What was the explanation of OPERA superluminal neutrinos?
In summary, the OPERA apparent superluminal results on the measurement of neutrinos speed were initially explained using relativistic effects, but it was later found that the effect could be non-relativistic. The effect is called "The Sagnac satellite effect" and is due to the difference in time it takes for a light ray to reach the lab from a GPS satellite. A back-of-the-envelope calculation showed that the effect was 18 meters and not 20 meters as was expected. It was found that a faulty wire connection was to blame, not a loose wire.
MachPrincipe
44
When I first heard about the OPERA apparent superluminal results on the measurement of neutrinos speed, I tried to locate an explanation using all the possible relativistic effects. All were too small to account for a difference of 18 meters of virtual distance among photons and neutrinos.
Then I realized that the effect could be non-relativistic. I called it «The Sagnac satellite effect». They were using GPS satellites to track times. If one assumes that somehow in the calculations they didn't take into account the time it takes for a light ray to reach the lab from the satellite, it turns out that there is a difference which is not only of the same order of magnitude than expected, but also close to the 18 meters figure.
A back-of-the-envelope calculation uses this:
d = v_e * h / c * cos (theta)
where v_e is the Earth rotation speed (almost linear if only a few nanoseconds are taken into accout), h is the height of GPS satellite and theta is the mean latitude of the center of the segment connecting Gran Sasso and CERN.
v_e = 464 m/s
h = 20.000 km
theta = 44°
Thus d ~ 23 meters.Is it possible that a loosely tied switch could have turned off the correction needed for accounting this Sagnac effect when computing arrival times?
I am a little puzzled because relativistic effect were orders of magnitude different, and however this effect is not of the same order but close to the value. Is it just a big coincidence?
They took this into account (and the effect is much smaller, keep in mind that both CERN and Gran Sasso are rotating in a similar way, and the effect depends on the satellite position so it is not a constant distance difference). The loose cable just prevented a proper clock synchronization, so different clocks recorded different things.
Yes, the calculation uses only a single satellite and a mean position, also rectilinear movement instead of spherical coordinates and circular motion. It was just that I thought that the correction for the combined effect could have been masked due to the faulty wire. As for both locations rotating, the effect has just to do with time signals take to tragel each satellite-ground path. If you do not take Earth rotation into account you get a 20 meters difference or 90 nanoseconds time shift, which was the difference among neutrinos and light. Even I thought of a computer bug which did not calculate properly this part. The faulty wire is much more embarrasing, in my opinion.
You don't get 20 meters. If the satellite is at 90 degrees to the rotation direction, the effect is zero (to first order). If the satellite is roughly at the horizon in the right direction, the travel time to Gran Sasso increases or decreases by 20 meters, and the travel time to CERN increases or decreases by nearly 20 meters as well, so clock synchronization is still better than 20 meters. Also, different satellite positions lead to different effect sizes (and directions), this would have been noted easily.
Satellites at the horizon enhance uncertainties coming from atmospheric effects, so they were not used anyway.
You are right, I had doubts about the diifferent positions of the satellites, number of them, etc. The consistency of the data troubled me with this plausible hypothesis. In any case, I don't see how a faulty wire could not lead to stronger and irregular perturbations, easily identified as noise.
The main problem wasn't a loose wire but rather a loose optical fibre connector. I think that meant that a pulse signal was much weaker than intended, causing triggering to be delayed well past the leading edge and resulting in the clock at the transmitting end being a few nanoseconds behind the GPS time being used for reference. There's a Wikipedia page on the subject (which I haven't read in full but appears to support this explanation): Faster-than-light neutrino anomaly
Likes vanhees71
Thanks for the reference, I read it but still cannot understand the details. It is my suspect that I may be somehow right at the end: if the time corrections are of the same order than the Sagnac satellite effect because there are contributions of several satellites, it is plausible that a faulty optical fiber could distort results in a magnitude similar to that exposed, with the close value just being a mere coincidencem However, if we were talking of other relativistic effects not being,corrected, many orders of magnitude different, it would be a very big coincidence to be of the similar value than the results. Summariziing, I am bold fo claim that the failure in synchro was related, even if indirectly, with synchro somehow related to GPS satellites and thus with contribution to several Sagnac satellite effects.
These two statements do not go well together. If you can't understand the details, why would you think you may be "somehow right"?
Just before Cern discovered the error they repeated the experiment/calibration with a greatly reduced packet size and published the exact same sized errors as they obtained with their original published experiment/calibration. I always thought it was unusual that the errors stayed exactly the same for both tests despite the reasons given.
Wiki said:
Later the team reported two flaws in their equipment set-up that had caused errors far outside their original confidence interval: a fiber optic cable attached improperly, which caused the apparently faster-than-light measurements, and a clock oscillator ticking too fast.[3] The errors were first confirmed by OPERA after a ScienceInsider report;[4] accounting for these two sources of error eliminated the faster-than-light results.[5]
http://www.theguardian.com/science/2011/nov/18/neutrinos-still-faster-than-light?newsfeed=true
One potential source of error pointed out by other scientists was that the pulses of neutrinos sent by Cern were relatively long, around 10 microseconds each, so measuring the exact arrival time of the particles at Gran Sasso could have relatively large errors. To account for this potential problem in the latest version of the test, the beams sent by Cern were thousands of times shorter – around three nanoseconds – with large gaps of 524 nanoseconds between them. This allowed scientists to time the arrival of the neutrinos at Gran Sasso with greater accuracy.
