Will the spoon fall on the earth?
  • Thread starter Sya gars
  • Tags
    Earth Fall
In summary, if the satellite is orbiting the Earth and there is minimal friction, the spoon released by the astronaut will stay in orbit. However, if there is friction present, the spoon will eventually slow down and fall to Earth, but will not survive the journey due to heat and destruction caused by the atmosphere.
Sya gars
An astronaut in the satellite releases a spoon out of satellite in the space. Will the spoon fall on the earth?
This depends much on the state of the satellite. If the satellite is orbiting the Earth then the spoon -as it is dropped from the satellite- will have sufficient velocity to stay also in orbit. Of course it depends also whether you are considering or not zero friction. If you consider realistic conditions in which there is a -minimal- friction also in outer space, then the spoon will slow down until it eventually falls on the earth. Anyway while falling through the atmosphere the friction will heat it up enough to melt it and destroy it, so it will not actually arrive on the Earth surface...
Related to Will the spoon fall on the earth?
1. Will the spoon ever fall off the earth?
No, the spoon will not fall off the earth. The earth's gravitational pull keeps objects, including the spoon, on its surface.
2. How does the spoon stay on the earth?
The spoon stays on the earth due to the force of gravity. This force is created by the mass of the earth and the mass of the spoon attracting each other.
3. Can the spoon fall towards the sky?
No, the spoon cannot fall towards the sky. Objects are always pulled towards the center of the earth, so the spoon will always fall towards the ground.
4. What factors affect the spoon's fall on earth?
The main factor that affects the spoon's fall on earth is gravity. Additionally, air resistance, the weight and shape of the spoon, and any other forces acting on the spoon can also affect its fall.
5. Will the spoon fall at the same rate as other objects on earth?
Yes, the spoon will fall at the same rate as other objects on earth. This is because all objects on earth experience the same gravitational acceleration, regardless of their mass or size.
