Why does a higher activation energy usually mean a slower reaction?
In summary: So a higher activation energy means a lower rate at a given temperature.In summary, the activation energy of a reaction is related to the rate of the reaction as it determines the fraction of collisions that result in a reaction. A higher activation energy usually means a slower reaction because fewer collisions have enough energy to meet the activation barrier and result in a reaction. However, this is not always the case as the relationship between activation energy and reaction rate can vary depending on the specific chemicals involved.
needingtoknow
160
Doesn't activation energy just tell us whether or not a reaction will take place or not based on if the particles have enough energy to meet the activation barrier? How is it related to the rate of the reaction?
It can also indicate the energy needed to maintain the reaction is also high.
You are right though - a high activation energy need not always indicate a slower reaction rate.
You need to look at why the activation energy is high.
But generally why do people say that reactions with high activation energies tend to be slow?
<puzzled>
Because, generally, but not always, reactions with high activation energies tend to be slow, and "people" tend to be honest about such things.
For specific cases, it is probably possible to find a reaction with a higher activation energy that proceeds faster.
Or, for that matter, a reaction with a lower activation energy that does not proceed very fast at all.
In all cases, where does the energy for the reaction come from?
How is it supplied? Does it all come in one go?
How does the reaction rate depend on the available energy?
The activation energy and the reaction rate are not expected to be independent terms - they both depend on the chemicals involved. Therefore it is not surprising to find some correlation between them.
But we may be confusing terms - the activation energy is the minimum energy the reactant molecules need in order to form the products.
Likes 1 person
See the Arrhenius equation. Rate constants are directly proportional to temperature and inversely proportional to activation energy.
The temperature dependence of a reaction rate constant is usually expressed in terms of its activation energy as follows:
[tex]k=k_∞e^{-E/RT}[/tex]
where E is the activation energy and T is the temperature. The rate constant at very high temperatures k is related to the collision frequency, which is on the same order of magnitude for most combinations of molecules in a gas. So, the higher the activation energy, the lower the rate constant is likely to be at a given temperature.
The rate of reaction depends on how many molecules have energies above the activation rate.
I think that the missing part in your understanding is that the molecules have a distribution, a range of energies, at any given temperature. So is the activation is low (but within the range), the number of molecules with enough energy will be larger.
Likes 1 person
How does the rate of reaction depend on how many molecules have energies above the activation rate? If more molecules have energies above the activation energy doesn't that just mean that more of the substance will react? What does it have to do with rate is my question?
The rate of reaction depends on the rate of molecules of the reactants encountering each other. Something like molecular collisions. Do you understand that the rate of molecule collision in a gas depend on the concentration of molecules?
Then assume than for one reaction 90% of these collisions satisfy the energy condition and for another reaction, with higher reaction energy, in only 1/10 of the collisions the energy will be high enough. Most of the encounters between the molecules of reactant will not result in a reaction.
This is a crude model but offers (i hope) some intuitive understanding of how the rate depends on reaction energy. Of course temperature is an important player too.
You seem to be confusing the activation energy with the heat of reaction. The heat of reaction determines the temperature dependence of the equilibrium constant, which determines how much of a substance reacts. The activation energy determines the temperature dependence of the reaction rate, by determining what fraction of collisions per unit time result in reaction.
Related to Why does a higher activation energy usually mean a slower reaction?
1. Why is activation energy important in a reaction?
The activation energy is the minimum amount of energy required for a chemical reaction to occur. It is important because it determines the rate or speed at which the reaction will occur.
2. What is the relationship between activation energy and reaction rate?
A higher activation energy usually means a slower reaction rate. This is because a higher activation energy means that more energy is needed for the reaction to occur, making it more difficult for the reactants to reach the necessary energy threshold to start the reaction.
3. How does temperature affect activation energy?
Increasing the temperature usually decreases the activation energy, making the reaction happen faster. This is because higher temperatures provide more energy to the reactants, allowing them to overcome the activation energy barrier more easily.
4. Why do some reactions have higher activation energies than others?
The activation energy of a reaction depends on the specific reactants and the mechanism of the reaction. Some reactions may have more complex mechanisms or involve stronger bonds, which require more energy to break and thus have higher activation energies.
5. Can the activation energy of a reaction be changed?
Yes, the activation energy of a reaction can be changed by altering the conditions of the reaction. For example, increasing the temperature or using a catalyst can lower the activation energy and speed up the reaction.
  • Biology and Medical
  • Science Fiction and Fantasy Media
