Why do we observe an electron both as a wave and as a particle ?
In summary, an electron is both a particle and a wave. If you measure it for wave characteristics, you see the wave characteristics. If you measure it for particle characteristics, you see the particle characteristics.
Leonardo Bittar
Maybe because when you don't observe it, the Schrödinger equation predicts the totality of interactions (paths) of the electron over an infinite time, all the paths it can take ( forming a wave like function ) which is actually all the paths the electron can take overlapped... and when u directly observe the electron, u can only observe the path its taking at a single moment in time. If u take an infinite number of measures of the same electron and superposition their results, the result would be a wave like function, exactly as the Schrödinger equation predicts ?
An electron is not a particle and it is not a wave. It is a quantum object. If you measure a quantum object for wave characteristics, you see the wave characteristics. If you measure it for particle characteristics, you see the particle characteristics. You need to be careful to understand just what you are measuring.
It's both and it's neither.
I mean you use the equations that describe it as a particle and as a wave simultaneously.
  • Skeptical
Likes PeroK
In modern Quantum Mechanics (from about 1930), the experimental results you get for an electron are explained. It's dynamic properties (such as position and momentum) are described by its wavefunction, which evolves according to the Schrödinger equation.
Your description is close to Feynman's path integral formulation, which you could read about here.
https://en.wikipedia.org/wiki/Path_integral_formulation
Essentially the wavefunction at a given point in space at a given time is the sum of all the ways the particle could get to that point at that time, breaking down its path into very small time intervals, and then taking the limit of that sum (integral) as you the time interval tends to zero.
It's actually quite close to what you supposed here:
And, in fact, the path integral formulation is another way to derive the Schrödinger equation.
Likes Leonardo Bittar
Related to Why do we observe an electron both as a wave and as a particle ?
1. Why do we observe an electron both as a wave and as a particle?
The observation of an electron as both a wave and a particle is a fundamental concept in quantum mechanics. This phenomenon is known as wave-particle duality, and it is a result of the wave-like behavior of electrons at the subatomic level.
2. How can an electron be both a wave and a particle?
Electrons, like all subatomic particles, exhibit both particle-like and wave-like properties. This is because at the subatomic level, particles do not behave like classical objects that have a definite position and velocity. Instead, they behave like waves that can spread out and interfere with each other.
3. What experiments demonstrate the wave-particle duality of electrons?
There are several experiments that demonstrate the wave-particle duality of electrons, including the double-slit experiment and the Davisson-Germer experiment. In these experiments, electrons are shown to exhibit interference patterns, similar to waves, when passing through narrow slits or diffracting off crystals.
4. How does the wave-particle duality of electrons impact our understanding of the physical world?
The wave-particle duality of electrons challenges our classical understanding of the physical world. It suggests that at the subatomic level, particles do not have a definite position or velocity, and instead, their behavior is described by a wave function. This has profound implications for our understanding of matter and the fundamental laws of physics.
5. Can we observe the wave-particle duality of larger objects?
While the wave-particle duality has been observed in small particles like electrons, it is not as apparent in larger objects. This is because the wavelength of larger objects is too small to be detected, and their wave-like behavior is overshadowed by their particle-like behavior. However, some experiments have shown wave-like behavior in larger objects, such as molecules and even viruses.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
