Why do some mesons have = sign while others have ≈ in their composition?
In summary, the ω and ϕ mesons have a slightly different composition, which is represented by the use of the ≈ sign instead of the equal sign. This is due to the mixing of SU(3) wave functions and the resulting mixing angle θ. The ω meson has a small component of ss̅, while the ϕ meson does not.
kelly0303
563
33
Hello! I am reading Modern Particle Physics by Mark Thomson and in chapter 9.6.2 he writes the composition of certain mesons. However for some of them he uses an equality sign: $$|\rho^0> = \frac{1}{\sqrt{2}}(u\bar{u}-d\bar{d})$$ while for others he writes: $$|\omega> \approx \frac{1}{\sqrt{2}}(u\bar{u}+d\bar{d})$$ I see that on wikipedia the omega meson appears simply as $$ \frac{1}{\sqrt{2}}(u\bar{u}+d\bar{d})$$ so I was wondering what is the meaning of not using an equal sign for certain mesons' composition. Thank you!
The ≈ is used because the ω has a tiny bit of ss̅
The ω and ϕ arise from mixing of two SU(3) wave functions:
$$\phi = \psi_8 \cos\theta - \psi_1 \sin\theta$$
$$\omega = \psi_8 \sin\theta + \psi_1 \cos\theta$$
where
$$\psi_8 = \frac{1}{\sqrt{6}}(u\overline{u} - d\overline{d} - 2s\overline{s})$$
$$\psi_1 = \frac{1}{\sqrt{3}}(u\overline{u} + d\overline{d} + s\overline{s})$$
The mixing angle θ just happens to be such that
$$\phi \approx s\overline{s}$$
$$\omega \approx \frac{1}{\sqrt{2}}(u\overline{u}+d\overline{d})$$
Related to Why do some mesons have = sign while others have ≈ in their composition?
1. Why do some mesons have an equal sign (=) in their composition?
Some mesons have an equal sign in their composition because they are made up of two quarks with equal and opposite charges. This results in a neutral overall charge for the meson.
2. Why do other mesons have an approximately equal sign (≈) in their composition?
Other mesons have an approximately equal sign in their composition because they are made up of two quarks with slightly different masses. This results in a slightly unequal distribution of charge within the meson, leading to the use of the approximately equal sign.
3. How are mesons different from other subatomic particles?
Mesons are different from other subatomic particles because they are composed of two quarks, while other particles such as protons and neutrons are composed of three quarks. Additionally, mesons have a shorter lifespan and are considered unstable compared to other particles.
4. Are all mesons composed of two quarks?
No, not all mesons are composed of two quarks. There are also mesons known as exotic mesons, which are made up of four or more quarks. These mesons are not as well understood and are still being studied by scientists.
5. How do scientists study the composition of mesons?
Scientists study the composition of mesons by using particle accelerators to create and observe mesons in controlled environments. They also use mathematical models and theories, such as quantum chromodynamics, to understand the interactions between quarks within the mesons.
  • Classical Physics
