kyphysics
- 676
- 437
Thought this might be an interesting question. Feel free to post why it was hard and/or what let you finally understand it.
jbriggs444 said:I recall thinking: "what if there is a systematic offset in time corresponding to distance in the direction of relative motion?" Could that resolve these difficulties? Then I turned around, looked at the Lorentz transforms and saw that very term staring me in the face. *facepalm*.
Do you mean you think that nothing is absolute? If so, then no, some things ARE absolute. Just as a simple example, the outcome of arithmetic is absolute. 2 + 2 (in base 10, just to be clear) has an absolute outcome. It's always 4.sadhappymusic said:Speaking of absolute did you know that this is also not absolute ?
Ah. Well, I guess I was over-interpreting your comment.sadhappymusic said:No I meant that the "stages of grief" are not absolute. 2+2 in base 10 definitely is.
Absolutely.sadhappymusic said:Speaking of absolute did you know that this is also not absolute ?
phinds said:Do you mean you think that nothing is absolute? If so, then no, some things ARE absolute. Just as a simple example, the outcome of arithmetic is absolute. 2 + 2 (in base 10, just to be clear) has an absolute outcome. It's always 4.
Could you elaborate on what this means? It sounds interesting.atyy said:I still don't understand (intuitively) why the bottom of the wheel does not move relative to the ground!
mcastillo356 said:Circles are not geometry? That's how arose ##\pi##
Does the second theory explain all the phenomena of the first one but has little in common with it?If it explains all the phenomena and provides explanation for new phenomena that the first does not it is a generalisation.But if it explains completely the same phenomena with the first I would say it is equivalent, but has a different statement.mcastillo356 said:"How do we know that, if we made a theory which focuses its attention on phenomena we disregard and disregards some of the phenomena now commanding our attention, that we could not build another theory which has little in common with the present one but which, nevertheless, explains just as many phenomena as the present theory?"
I need your help to understand these sentence, I thought I had understand: does it mean that if somebody states something inconsistent, this is, not in agree with something else, eg, previous studies, we can fall into a chain of failures? Is DanielMB trying to say that the concurrence of ##\pi## is yet to study?
I agree, and further it seems strange to me that cardinalities bump up in scale discretely according to simple formulas. It makes me wonder how intrinsic it is (beyond ZFC in general, and in nature).kyphysics said:I think different types of infinity are weird.
You can have infinity from 0 on up . . .
Then, you can have a "smaller" infinity from 1 on up. . .
Both are infinity, but one is larger than the other.
Have you studied any philosophy, Jarvis? I'm not a STEM major, but do have a social sciences and humanities background that includes philosophy (almost a minor of mine).Jarvis323 said:I also find uncomputable numbers strange. They are numbers which presumably cannot show up or play any role in a physical universe, unless the universe has an infinite state space going into determining a single value. And these numbers are the vast majority of numbers (small and big). They make up the vast majority of the interval from 0 to 1 for example. And they're implicitly part of our continuous physics models, even though they can't really be in the way they are in the model in reality.
It makes me think that maybe values are not complete separable objects in physical reality, but rather a single value, or physical realization of a real number, is something that must be distributed in space and time (perhaps infinitely in each dimension), and not only can we not measure them completely as an instantaneous thing, or completely in any sense, but we can't even talk about them completely or use them in applied math or physics.
The scientific method is a systematic approach to conducting and analyzing experiments in order to gain knowledge and understanding about the natural world. It involves making observations, formulating a hypothesis, designing and conducting experiments, collecting and analyzing data, and drawing conclusions. This process is used to test and validate theories and to make predictions about future experiments.
A hypothesis is an educated guess or prediction about a phenomenon that can be tested through experimentation. It is a tentative explanation for a set of observations. A theory, on the other hand, is a well-supported and extensively tested explanation for a wide range of phenomena. It is a comprehensive and widely accepted explanation that has withstood the test of time and has been supported by multiple lines of evidence.
Peer review is a critical part of the scientific process. It involves having other experts in the same field review and evaluate a scientist's research before it is published. This process helps to ensure the accuracy and validity of the research and allows for any potential biases or errors to be identified and corrected. It also helps to maintain the high standards and credibility of scientific research.
Correlation refers to a relationship between two variables, where a change in one variable is associated with a change in the other variable. However, this does not necessarily mean that one variable caused the change in the other. Causation, on the other hand, refers to a direct cause-and-effect relationship between two variables, where one variable directly influences the other. It is important for scientists to establish causation through controlled experiments rather than relying solely on correlations.
Scientists use a variety of methods to ensure the validity and reliability of their findings. This includes using appropriate and reliable research methods, controlling for variables, replicating experiments, and using statistical analysis to determine the significance of results. Additionally, peer review and publication in reputable scientific journals also help to validate and establish the credibility of scientific findings.
