What Would Happen if Our Sun Became a Pulsar?
In summary: If our sun was replaced by a pulsar, would our solar system be sucked into it because of the increased gravity? How long would it take? Would we burn up because of the increased heat? How long would it take? Does it still emit visable light or only x-rays etc..?If our sun was replaced by a pulsar, the gravitational pull would be exactly the same. The pulsar's emission spectra would depend largely on its evolutionary state, surface temperature, and local environment. It would be (at least) significantly dimmer in the visual. The strobes and level of x-ray emission would depend sensitively on the orientation of the pulsar's magnetic field axis to the orbital plane of
Algaib
If our sun was replaced by a pulsar, would our solar system be sucked into it because of the increased gravity? How long would it take? Would we burn up because of the increased heat? How long would it take? Does it still emit visable light or only x-rays etc..? Would the light on Earth be observed as a 'strobe'? (if the rotation of the pulsar was slow enough to see, say a few seconds.)
Space news on Phys.org
Our solar system would not be sucked in.
If the sun was replaced by a solar mass pulsar, the gravity would be exactly the same.
The strobes and level of x-ray emission would depend sensitively on the orientation of the pulsar's magnetic field axis to the orbital plane of the earth. Generally the magnetic field is perpendicular to the orbital plane, and thus we would not see (or be exposed) to the pulses.
What if you had a pulsar with much more mass than the sun, say enough to pull everything into it, how long would that process likely take? For Earth to fall in?
Things still wouldn't be pulled in, it would just change their orbits.
Its very possible the new configuration would be unstable however... and eventually some planets would collide with the sun, or others would be ejected from the system. There is no predictable amount of time that would take without doing the calculations. Most like between millions and billions of years.
Pulsar Effect on Planets Videos
http://www.google.com/search?source...ved=0CFsQqwQ&bav=on.1,or.&fp=e63e90ac70623278
One thing to keep in mind is that pulsars are rotating neutron stars resulting from supernova explosions. So any planets that were present at the time of that event were bathed in the resultant radiation. There are actually rocky planets that have been detected around a pulsar. Neutron star, PSR B1257+12, was the first. Here is an article concerning this.
Planets around pulsars:
http://www.astro.psu.edu/users/alex/pulsar_planets_text.html
Related to What Would Happen if Our Sun Became a Pulsar?
1. What is a pulsar?
A pulsar is a highly magnetized, rotating neutron star that emits beams of electromagnetic radiation. It is formed when a massive star undergoes a supernova explosion and collapses, with its core becoming incredibly dense and spinning rapidly.
2. Can our Sun become a pulsar?
No, our Sun does not have enough mass to undergo a supernova explosion and form a pulsar. Pulsars are typically formed from stars that are at least 10 times more massive than our Sun.
3. What would happen to Earth if our Sun became a pulsar?
If our Sun were to somehow become a pulsar, the Earth and other planets in our solar system would not be able to survive. The intense radiation and strong magnetic fields emitted by the pulsar would strip away our atmosphere and potentially even disrupt the orbits of the planets.
4. How long would it take for our Sun to become a pulsar?
This is difficult to predict, as it is dependent on many factors such as the mass of our Sun and its rate of rotation. However, it is estimated that our Sun will not undergo a supernova and become a pulsar for another 5 billion years.
5. What would happen to the rest of the stars and galaxies if our Sun became a pulsar?
If our Sun somehow became a pulsar, it would not have a significant impact on the rest of the stars and galaxies in the universe. Pulsars are relatively small and do not have enough mass to significantly affect the structure and dynamics of galaxies.
  • Astronomy and Astrophysics
  • Other Physics Topics
