CAMAC crate electronics - Where were/are they used?
  • Thread starter Christoffer B
  • Tags
    Electronics
In summary, The CAMAC standard of nuclear electronics was a digital version of NIM and was used in various experimental setups. It was not as common as NIM, but still had significant usage in the past. It has since been replaced by newer standards such as VMEbus. The Rutherford Laboratory in the UK and the Harwell Laboratory had their own modular systems similar to CAMAC. Today, there are still some companies producing CAMAC modules and it is still being used in some older detector arrays and accelerators. It may be possible to acquire CAMAC crates and modules from main nuclear physics labs and facilities that are no longer using them.
Christoffer B
TL;DR Summary
Looking into the history of CAMAC crate electronics for physics/high energy setups.
How common were/are they? In what setups were they used?
Hi!
I've done some research on the CAMAC standard of nuclear electronics - "It's like NIM but digital" - as I would like to acquire a bin and some modules for historic and scientific curiosity.
I have never worked with the system, and I would like to get in touch with somebody who has. How common were they ever? And in what experimental setups were they used?
There is a short handbook 'A CAMAC Primer' written and distributed at LANL, which can be found online, but It's not the most helpful text.
Were Europe favoring VMEbus systems over CAMAC? I can find very little evidence of them being used outside of the US.
Any insight would be much appreciated!
--Chris
A little less than NIM.
It was like NIM, but modules could communicate. So instead of a rat's nest of cables in the front, you had fussy and unreliable communication on the backplane. This is called "progress". 😈
Lots of places...fifty years ago. It's at least four standards back.
Likes Astronuc and DaveE
Good to know, thanks! I know it's oldschool, but as far as I've heard, they're still running on some older detector arrays and accelerators. There are a few companies still producing modules in the standard, even USB/ethernet crate controllers. SOMEONE must be buying them, even if it's only to keep old setups alive.
They were used a lot at the Rutherford Laboratory, next to Harwell, in the 70s.
Harwell had its own modular system - I forget the name - based on a module about 3" wide where 5? fitted in a single shelf. I remember being a little envious that Rutherford had these much slimmer CAMAC systems and I couldn't get my hands on them.
That's interesting to know. I have read that CAMAC modules were massively more expensive than both the preceding NIM modules and the VME ones that replaced them.
CAMAC was a niche market. VME is in much wider use.
The base bus and racks might be, but the nuclear ADCs and coincidence modules are still pretty unique to that field. The general construction of VME modules are simpler, though.
Hi,
If you want to buy some old stuff, you may ask the main nuclear physics labs/facilities in your country, they can tell you if they are using them, or planning to get rid of some CAMAC crates/modules. If they have some old modules and they are not in use, maybe they can give them to you free of charge.
CAMAC is still on use in some facilities which have been operating without uninterruptedly in the last 20 years (or even more), and also laboratories which have a low budge and they have to use what they have at hand...
Regards,
ORF
Related to CAMAC crate electronics - Where were/are they used?
1. What is a CAMAC crate?
A CAMAC crate is a standardized electronic chassis used in scientific and industrial applications for housing and powering electronic modules. It stands for Computer Automated Measurement And Control and was developed in the 1970s as a standard for instrumentation and control systems.
2. Where were/are CAMAC crates used?
CAMAC crates were primarily used in nuclear physics, particle accelerators, and other high-energy physics experiments. They were also used in industrial automation and control systems, such as in manufacturing plants and power plants.
3. What are the advantages of using CAMAC crate electronics?
The main advantage of CAMAC crate electronics is their modularity and standardization. This allows for easy integration and replacement of electronic modules, making it a cost-effective and flexible solution for complex systems. Additionally, CAMAC crates have a high power capacity and can support a large number of modules.
4. Are CAMAC crate electronics still in use today?
While CAMAC crates were widely used in the past, they have largely been replaced by newer and more advanced technologies. However, some older systems and experiments may still use CAMAC crates due to their reliability and compatibility with older equipment. They are also still used in some industrial applications.
5. Can CAMAC crates be used with modern equipment?
Yes, CAMAC crates can still be used with modern equipment, but it may require additional adapters or converters. Many companies also offer upgrades and retrofitting services to modernize existing CAMAC crate systems. However, it is more common for newer systems to use more advanced and specialized electronic chassis.
  • STEM Academic Advising
  • Quantum Interpretations and Foundations
  • Computing and Technology
  • Art, Music, History, and Linguistics
