Why is it said that high current is dangerous? Why not Watts?
In summary, high current is considered dangerous because it can cause heat and electrochemical reactions in tissues, which are both current dependent. While voltage and power also play a role in the analysis of electrical dangers, current is the primary factor. The lethality of an electric shock depends on various variables such as current, duration, pathway, voltage, medical conditions, age, and sex. Alternating current at typical power transmission frequencies has been debated to be more dangerous than direct current, but shock hazards can still occur with voltages as low as 42 volts. High current circuits with low voltages are not typically dangerous, but can be destructive if a short circuit occurs. Even a small voltage with high current can be dangerous if the current passes through a wound
kolleamm
477
44
From what I've read, it says that high current is dangerous.
So my question is
if you had 1v and 10amp, would it be more dangerous than 10v and 1 amp? Shouldn't they be the same?
Why don't we say high watts are dangerous?
Two things that are mostly damaging to tissues are heat and electrochemical reactions, both are current dependent (i2R and i×t). Yes, when trying to analyze details there is no way to ignore voltage and power, but the first approximation can deal with the current only.
Likes kolleamm
You are ignoring how electricity works. 100 volts with the ability to deliver, say 200 milliamps could very well kill you but 5 volts with the ability to deliver a million amps is utterly harmless.
Look up Ohm's Law and consider the resistance of the human body.
Likes jim hardy and kolleamm
Lethality of electric shock is a complicated nonlinear function of biology and physics. Here are some of the factors.
https://en.wikipedia.org/wiki/Electrical_injury said:
Log-log graph of the effect of alternating current Iof duration T passing from left hand to feet as defined in IEC publication 60479-1.[18]
AC-1: imperceptible
AC-2: perceptible but no muscle reaction
AC-3: muscle contraction with reversible effects
AC-4: possible irreversible effects
AC-4.1: up to 5% probability of ventricular fibrillation
AC-4.2: 5-50% probability of fibrillation
AC-4.3: over 50% probability of fibrillation
The lethality of an electric shock is dependent on several variables:
  • Current. The higher the current, the more likely it is lethal. Since current is proportional to voltage when resistance is fixed (ohm's law), high voltage is an indirect risk for producing higher currents.
  • Duration. The longer the duration, the more likely it is lethal—safety switches may limit time of current flow
  • Pathway. If current flows through the heart muscle, it is more likely to be lethal.
  • High voltage (over about 600 volts). In addition to greater current flow, high voltage may cause dielectric breakdown at the skin, thus lowering skin resistance and allowing further increased current flow.
  • Medical implants. Artificial cardiac pacemakers or implantable cardioverter-defibrillators(ICD) are sensitive to very small currents.[19]
  • Pre-existing medical condition. [20]
  • Age and Sex.[21]
Other issues affecting lethality are frequency, which is an issue in causing cardiac arrest or muscular spasms. Very high frequency electric current causes tissue burning, but does not penetrate the body far enough to cause cardiac arrest (see electrosurgery). Also important is the pathway: if the current passes through the chest or head, there is an increased chance of death. From a main circuit or power distribution panel the damage is more likely to be internal, leading to cardiac arrest.[citation needed] Another factor is that cardiac tissue has a chronaxie (response time) of about 3 milliseconds, so electricity at frequencies of higher than about 333 Hz requires more current to cause fibrillation than is required at lower frequencies.
The comparison between the dangers of alternating current at typical power transmission frequences (i.e., 50 or 60 Hz), and direct current has been a subject of debate ever since the War of Currents in the 1880s. Animal experiments conducted during this time suggested that alternating current was about twice as dangerous as direct current per unit of current flow (or per unit of applied voltage).
It is sometimes suggested that human lethality is most common with alternating current at 100–250 volts; however, death has occurred below this range, with supplies as low as 42 volts.[22] Assuming a steady current flow (as opposed to a shock from a capacitor or from static electricity), shocks above 2,700 volts are often fatal, with those above 11,000 volts being usually fatal, though exceptional cases have been noted. According to a Guinness Book of World Records comic, seventeen-year-old Brian Latasa survived a 230,000 volt shock on the tower of an ultra-high voltage line in Griffith Park, Los Angeles on November 9, 1967.[23] A news report of the event stated that he was "jolted through the air, and landed across the line", and though rescued by firemen, he suffered burns over 40% of his body and was completely paralyzed except for his eyelids.[24]
Likes pinball1970
Generally we do not consider high current to be dangerous because potentials under 30V are unlikely to induce a biologically significant current across the resistance of human skin and tissues (see ohms law). Think about how you don't get a shock touching the terminals of a 9V battery to your hand, but it can give a shock to your tongue where the resistance of the wet tissue is much lower.
