That sounds better. It should make sense that if aluminum's thermal conductivity is higher, then the midpoint should be closer to the temperature at the end of the aluminum rod.
Ok thank you for your help! Much appreciated
Related to What is the temperature at the joint between the two rods?
1. What is the joint temperature between the two rods?
The joint temperature between the two rods is the average temperature at the point where the two rods meet or connect. It is the temperature that can be measured at the interface of the two rods.
2. How is the joint temperature between the two rods calculated?
The joint temperature between the two rods can be calculated by taking the average of the temperatures at the interface of the two rods. This can be done by measuring the temperature at multiple points along the interface and then finding the average value.
3. Why is the joint temperature between the two rods important to measure?
The joint temperature between the two rods is important to measure because it can indicate the efficiency of heat transfer between the two rods. It can also help determine if there are any temperature differences or imbalances between the two rods, which could affect their performance.
4. What factors can affect the joint temperature between the two rods?
The joint temperature between the two rods can be affected by factors such as the materials of the rods, their surface area, the rate of heat transfer, and the external temperature. Other factors such as the presence of insulating materials or the use of a heat source can also impact the joint temperature.
5. How does the joint temperature between the two rods relate to the overall temperature of the system?
The joint temperature between the two rods is a component of the overall temperature of the system. It is an important part to consider, but it does not necessarily reflect the average temperature of the entire system. Other factors such as the temperature of the surrounding environment and the heat flow within the system also contribute to the overall temperature.
9K
