"Class" fire ratings vs hour fire ratings
  • Construction
  • Thread starter Stephen Tashi
  • Tags
    Class Fire
In summary, while fire ratings for wall coverings and materials like drywall may both be measured in hours, they are not directly related and serve different purposes in fire protection and prevention.
Stephen Tashi
1,599
TL;DR Summary
Do (USA) fire ratings for wall coverings (Class A,B,C) relate to fire ratings given in hours for materials like drywall?
I'm particularly interested in how ornamental ceiling tiles that have a "class A" fire rating ( e.g. https://www.amazon.com/dp/B00319FP8Y/?tag=pfamazon01-20 ) affect the fire resistance of a drywall ceiling when they are applied over it.
My first idea is that the "class" type of fire rating indicates how much a fire would spread over a tiled ceiling but that the spread of the fire on the tile wouldn't have much effect on how long the fire would take to burn through the drywall. It would take very little time for a fire to burn through a wall covering. So, by this theory, people don't bother to fire rate wall coverings in hours.
Yes, we discuss and specify elements of fire rated walls, partitions and ceilings based on time of resistance to fire.
UL assembly penetrations and fire dampers and ceiling radiation dampers are also rated by time (example: 1-hour dynamic fire damper).
Please, see:
https://codes.iccsafe.org/content/F...smoke-protection-features#FBC2017_Ch07_Sec706
https://www.ruskin.com/model/dfd-lp
:cool:
Likes BillTre and berkeman
It's a good question and one that I've also wondered about. From my understanding, the class A, B, C fire ratings for wall coverings do not directly relate to the fire ratings given in hours for materials like drywall. The class rating is more of a measure of how easily the material will ignite and spread fire, rather than how long it will take for the material to burn through.
In terms of ornamental ceiling tiles, having a class A fire rating means that the tiles are highly resistant to fire and will not contribute to the spread of flames. However, this does not necessarily mean that they will provide any additional fire resistance to the drywall ceiling they are applied over. In fact, in the event of a fire, the tiles may actually hinder the ability for firefighters to access the drywall and extinguish the fire.
In general, it's always best to follow the manufacturer's recommendations for fire ratings and installation methods when it comes to wall coverings and ceiling tiles. It's also important to ensure that any fire-rated materials are properly installed and maintained to ensure their effectiveness in the event of a fire.
Related to "Class" fire ratings vs hour fire ratings
What is the difference between "Class" fire ratings and hour fire ratings?
The "Class" fire rating system is used to classify the performance of a material or assembly in a fire situation based on its ability to resist fire spread and produce smoke. It ranges from Class A (highest resistance) to Class F (no resistance). On the other hand, hour fire ratings refer to the amount of time a material or assembly can withstand fire exposure without failing or allowing fire to spread to the non-fire side.
How are "Class" fire ratings and hour fire ratings determined?
"Class" fire ratings are determined by conducting a series of standardized tests on the material or assembly, which includes measuring its flame spread, smoke production, and heat release. Hour fire ratings are determined by subjecting the material or assembly to fire exposure for a specific period of time and evaluating its performance afterwards.
Which one is more important in determining the fire safety of a building: "Class" fire ratings or hour fire ratings?
Both "Class" fire ratings and hour fire ratings are important in determining the fire safety of a building. "Class" fire ratings provide information on the potential for fire spread and smoke production, while hour fire ratings indicate the amount of time a building can withstand fire exposure. Both factors must be considered together to ensure adequate fire safety.
Can a material or assembly have a high "Class" fire rating but a low hour fire rating?
Yes, it is possible for a material or assembly to have a high "Class" fire rating but a low hour fire rating. This could happen if the material or assembly has a high resistance to fire spread and smoke production, but is not able to withstand fire exposure for a long period of time.
Are there any other factors besides "Class" fire ratings and hour fire ratings that determine the fire safety of a building?
Yes, there are other factors that contribute to the fire safety of a building, such as the building's design, construction materials, fire protection systems, and maintenance practices. It is important to consider all of these factors together in order to ensure the overall fire safety of a building.
  • Thermodynamics
  • Mechanical Engineering
  • Materials and Chemical Engineering
  • STEM Academic Advising
