Wormholes & Arbitary High Energy: Exploring Possibilities
In summary, this article discusses the Casimir effect and its potential for creating regions of space with a higher stress-energy tensor than mass density component. There is some uncertainty around whether or not this is possible in reality, and further research is needed to determine if it is even possible.
Christofer Br
51
Could we hypothetically use it to create a region of space with the magnitude of the stress component of stress energy tensor greater than magnitude of mass denisty component?
No.
To make it worse, all solutions (I know of) need negative energy densities, and we have no idea if these can exist at all.
mfb said:
No.
Not speaking to the feasibility of wormholes, per se, but doesn't the Casimir effect count as experimental proof of the possibility for negative energy densities? Or am I missing something?
Likes Christofer Br
No, in classical General Relativity you need a negative energy density to stabilize wormholes. See for instance the Moris-Thorne-Yurtsever wormhole paper, https://authors.library.caltech.edu/9262/1/MORprl88.pdf, "Wormholes, time machines, and the weak energy condition".
The B-level "explanation" of this is that adding more positive energy just increases the gravity, causing the throat of the wormhole to collapse, rather than keeping it open.
If you can find a copy at the library, "Lorentzian Wormholes" by Visser is a good source that's not too technical.
It is just an attractive force between two things of (high) positive energy density.
The casimir force violates the weak energy condition, so it's a promising candidate, but I'm not sure if it violates the average weak energy condition, which is what you really need to stabilize a wormhole according to the Morris-Thorne-Yurstserver paper.
To possibly oversimplify, the plates of known conductorshave a positive energy density, the space between two conductive plates can have a negative enregy density due to some strange quantum weirdness, the supression of certain frequencies in the quantum vacuum.
To violate the average weak energy condition, as I understand it at least, the negative energy between the plates has to be greater in magnitude than the positive energy density of the plates themselves.
Likes ComplexVar89
I think a better way to put this is that the energy of the vacuum between the plates is slightly lower than the energy of the vacuum outside the plates. Whether this means the vacuum inside the plates has "negative energy" depends on how you pick the zero point of energy, which in the absence of gravity, i.e., in flat spacetime, is an arbitrary choice.
The problem is that, if we are talking about trying to stabilize a wormhole, we aren't in flat spacetime. That complicates the whole issue; see below.
Strictly speaking, the quantum vacuum in general violates the weak energy condition. That's because the effective stress-energy tensor that you get when you try to calculate one for the quantum vacuum looks like a cosmological constant, and a cosmological constant violates the weak energy condition.
The problem is that, if we "naively" calculate the stress-energy tensor of the quantum vacuum, we find that it not only violates the weak energy condition, but its energy density is so large--by something like 120 orders of magnitude--that it produces a huge spacetime curvature that we do not actually observe. So clearly we are missing something basic about what the "actual" energy of the quantum vacuum is.
If we assume that, whatever the something basic is that we're missing, it will turn out to assign exactly zero energy density to the quantum vacuum in flat spacetime, then that would make the energy density between a pair of conducting plates slightly negative. This corresponds to a slightly negative cosmological constant, which produces attractive gravity, hence the tiny attractive force between the plates. This is one way to heuristically understand the Casimir force. (Note that on this view, spacetime between the plates is not flat, but slightly curved--basically it's a small piece of anti-de Sitter spacetime.)
To check whether the average weak energy condition is violated, as you note, we have to take into account the stress-energy of the plates. In real Casimir experiments that we have conducted, of course, the plates have a huge positive energy density that swamps any negative contribution from the quantum vacuum inside the plates. But that does not mean that any possible configuration of this sort must have that property; the Morris-Thorne-Yurtsever paper basically tries to investigate the implications of a "Casimir" configuration with plates whose energy density is small enough that the AWEC is violated, so that a wormhole can be held open. Their conclusion appears to me to be that we don't know enough about quantum field theory to know whether such a configuration is possible or not.
Likes ComplexVar89
Related to Wormholes & Arbitary High Energy: Exploring Possibilities
1. What is a wormhole?
A wormhole is a hypothetical tunnel or bridge that connects two distant points in space-time. It is a theoretical concept in physics that suggests the existence of a shortcut through space-time, allowing for faster-than-light travel.
2. Can wormholes really exist?
There is currently no direct evidence for the existence of wormholes. They are purely theoretical and have not been observed or confirmed by scientific experiments. However, some equations in Einstein's theory of general relativity suggest that wormholes could be possible.
3. How would one travel through a wormhole?
Theoretically, one would enter a wormhole through one end and emerge from the other end at a distant point in space-time. However, the extreme gravitational forces and high energy requirements for sustaining a wormhole make it highly unlikely for humans to ever be able to travel through one.
4. Can wormholes be used for time travel?
Some theories suggest that wormholes could potentially be used to travel through time. However, this is still highly speculative and there are many paradoxes and limitations that would need to be addressed for time travel to be possible through a wormhole.
5. How are scientists studying wormholes?
Scientists study wormholes through mathematical equations and simulations. They also search for any indirect evidence of their existence in astronomical observations and experiments. However, due to the complexity and limitations of current technology, studying wormholes remains a challenging task for scientists.