It is a pity that they didn't published something like the NASA "Hubble Space Telescope Optical Systems Failure Report" to eliminate any misconceptions.
https://www.ssl.berkeley.edu/~mlampton/AllenReportHST.pdf
Because the data to be corrected were precisely those satellite effects, so that would explain, if the correction fails by software bug, optical fiber defect or anything else, that the correction would fail to apply and if it is on the correct order of magnitude, then no strange that the value coincides so close.
There are many signal propagation delays that had to be taken into account, some of them are about 20 meters, even if the loose fibre would have let to the measurement ignoring one of them there is no reason to expect a specific one.
The sagnac-like effect, as shown above, is significantly below 20 meters, and varies from satellite to satellite, contrary to the observation of the OPERA collaboration. We can rule this out.
From the wikipedia page:
  • A link from a GPS receiver to the OPERA master clock was loose, which increased the delay through the fiber. The glitch's effect was to decrease the reported flight time of the neutrinos by 73 ns, making them seem faster than light.[21][22]
  • A clock on an electronic board ticked faster than its expected 10 MHz frequency, lengthening the reported flight-time of neutrinos, thereby somewhat reducing the seeming faster-than-light effect. OPERA stated the component had been operating outside its specifications.[23]
Reference 22 is the most interesting one, the original is in German but there is a translation available: the details of the fibre connection influenced the synchronization of two clocks, if the fibre was loose one clock was too late/early with respect to the other.
"I don't understand it, therefore I'm convinced whatever I came up with is right" is never a good approach.
I agree.
MachPrinciple, is there any evidence whatsoever that could come from OPERA that would convince you that you are wrong? If so, what? If not, well, if not, can you really say you are doing science?
Neutrinos they exhibit spontaneous chiral oscillations. This provides a temporal metric for the neutrino's reference frame. As such, time (relative to this frame) is not stretched to infinity, so neutrinos must travel at non-celerital speed. Certain interactions of neutrinos occur in a temprorally asymmetric way, therefore the neutrinos travel in negative time direction towards the future as all sub-luminal entities.
This not only provides neutrinos with a sub-luminal speed, but also a non-zero rest mass.
Vanadium 50 said:
I agree.
I am not doing science. It was speculation all the time. I could not pretend to peer-review an experiment which is outside my scope, knowledge and means. Simply I have always found the coincidence very curious. Nothing else. As for the effect, it must be rutinarily be taken into account, whatever its name if it has one (Sagnac effect would be a little different here). I will not suggest that they are masking the real error by anoth
Well, since you have your answer, and refuse to believe it, maybe it's time for the thread to be closed.
Related to What was the explanation of OPERA superluminal neutrinos?
1. What was the initial discovery of superluminal neutrinos by the OPERA experiment?
The OPERA experiment, which stands for Oscillation Project with Emulsion-tRacking Apparatus, announced in September 2011 that they had observed neutrinos travelling faster than the speed of light. They measured the neutrinos travelling from CERN in Switzerland to the Gran Sasso National Laboratory in Italy, a distance of 730 kilometers, and found that they arrived 60 nanoseconds earlier than expected.
2. What was the proposed explanation for the observed superluminal neutrinos by the OPERA experiment?
The researchers initially thought that the superluminal neutrinos were moving faster than the speed of light due to a possible error in their measurement or analysis. However, after further investigations, it was suggested that the neutrinos may have been taking a shortcut through extra dimensions, which would allow them to travel a shorter distance and arrive earlier than expected.
3. How did the scientific community respond to the initial announcement of superluminal neutrinos by the OPERA experiment?
The initial announcement by the OPERA experiment was met with skepticism and criticism from the scientific community. Many physicists pointed out flaws in the experimental setup and questioned the accuracy of the measurements. Additionally, the idea of particles travelling faster than the speed of light went against the well-established principles of Einstein's theory of relativity.
4. What were the results of further experiments and observations regarding the superluminal neutrinos by the OPERA experiment?
After the initial announcement, the OPERA experiment conducted further experiments to confirm their results. However, they found that the earlier-than-expected arrival of neutrinos was most likely due to a faulty cable connection in their equipment, which caused a delay in the timing of the neutrino signal. Further observations and experiments by other research groups also did not find any evidence of superluminal neutrinos, leading to the conclusion that the initial result was most likely due to an experimental error.
5. What is the current understanding of the superluminal neutrinos observed by the OPERA experiment?
Currently, the superluminal neutrino result by the OPERA experiment is considered to be a false alarm. The experiment has been repeated with improved equipment and procedures, and no evidence of superluminal neutrinos has been found. The consensus among the scientific community is that the initial result was most likely due to an experimental error, and that neutrinos do not travel faster than the speed of light.
  • Beyond the Standard Models
  • Quantum Physics
11K
  • Electromagnetism
11K
