Apps of nuclear physics in medicine
In summary: With this more complex logic you can build a system that can decide if two events are from the same source or not.
anju
how images of body organisms are are formed in positron emission tomography...?
You're asking how PET scaner work?
Basically, you give a radioactive dye to someone (injected or ingested depending on what you want to image). The radioactive die emits positrons (anti-electrons) as it decays. The positrons slow down and pair up with an electron and the two annihilate each other, giving off two photons with 511 keV going in opposite directions. Some of these photons make it out of the body and get captured by detectors.
In order to form an image, you look for times when detectors on opposite sides of someone go off at the same time. You then draw a line between them. Keep doing this for thousands or millions of events. The number of lines that pass through an area tell you roughly how much dye was there in 3D.
You can do neat things like attach the radioactive dye to sugar molecules, and the body brings it to places to be metabolized. Thus you can 'see' metabolic activity, which can indicate problems like tumors.
such coincidence identification is carried out by a coincidence electronic ckt .it is found that some small animal PET scanners offers possibility of recording individual single events .what's its advantages...?
advantages and working principle of FPGA based digital coincidence engines...?
I'm not an expert on imaging technology, but I'll give it a shot.
In a PET scanner you want to produce an image from the pair of 511 keV photons going in opposite directions. The reason for this is it gives you two point (detectors) to draw a line between which represent possible locations for the source. Its pretty unlikely that two 511 keV photons arrive at opposite detectors at roughly the same time if they are not from the same source/event. Therefore you can use a coincidence window to identify event pairs.
If you wanted to be fancier, you could use other methods for identifying the pairs. Light travels at roughly 1 foot per nanosecond. Thus, if you knew the exact time the photon arrived at both detectors, you could figure out where on the line between them the light originated. However, nanosecond level timing is exceptionally difficult requiring very specialized electronics and accounting for the time taken by the physical processes (such as charge collection and amplification).
If you record every event instead of just coincidence pairs, you could try to use other methods to produce an image. For example, you could include the probability that particles are attenuated by the body. These methods require MUCH more computer power, but in theory can extract more information from the scan.
FPGAs is just a fancy high speed logic/electronics kits. For example you can use more complicated logic to decide if something is from the same event. For example, you don't need to assume the detectors are exactly opposite each other (because if the photons were produced off-center the line would be a cord instead of a diameter).
Nuclear physics plays a crucial role in modern medicine, particularly in the field of medical imaging. One of the most widely used applications of nuclear physics in medicine is in positron emission tomography (PET) imaging.
PET imaging uses positron-emitting radioactive isotopes, which are produced in nuclear reactors or particle accelerators, to image the metabolic activity of cells in the body. These isotopes are injected into the patient and then detected by a PET scanner, which creates detailed images of the body's internal structures and functions.
The images produced by PET scans are formed through the process of annihilation, in which a positron collides with an electron, resulting in the release of two high-energy photons in opposite directions. These photons are then detected by the PET scanner and used to create an image of the body's metabolic activity.
The ability to visualize and measure the metabolic activity of cells in the body has revolutionized the diagnosis and treatment of various diseases, including cancer, neurological disorders, and cardiovascular diseases. PET imaging has also been used in drug development and clinical trials, allowing researchers to track the effectiveness of new treatments and medications.
In conclusion, the use of nuclear physics in PET imaging has greatly advanced the field of medicine and has had a significant impact on patient care and treatment. It is a prime example of how scientific advancements can be applied to improve the health and well-being of individuals.
Related to Apps of nuclear physics in medicine
1. How are nuclear physics used in medical imaging?
Nuclear physics is used in medical imaging through techniques such as positron emission tomography (PET) and single-photon emission computed tomography (SPECT). These techniques involve the use of radioactive isotopes, which emit gamma rays that are detected by specialized cameras. The data from these cameras is then processed to create detailed images of the body's internal structures, helping doctors diagnose and treat various diseases.
2. What is the role of nuclear physics in cancer treatment?
Nuclear physics plays a crucial role in cancer treatment through techniques such as radiation therapy. In this method, high-energy radiation is used to destroy cancer cells and shrink tumors. The radiation is produced by accelerated particles, such as protons or gamma rays, which are generated by nuclear reactions. Nuclear physics also helps in the development of targeted therapies, where radioactive substances are used to specifically target cancer cells while minimizing damage to healthy tissues.
3. How do nuclear physics help in the production of medical isotopes?
Nuclear physics is essential in the production of medical isotopes, which are used in various diagnostic and therapeutic procedures. These isotopes are created through nuclear reactions, where a stable isotope is bombarded with neutrons or other particles to form a radioactive isotope. This process is carefully controlled to ensure the safety and purity of the produced isotopes, which are then used in medical procedures such as PET scans and radiotherapy.
4. What is the significance of nuclear physics in nuclear medicine research?
Nuclear physics plays a significant role in nuclear medicine research, as it helps in the development and improvement of various medical techniques and technologies. Researchers in this field use nuclear physics principles to study the behavior of atoms and particles in the body, which aids in understanding diseases and developing new treatments. Nuclear physics also plays a crucial role in the development of new imaging and therapeutic agents, which can help diagnose and treat diseases more effectively.
5. How are nuclear physics techniques used in studying the human body's functions?
Nuclear physics techniques, such as nuclear magnetic resonance (NMR) and positron emission tomography (PET), are widely used in studying the human body's functions. NMR uses powerful magnets and radio waves to produce detailed images of the body's tissues and organs, helping doctors diagnose various conditions. PET, on the other hand, uses radioactive tracers to study metabolic processes in the body, providing valuable information about organ function and disease progression. These techniques are essential in understanding and monitoring the body's functions and detecting abnormalities.
  • Nuclear Engineering
  • STEM Academic Advising
