When will DNA adopt an A-form helix?
  • Thread starter whamola411
  • Tags
    Dna Helix
In summary, DNA can adopt either an A-form helix or a B-form helix, with the B-form being more prevalent in aqueous solution. Low humidity can help form the A-form, while high humidity favors the B-form. However, in the body, DNA will always be surrounded by water and thus will not adopt an A-form helix. RNA, on the other hand, can only exist in an A-form helix due to the presence of a 2' hydroxyl group preventing the required conformation for a B-form helix.
whamola411
Can DNA adopt an A-form helix, and can RNA adopt a B-form helix. If so, under what conditions, and if not, why not?
The only idea I have so far is that low humidity will help form the A form, and high humidity forms the B form. However, can humidity change in our bodies? I'm lost here.
As you mentioned, DNA can adopt either an A-form helix or B-form helix, although in aqueous solution, the B-form is most prevalent. As you noted, DNA can be artificially made to adopt an A-form helix under conditions where it is dehydrated. Naked DNA in the body would not adopt an A-form helix because there will always be water around. However, researchers have seen that DNA can adopt an A-form like geometry when bound by certain proteins, such as some DNA polymerases. Furthermore, certain bacteria that form spores will dehydrate themselves and with the help of specific DNA binding proteins, convert their DNA to adopt an A-form geometry.
RNA is capable of existing only in an A-form helix. The 2' hydroxyl in RNA prevents the sugar from adopting the C2'-endo conformation required for a B-form helix.
Thank you so much, I couldn't find information on this anywhere!
Related to When will DNA adopt an A-form helix?
1. What is the A-form helix in DNA?
The A-form helix is a secondary structure of DNA in which the base pairs are tilted and displaced from the central axis, resulting in a wider and shorter helix compared to the more common B-form helix.
2. How does the A-form helix form?
The A-form helix can form under certain conditions, such as in low salt concentrations or in the presence of specific proteins or chemical modifications.
3. Why is the A-form helix less common than the B-form helix in DNA?
The A-form helix is less common because it is a less stable conformation compared to the B-form helix. It also requires specific conditions to form, making it less likely to occur in natural DNA.
4. What is the significance of the A-form helix in DNA?
The A-form helix may play a role in certain biological processes, such as DNA replication and repair. It may also have implications in the regulation of gene expression.
5. When will DNA adopt an A-form helix?
The A-form helix is not a permanent conformation in DNA, but rather a transient state that can occur under specific conditions. It is difficult to predict when exactly DNA will adopt an A-form helix, as it depends on various factors such as the environment and interactions with other molecules.
11K
  • Classical Physics
