What must be one's speed, relative to a frame S, in order....
In summary, time dilation states that a clock moving with respect to an observer will appear to run slower compared to a stationary clock. In the case of a clock losing 1 second per day, the moving clock will experience (24*60)-1 minutes while the stationary clock experiences 24*60 minutes. This can be calculated using the time dilation formula and solving for velocity. Alternatively, an approximate formula can be used if the value of gamma is close to 1.
cosmos42
... in order that one's clocks will lose:
(a) 1 second per day as observed from S?
(b) 1 minute per day as observed from S?
I was referencing this:( http://hyperphysics.phy-astr.gsu.edu/hbase/relativ/tdil.html#c2 ) hyperphysics page but I still can't seem to understand what I need to do to solve for velocity.
In the one minute-per-day case, time dilation says that while 24*60 minutes elapse on the stationary clock, (24*60)-1 minutes elapse on the moving clock. The time dilation formula and some algebra will see you home from there.
Likes cosmos42
There are 86400 seconds in a day so on a clock that loses 1 second per day 86401 seconds will pass. Thus ##\gamma## equals ##\frac{86401}{86400}##. You can then use that value in the time dilation formula you linked to and solve for ##v##.
Or, since both of your γ are close to 1, you can use the following approximate formula:
v2 ≈ 2 c2(γ - 1)
That's a clock gaining 1s. A slow clock will tick 86399 times in a day as measured by a clock at rest in S, which gives ##\gamma =\frac {86400}{86399}##.
Likes Mister T
Related to What must be one's speed, relative to a frame S, in order....
1. What is a frame of reference?
A frame of reference is a set of axes or coordinates used to describe the position, motion, and orientation of an object or observer in space.
2. How is speed measured in a frame of reference?
Speed is measured as the rate of change of distance with respect to time in a particular frame of reference. It is typically expressed in units of distance per unit of time, such as meters per second or miles per hour.
3. What is meant by "relative" speed?
Relative speed refers to the speed of an object or observer with respect to a particular frame of reference. It takes into account the motion of the observer and the object being observed, rather than just the speed of the object alone.
4. Why is a frame of reference important in measuring speed?
A frame of reference allows us to accurately measure an object's speed and describe its motion in a specific context. Without a frame of reference, the speed of an object would be relative to the observer's perspective, making it difficult to compare and analyze different speeds.
5. Can an object have different speeds in different frames of reference?
Yes, an object can have different speeds in different frames of reference. This is because the speed of an object is always relative to the observer's perspective. For example, a car traveling at 60 miles per hour to a stationary observer may appear to be moving at a slower speed to an observer in a car traveling at the same speed.
