Which solvent is the best choice?
In summary, the conversation discusses the extraction and quantification of lipids within starch and which solvents would be suitable for this process. The concept of "like dissolves like" is brought up, and it is determined that lipids are soluble in organic solvents such as chloroform while starch is insoluble. The problem of precipitation of starch under all solvents is discussed and the use of a separation funnel is suggested, although it may be blocked by the starch. Other methods such as solid phase separation, filtering, or centrifuging are also mentioned as potential solutions.
Cyrus the great
23
I want to extract and quantify lipids inside the starch. Which solvents you recommend for the extraction?
Let's turn this into a learning experience --- "like dissolves like," can be translated to what?
Hi,
I didnt understand what do you mean? Starch is not soluble neither in water nor in ethanol but lipids are soluble in organinc solvent such as chloroform. But the problem is starch would be precipitated under all the solvents (it would be water phase,organic phase and the. Precipated starch)? Is my theory correct? If we use separation funnel then starch would block the passage of the funnel?
Sounds like you've got your answer --- starch is insoluble.
So, what is the solution? Do you have any idea?
Sep funnels are great for liquid-liquid extractions, but they're not the only tool. If you want to separate your organic solvent + dissolved lipids from the starch, what methods do you know of that might work to separate a liquid from a solid?
Solid phase seperation?
You can try filtering out the solid or centrifuging.
Related to Which solvent is the best choice?
What is a solvent?
A solvent is a substance that has the ability to dissolve other substances, known as solutes.
What factors should be considered when choosing a solvent?
The factors that should be considered when choosing a solvent include its ability to dissolve the desired solute, its chemical compatibility with the solute, its toxicity, its cost, and its availability.
What is the most commonly used solvent?
Water is the most commonly used solvent in both scientific research and industrial processes due to its availability, low cost, and low toxicity.
Why is the choice of solvent important?
The choice of solvent is important because it can greatly affect the outcome of a chemical reaction or process. The right solvent can improve the solubility and yield of a desired product, while the wrong solvent can lead to unwanted side reactions or impurities.
Can one solvent be universally considered the best choice?
No, there is no single solvent that can be considered the best choice for all situations. The best solvent depends on the specific needs and goals of the experiment or process, and different solvents may be more suitable for different purposes.
