Writing fiction, steam power, hydrogen internal combustion engine
In summary: I think maybe the late 70s early 80s? After the Chernobyl disaster where it was suggested that we might want to switch to nuclear power? Yes, after the Chernobyl disaster nuclear cars were proposed as a way to avoid the environmental impact of gasoline cars.
lesah
Question: is it possible to have any of the following -
1. Steam engine in a car
2. A steam internal combustion engine
3. A hydrogen internal combustion engine
Background info
Hi all, I am working on a fiction short story for fun. It is set in a parallel universe so history and a few other things are different.
It's a mix of steampunk and present day settings and technology
It doesn't have to be extremely accurate. I'm looking more at if these things are possible at all.
I appreciate any help you could provide, should you have the time.
Thank you.
Steam engine car, the Stanley Motor Carriage Company built Stanley 'Steamers' from 1902 - 1924
The BMW Hydrogen 7 is car that can replace gasoline with hydrogen. I think that would count as a hydrogen internal combustion engine.
Thanks for the replies.
Ryan,
I did do research on it. But I wasn't able to find out the specifics. I know that they had steam cars and there are hydrogen cars in production now. I was wondering if it was possible to have, specifically, a steam internal combustion engine, not the boiler, as well as if it was possible to have an internal combustion engine that burned hydrogen, rather than using electrolysis.
I'm not looking at if it's practical or not, just if those specific configurations are possible.
Thanks!
As it says in the hydrogen vehicle link it is possible to make a combustion engine that works with one. As for using a combustion engine with steam I'm fairly certain that would be pointless, a combustion engine already can provide energy to move. If you instead pump that as heat into a complicated steam set up you're making the whole set up massively less efficient.
# 2 is not practical as Ryan points out. However, you might consider a steam turbine engine if you have a small nuclear core that generates lots of heat with fuel rods on a small scale. Not sure I'd buy one, but in the future, with a new radiation safe material called Bee-eS-Shield-ooniam, it would then be practical.
A steam internal combustion engine is an oxymoron, an internal combustion engine heats the working fluid inside the engine, cylinders for recip engines combustion chamber for gas turbines, a steam engine heats the working fluid in a boiler and is an external combustion engine. However you can inject water into the air stream of IC engines to improve the power output or to control combustion temperatures and emissions.
Thanks for the additional information, everyone.
I guess I missed the combustion part while researching hydrogen. Thanks.
CalcNerd,
Hey, that's a good idea. Hadn't thought of putting a steam turbine in a car or even a very small nuclear powerplant. - In engineering terms, the nuke plant would be the prime mover, correct? And the steam turb the secondary mover?
It's an alternate world, so it doesn't have to be practical. Even so, I'll probably have to insinuate that there may be ever so slightly differences in the laws of nature, disregarding the fact that that would make life as we know it impossible. Hence, speculative fiction.
Jobrag,
I can sort of see how that would be redundant, but I still don't understand engines/turbines and the uber basics of engineering enough yet. Is it because steam power and combustion do the same step in the process of making work, that you can't really combine them?
(I'm a little slow on the uptake; not being facetious. Sometimes quite slow.)
Or is it b/c the steam needs internal combustion in a furnace anyway, that it would be a total waste to combine ICE w/ steam?
Thanks again, all. I appreciate the help.
I'm not an automotive engineer but I'm fairly certain the following is true:
The way any car works is to turn the energy stored in its fuel into motion, specifically the wheels turning. A steam car works by burning fuel (like oil), the heat from that is used to boil water which evaporates as steam. That steam is forced out of the boiler (by the pressure of evaporating) and pushes on a mechanism as it does so which spins the wheel.
An internal combustion engine gets rid of the whole steam set up and instead the burning of the fuel itself drives a mechanism that spins a wheel. If you were to combine them you'd end up with a system that burns fuel to spin a mechanism to heat water to spin a mechanism. No step is perfectly efficient so you lose energy at each stage, not to mention the extra weight.
RE nuclear cars that's been proposed for a while but no prototype has ever been built: http://en.wikipedia.org/wiki/Ford_Nucleon
Okay . . now it makes sense. Thanks. Appreciate it. Yeah, that wouldn't even work for a fictional world.
Never heard the concept of nuclear cars. Cool! I'll look into that, as it may work for this story.
Related to Writing fiction, steam power, hydrogen internal combustion engine
1. What is the difference between writing fiction and non-fiction?
Writing fiction involves creating a story that is not based on real events or people, while non-fiction writing is based on factual information and real events. Fiction writers use their imagination to create characters, settings, and plots, while non-fiction writers use research and evidence to support their writing.
2. How does steam power work?
Steam power is based on the principle of converting heat energy into mechanical energy. Water is heated in a boiler to produce steam, which is then directed through pipes to a turbine or engine. The steam's pressure turns the turbine, which in turn drives a generator to produce electricity or powers a mechanical device.
3. What is the difference between an internal combustion engine and a hydrogen internal combustion engine?
An internal combustion engine uses a mixture of fuel and air that is ignited by a spark to produce energy. A hydrogen internal combustion engine, on the other hand, uses hydrogen gas as the fuel source. The combustion of hydrogen and air produces energy, with water being the only byproduct, making it a more environmentally friendly option.
4. What are the benefits of using a hydrogen internal combustion engine?
Hydrogen internal combustion engines have several benefits, including lower emissions, as they do not produce harmful pollutants like traditional gasoline or diesel engines. They also have a higher energy efficiency, meaning they can travel farther on the same amount of fuel. Additionally, hydrogen is a renewable resource, making it a more sustainable option for transportation.
5. Is it possible to incorporate steam power and a hydrogen internal combustion engine in a fictional story?
Yes, it is possible to incorporate both steam power and a hydrogen internal combustion engine into a fictional story. Many science fiction stories use advanced technologies and alternative energy sources, making it a perfect fit for a futuristic or alternate world setting. The author can also use these technologies to drive the plot and add unique elements to their story.
  • General Engineering
