Adding sugar to water; water level doesn't go back to the original volume
In summary, the experiment is missing a final volume larger than 50 mL but smaller than 55 mL, with a ballpark estimate of above 53 mL. Volumes of solutions are not additive, and the final volume is typically not equal to the sum of volumes. The water level settling at 51 mL after 24 hours could be due to evaporation. With a bulk density of sugar at around 0.8-0.9 g/mL, adding 5 mL of sugar to 50 mL of 1 g/mL water results in a 9.1% w/w sucrose solution with a density of 1.0344 g/mL. Accounting for thermal expansion/contraction, the final volume of the solution is estimated
musicgold
304
This is not a homework problem. I am doing a Chemistry experiment with my kid. As per the booklet, we have added 5ml sugar to a glass with 50ml of hot water. The booklet says that the water level should go back to 50ml after the sugar is dissolved.
It has been 2 hours since we dissolved the sugar, but the water level is still close to 54ml. When the sugar was added the water level increased from 50 to 55ml.
What are we missing in this experiment?
Thanks
Booklet is wrong, final volume should be larger than 50 mL, but smaller than 55 mL (I would expect something above 53 mL, 54 sounds in a right ballpark).
Volumes of solutions are not additive (the final volume is typically not equal to sum of volumes, unless you mix same with same). Same holds when dissolving solids in any solvent.
Likes berkeman, hmmm27 and musicgold
Just a follow up, after 24 hours, the water level settled at 51 mL. Could we have lost some water because of evaporation?
Most likely.
Bulk density of sugar is around 0.8-0.9 g/mL. Let's make it 1g/mL for brevity. You took 5 mL, so around 5 grams.
You started with 50 mL of water of 1 g/mL density. That means 50 g of water. After adding sugar you had 55 g of the solution. 5 g of the sucrose in 55 g of the solution means 9.1 % w/w. Sucrose solution density tables say such a solution has a density of 1.0344 g/mL. 55 g of the solution of 1.0344 g/mL density has a volume of 53.2 mL.
Give or take half a mL here and there, as your numbers are approximate.
Likes jim mcnamara
Did you measure 50 mL of HOT WATER or did you start with 50 mL of RT water, heat it and then dissolve the sugar?
If the former, consider thermal expansion/contraction as well.
Related to Adding sugar to water; water level doesn't go back to the original volume
1. Why does adding sugar to water cause the water level to stay higher?
When sugar is added to water, it dissolves and forms a solution. This solution has a greater volume than the original water, causing the water level to appear higher. This is because the sugar molecules take up space in between the water molecules, increasing the overall volume of the solution.
2. Does the amount of sugar added affect the change in water level?
Yes, the amount of sugar added directly affects the change in water level. The more sugar that is added, the greater the increase in volume of the solution and the higher the water level will appear.
3. Will the water level eventually return to its original volume if left undisturbed?
No, the water level will not return to its original volume if left undisturbed. The sugar molecules will remain dissolved in the water, keeping the overall volume of the solution higher than the original water level.
4. Can the water level be lowered again after sugar has been added?
Yes, the water level can be lowered again by either adding more water to the solution or by allowing some of the water to evaporate. This will decrease the concentration of sugar in the solution and lower the overall volume.
5. Does the temperature of the water affect the change in water level when sugar is added?
Yes, the temperature of the water can affect the change in water level when sugar is added. Higher temperatures can increase the solubility of sugar, leading to a greater increase in volume and a higher water level. On the other hand, colder temperatures may result in less sugar dissolving and a smaller change in water level.
  • Other Physics Topics
