Why amonia is a base and not water?
  • Thread starter SciencePF
  • Tags
    Base Water
In summary, ammonia (NH3) acts as a base in water because it has a lone electron pair, making it a proton acceptor. Water is able to act as both an acid and a base, but in this case, it acts as an acid by donating a proton to ammonia, effectively forming NH4+ and OH-. The geometry and electronegativity of water and ammonia also play a role in why ammonia is able to accept a proton more easily than water.
SciencePF
56
Why amonia NH3 in water acts as a base and not an acid?
Thanks
Chemistry news on Phys.org
Because the nitrogen atom has a lone electron pair, and thus is a proton acceptor. Proton acceptors are bases.
- Warren
but water has two lone electron pair!
Water is amphoteric -- it can indeed act as a base, but it can also act as an acid.
- Warren
Sorry, Warren, but water is amphoteric and why it can not act as a proton acceptor from NH3?
Technically speaking, water is amphiprotic. Wiki has a good explination of this: http://en.wikipedia.org/wiki/Amphiprotic
But as to the original question:
When you combine water with say, Hydrogen Chloride, HCl is the acid and Water is the base (according to Brønsted-Lowry theory becuase water is accepting the proton)
H2O + HCl → H3O+ + Cl−
In the case of combining water with Ammonia you get this reaction:
H2O + NH3 → NH4+ + OH−
Ammonia is clearly accepting the proton and thus (again according to Brønsted-Lowry theory) is the base. (and water is the acid).
Your arguements about electron pairs would fit in more with Lewis Theory of acids and bases, but it still doesn't change anything, as Ammonia is donating its electron pair in that reaction which still makes it a base.
So the reason it is a base is simply becuase the proton goes there (or because the electron pair leaves)
It still doesn't answer the question WHY ammonia is accepting th eproton, instead of donating one of its own to water molecule. And that's the question SciencePF asked.
If you look at the geometry(bent) at an [tex]H_{2}0[/tex] it is a polar molecule. The Oxygen is pretty electronegitive: So the oxygen has a partial charge of [tex]-2\delta[/tex]. Then each Hydrogen has a [tex]+\delta[/tex]. Then the lewis structure of the ammonia has the lone pair of [tex]e^-[/tex] and will take one of the [tex]H^+[/tex]. Hope that helps
Both H2O and NH3 are the sp3 hybridization which have the tetrahedral molecule with O and N as the center. For H2O, there are 2 H and 2 lone pairs. The two lone pairs of electrons in H2O can accept 2 H+, but it is far more difficult than in the case of NH3 which has only one lone pair. If water takes two protons, it will be too positive. If it takes one, it is not symmetrical. NH3 can take one proton making it a complete tetrahedron.
Overmore oxygen has higher electronegativity compared to nitrogen, so oxygen 'hates' H+ more than nitrogen.
Yeah, like pixel said, it's because of energy in the bonds. There is either less energy required or more energy released (I didn't look it up to find out which) in the process of breaking bonds with water's H+ ion and forming NH4 than there is for NH3 to break a bond with an H+ and form H3O. Since this is the 'easier' process (in terms of energy) this is what happens.
Related to Why amonia is a base and not water?
1. What is the definition of a base?
A base is a substance that can accept a proton (H+) from another substance, and is therefore considered to be a proton acceptor.
2. How does amonia act as a base?
Amonia (NH3) has a lone pair of electrons on its nitrogen atom, which can readily attract a proton from another substance, making it a base.
3. Why is amonia a stronger base than water?
Amonia has a stronger ability to accept protons compared to water because it has a larger size and a lone pair of electrons that is more exposed and therefore more available for accepting protons.
4. Can water also act as a base?
Yes, water can act as a base in certain situations. It can accept protons from stronger acids, such as hydrochloric acid (HCl), to form the hydronium ion (H3O+).
5. What is the difference between amonia and water as bases?
The main difference between amonia and water as bases is their relative strengths. Amonia is a stronger base than water, and can accept protons more readily due to its larger size and availability of lone pair electrons on its nitrogen atom.
  • Chemistry
  • Chemistry
  • Chemistry
