Will a conveyor belt push a hovercraft along?
In summary, two friends had a debate about whether a hovercraft hovering over a moving conveyor belt would move in the direction of the belt or remain stationary. They discussed the hypothetical situation using mathematical models and constraints. One friend argued that the conveyor belt would not affect the hovercraft, while the other believed that there would be some slight drag. They also considered the possibility of a video game hoverboard using magnetic or antigravity technology. Finally, they questioned whether moving the ground would also move the hovercraft and concluded that the craft would only be affected if the movement was slow and steady.
Izzard
Hi. This forum seems to be just what I'm looking for!
My friend and I have just been having one of those drawn out debates over a hypothetical physics model and I guess (although it was an animated discussion) neither of us was 100% convinced we were correct what we were saying. We were both pretty adamant the other person was wrong though ;)
The basic hypothetical situation is a hovercraft hovering over a moving conveyor belt. Does the hovercraft move in the direction of the belt, or does it remain stationary (relative to everything else in the universe)?
We tried thinking of it as a mathematically perfect model. Or at least with these constraints: The workings of the ‘hovercraft’ are unspecified, but you can assume it pushes air downwards from a skirt and is completely stable.. ..on unmoving ground it would appear completely stationary. The conveyor belt is a huge (maybe even infinite) plane, moving at a constant velocity. The ‘craft’ has just magically popped into existence above it at a stable altitude. Actually, feel free to toy around with the restraints all you like if you have any comment to make :)
This came about because my friend was playing a console game where his character, riding a ‘hoverboard’ glides onto a conveyor belt for a few moments. The character is pushed along as though he had stepped onto the belt. Obviously wrong. My friend said that the belt should not affect the board at all. I said I thought it would, a bit, after a fashion. He said it never would.
Well my thinking was that if the board is *hovering* over the belt then it is using thrust to overcome the effect of gravity on its mass. I.e. there are forces acting directly upwards and directly downwards which are equal and opposite, so the hoverboard remains in place. I thought that this made the two things connected, albeit loosely (the conveyor belt isn’t frictionless, after all), so eventually the relentless motion of the belt would be transferred through the column of air to the board. Now my brain hurts. Please help!
Originally posted by Izzard
Please help!
Draw a free-body diagram of the stationary hovercraft. The only force on it, ideally, is its lift.
Now turn on the conveyor belt. What happens? In a vacuum, nothing would happen at all. The two objects (belt and hovercraft) are not touching, and therefore the hovercraft stays exactly where it is.
In the real world, the conveyor belt exerts some friction on the air above it, and the air between the belt and hovercraft moves slightly along with the belt. The air then pushes on the hovercraft, and exerts a teeny-tiny force on it. It's essentially the drag force caused by the "wind" which is (only slightly) moving along with the conveyor. The force is negligible for a reasonably massive hovercraft, and probably completely immeasurable in practice.
You can safely say that your hovercraft would stay exactly as it is, regardless of what the conveyor belt is doing under it.
- Warren
- Warren
I dissagree (though I am not "adamant that [you are] wrong"!). Althought hovercraft have a very low drag coefficient with the ground, it is not zero. The air trapped under the skirt is escaping around the edges. As it escapes, it interacts with whatever surface it is "hovering" itself above. The air trying to escape out the leading edge of the skirt (or the edge that is facing in the direction from which the conveyer surface is aproaching) will encounter slightly more resistance when trying to escape. Likewise, the air on the trailing edge (in the direction the belt is moving towards) will secape with less resistance. So the hovercraft will experience some slight drag in the direction of surface movement.
Of course, your friends "hoverboard" being of video-game design, it might be hovering magnetically, or antigravitationally, ni which case the specifics of the mechanism would make all the difference.
I believe I explicitly said that!
- Warren
Thank you for these comments, you two.
Right! So is there a situation where you can be fairly sure that moving the 'ground' will also move the hovercraft?
For example, if I have a 'large', traditional hovercraft, big enough to carry a few people, hovering over a wooden area which is, say, 100m x 100m and no part of the craft is touching that surface. If we then slowly push the wooden area along, can we affect the craft enough to move it along too? If we move the wood too briefly and or/quickly, inertia negates movement of the craft (tablecloth/crockery style). Perhaps moving it too slowly allows the wood to creep past underneath without moving the hovercraft...? Is there a sweet spot where the speed of the 'conveyor' would eventually move the hovercraft or will the other forces in the real world always prevent the craft moving by an appreciable amount?
- Warren
I'm sorry chroot, I thought you were talking only about the ambient air in the room (especially that right close to the conveyor) being moved along, and that would move the hovercraft. What then did you mean by, "In a vacuum, nothing would happen at all"?
Izzard, in the scenario you propose, the hovercraft would move when the board is moved, and in the same direction, too. It just wouldn't move very much. I can't think of a stuation ni which the force you apply to the board would be transferred to the craft with enough efficiency so that the two become synchronised, but I'll let my subconscious gnaw at it for a while and see what it regurgitates.