While high current circuits with low voltages are generally not an electrical shock hazard, they have the potential to send large currents through other unintended routes. If you had a battery of say ten 12V car batteries arranged in parallel it would still be 12V and not shock you. But if you dropped a screwdriver across the terminals you could source 1000A across the 0.1ohm screwdriver for a power P=I^2*V = 100kW. The wiring in the circuit and the screwdriver won't last very long at this power and it will probably melt or vaporize in your face resulting in flash burns. This is the main reason to use caution around high current circuitry; short circuits can be destructive.
Just to add to what was written above. Even a small voltage (tens of volts) and high current can be dangerous if the current somehow makes it way into your body.
You skin is a -as was pointed out above- a pretty good insulator (when dry) but if you make contact via a wound (something penetrates the skin) or say in your mouth things become more dangerous.
Now, this might sound far fetched but if you think about the situations when an accident could happen it becomes fairly obvious that this can be a major issue; there are plenty of sharp edges in electrical machinery (not to mention sharp copper wires).
I do a fair amount of work with low-voltage (a few volts). high current equipment (100A) and I always make a point of treating every situation AS IF the terminals are high voltage for this reason (even though it would be perfectly safe to touch them with dry hands).
Likes anorlunda
Rule of thumb is, "Voltage shocks, Current kills".
As the above posts explain, it is a bit more complicated, potentially a lot more lethal...
Due Care, Please ??
FWIW, when my BIL started as an electrical apprentice, his first job was to scrape some charred remnants of his careless predecessor off a big pump's 440 volt switch-gear. As BIL said, the lingering smell put him off bacon sarnies for several weeks...
Likes anorlunda
I watched a YouTube video and the guy explains that basically you need a high voltage in order for a dangerous amount of current to hurt you. Is that right?
You already had several answers in this thread that said no; it depends on circumstances. It also depends on what "high" means.
Also, please don't say "guy on youtube" without giving a link.
Likes jim hardy
How high is up?
Likes jim hardy
Here is the video
I said a high voltage in my post because every situation is different
kolleamm said:
Here is the video
I’ve seen this video - he explains it well. You can’t say ‘it’s hitting the ground that kills you, not the falling’, because the two are linked; one causes the other. Voltage and current are linked too. You need a certain voltage to drive significant current through your insulating skin layer. The wattage you speak of is a various amalgam of voltage, current, time and resistance, and the individual details that are so crucial are lost:
My welder can supply 200A at about 20V, or 4 kW of power, which is a tremendous amount. But the voltage is too low to drive that current through me. See how detail is lost when considering shock hazards through power alone? Further to this, if I’m wearing a wedding ring and accidentally short it across the output, I’ll lose a finger.
An electric fence energiser is carefully designed not to kill, but a hand-to-hand shock delivered to an individual fitted with a pacemaker might just kill. So it’s not only the source of electrical power that has to be analysed - it’s the ‘shockee’.
Likes jim hardy
kolleamm said:
Here is the video
Indeed he explains it well
It's generally accepted that around twenty milliamps through your chest can be fatal.
https://www.ncbi.nlm.nih.gov/pmc/articles/PMC2763825/
it takes quite a bit of voltage to push that much current through dry skin
but not wet skin., as you saw on that guy's tongue.
That's why electrical code doesn't want outlets within reach of a bathtub or shower.
It's energy that's dangerous and energy is product of volts and current.
The 230 volt feed to a house is capable of this
it's not only electrical energy that's dangerous.
I'm more afraid of speed and height .
Good points all.
old jim
Related to Why is it said that high current is dangerous? Why not Watts?
1. Why is high current considered dangerous?
High current can be dangerous because it can cause severe electric shocks, which can result in burns, organ damage, and even death. The higher the current, the more intense the shock and the greater the risk of injury.
2. Why isn't the wattage of an electrical current used to measure danger?
Wattage is a measure of power, while current is a measure of the flow of electricity. While wattage can indicate the potential for danger, it does not accurately reflect the actual amount of electricity flowing through a circuit. High wattage devices, such as light bulbs, can still have relatively low currents and pose less of a danger compared to low wattage devices with higher currents.
3. Can low current also be dangerous?
Yes, low current can also be dangerous. It is not the level of current alone that determines the danger, but rather the amount of current that passes through the body and how long it is applied. Even a low current can cause damage if it passes through vital organs or if it is applied for a longer period of time.
4. How does the human body react to high current?
The human body is a good conductor of electricity, so when high current passes through it, it can disrupt the normal functioning of the body's cells and tissues. This can lead to electric shocks, burns, and damage to organs and nerves. In extreme cases, it can also cause cardiac arrest and death.
5. Are there any other factors that make high current dangerous?
Aside from the potential for electric shocks and tissue damage, high current can also cause fires if it overloads the circuit and generates excessive heat. It can also damage electrical equipment and cause power outages. Additionally, high current can be a sign of a malfunctioning or faulty electrical system, which can pose a danger to anyone using it.
  • Electrical Engineering