Well, I guess you're right LURCH -- a hovercraft in a vacuum wouldn't even make much sense!
The hovercraft will move along with the underlying surface best when it's moved more slowly. That's why you're not arriving at a clear answer, LURCH: the only time when the hovercraft will have the same velocity as the underlying surface is when the underlying surface is not moving!
- Warren
I'm delighted it's making other people have to thing hard too! Very interesting.
- Warren
Now that's the question that's puzzling me; exactly what would a hovercraft do in a vacuum? Obviously, ducted fans pointed inward would give no lift at all. The air for the "air cusion" would have to be supplied by a tank of compressed gas of some sort being slowly released into the hoverskirt. Or maybe a heating coil is boiling water under there, or a hose running in from outside the vacuum chamber supplies the air. Either way, what would the vehicles behavioral characteristics be?
On the one hand, I can see that zero pressure outside the hoverskirt would mean that you need very little air inside to keep it inflated. But on the other hand, it would also seem that having zero pressure outside would mean that the air would get sucked out around the bottom faster than you could replace it. I wonder which would be the dominant factor?
My own hunch is that any air you release/expand will just go towards filling the void and that the craft can't rise until there is a certain pressure of air in the 'room' for it to rise in. Don't know what that pressure threshold would be. ..maybe a function of the mass of the aircraft? Anybody got a bell jar, pump and tiny model hovercraft? :)
It also depends on the belt.
If the belt is somewhat strechy, then you could get a situation where the hovercraft makes a dent in the belt which would allow for significantly stronger interaction between the sub and the hovercraft.
If the belt is made of mesh then the hovercraft would come to rest on it, and be affected by the belt's movement.
Those are both very good points! :smile:
- Warren
OK, just to be irritating - a stretchy belt would cause the craft to move in the opposite direction of the belt.
Call the end from which the belt emerges the front, and the other end the back.
The whole area of the belt under the craft is depressed. As the belt exits from the front, it remains depressed for some brief period of time. The area at the back of the craft is less depressed as it begins passing under the craft. The larger gap at the front allows more air to escape. Conservation of momentum demands that the craft move in the opposite direction of the belt.
Njorl
Note that I didn't claim that the dent would cause the hovercraft to move forward. ;)
But there would be more pressure on the side where the belt is closer to the hovercraft which indicate that the hovercraft should move with the belt.
Ugh. This would be a *really* ugly problem to do on paper. Fluid dynamics for the air, the streching of the belt in two dimensions, and they're all moving. Also not the kind of experiment that's likely to get you funding.
the hovercraft is displacing air beneath it... kind of like the bernouli effect but not exactly...
no, the hovercraft will stay stationary with something moving under it... that's how they can float on water... the hovercraft makes an air pocket of sorts... which cushiones the craft from the ground, but because the actual air isn't moving with the conveyor belt, the hovercraft wouldn't move... or if you want to get really detailed, yes, the hoverraft will move on the coonveyor belt, but it will be so minute that it won't be noticeable...
now if the skirt of the hovercraft is TOUCHING the conveyor belt... yeah, that would make it move...
but the reason it does that in that game is because they tried to take a shortcut and leave some physics stuff out, so they made the model higher off the ground... which means if you put the hovercraft on a conveyor belt, it will move with it... simple solution to making a hovercraft...
if you think about th3 fundamental parts... the air being pushed downwards by the hovercraft, the hovercraft itself, and the conveyor... the air being pushed down doesn't have any treal physical link between the hover craft and the conveyor belt... its simple, no, it shouldn't be moving
Related to Will a conveyor belt push a hovercraft along?
1. How does a conveyor belt push a hovercraft along?
A conveyor belt works by using rotating belts to move objects from one location to another. When placed underneath a hovercraft, the conveyor belt's movement creates a cushion of air between the hovercraft and the belt, allowing the hovercraft to glide along the belt's surface.
2. Can a conveyor belt push a hovercraft in any direction?
Yes, a conveyor belt can push a hovercraft in any direction as long as the belt is moving in that direction. The hovercraft will follow the movement of the belt and can be steered using traditional hovercraft controls.
3. What is the maximum weight limit for a hovercraft to be pushed by a conveyor belt?
The weight limit for a hovercraft to be pushed by a conveyor belt will depend on the strength and durability of the conveyor belt. Most industrial conveyor belts can handle heavy loads, so as long as the hovercraft does not exceed the weight limit of the belt, it can be pushed along.
4. Can a conveyor belt push a hovercraft over rough or uneven surfaces?
It is not recommended to use a conveyor belt to push a hovercraft over rough or uneven surfaces. The belt's movement may become disrupted, causing the hovercraft to lose its cushion of air and potentially damaging the belt.
5. Is a conveyor belt a safe way to move a hovercraft?
A conveyor belt can be a safe and efficient way to move a hovercraft, as long as proper safety precautions are taken. It is important to ensure that the belt is in good condition and that the hovercraft is securely attached to the belt to prevent accidents.
  • Other Physics Topics
11K
  • Science Fiction and Fantasy Media
10K
