Classical ground state is Ne\'{e}l state:
The problem is that the different spins transform differently. You have to use the operator notation on the first line of #1 for each spin. In summary, the conversation discusses a transformation in which the B sublattice is rotated by 180 degrees around the x axis while the A sublattice remains unchanged. This transformation is represented by the operator e^(iσ_xπ/2) for each spin and results in the relations σ_j^± → ±σ_j^∓ and σ_j^z → -σ_j^z for j in the B sublattice. This can be extended to higher spins by using matrices of dimension (2s+1)x(2s+1).
Petar Mali
290
Tha classical ground state is Ne\'{e}l state: every spin up is surrounded by nearest neighbours which are down, and vice versa. To give them a name, denote the spins down the [tex]A[/tex] sublattice, and the spins up the [tex]B[/tex] sublattice. Perform a canonical transformation on the [tex]B[/tex] (but not on the [tex]A[/tex] spins: rotate them by [tex]180^{\circ}[/tex] about the [tex]\hat{S}^x[/tex] axis,
[tex]\hat{S}_j^{\pm}\rightarrow +\hat{S}_j^{\mp}[/tex]
[tex]\hat{S}_j^z \rightarrow -\hat{S}_j^z[/tex] [tex](j in B)[/tex]
Can you explain me this transformation with more details? I can't see why relations
are satisfied?
A rotation by 180 deg around x is [tex] \exp(i\sigma_x \pi/2)=\cos(\pi/2) +i\sigma_x \sin(\pi/2)=\sigma_x [/tex].
Hence [tex] \mathbf{\sigma}->\exp(i\sigma_x \pi/2)\mathbf{\sigma}\exp(-i \sigma_x \pi/2)=i\sigma_x \mathbf{\sigma} (-i \sigma_x)=(\sigma_x, -\sigma_y, -\sigma_z)^T [/tex], as sigma_x commutes with sigma_x and anti-commutes with sigma_y and sigma_z.
That's for spin 1/2 only. You will have to check yourself that it holds also for higher spins.
[tex]
\exp(i\sigma_x \pi/2)=\cos(\pi/2) +i\sigma_x \sin(\pi/2)=i \sigma_x
[/tex]
How you get this?
[tex]
\exp(i\sigma_x \pi/2)=\cos(\sigma_x \pi/2) +isin(\sigma_x \pi/2)[/tex]
from this?
use [tex]\sigma_x^2=1[/tex] and the Taylor representation of the sin.
Thanks!
[tex]e^{\frac{i\sigma_x\pi}{2}}=cos\frac{\sigma_x\pi}{2}+isin\frac{\sigma_x\pi}{2}=isin\frac{\sigma_x\pi}{2}=
i\sum^{\infty}_{n=0}(-1)^n\frac{{(\frac{\sigma_x\pi}{2})}^{2n+1}}{(2n+1)!}=i\sum^{\infty}_{n=0}(-1)^n\frac{{(\frac{\sigma_x\pi}{2})}^{2n}\frac{\sigma_x\pi}{2}}{(2n+1)!}
=i\sigma_x\sum^{\infty}_{n=0}\frac{{(\frac{\pi}{2})}^{2n+1}}{(2n+1)!}=i\sigma_x[/tex]
I have one more question?
I'm rotate them by [tex]180^{\circ}[/tex]. Why I use [tex]e^{\frac{i\sigma_x\pi}{2}}[/tex]?
Why not [tex]e^{{i\sigma_x\pi}}[/tex]
You want to say that
[tex]e^{\frac{i\sigma_x\pi}{2}}\hat{S}_j^z=-\hat{S}_j^z[/tex]?
and
[tex]e^{\frac{i\sigma_x\pi}{2}}\hat{S}_j^{\pm}=\hat{S}_j^{\mp}[/tex]?
To question #5:Because the spin 1/2 operator s_iis sigma_i /2 (setting hbar to 1).
To question #6:I want to say that
LaTeX Code: e^{\\frac{i\\sigma_x\\pi}{2}}\\hat{S}_j^z e^{-\\frac{i\\sigma_x\\pi}{2}}=-\\hat{S}_j^z
and
LaTeX Code: e^{\\frac{i\\sigma_x\\pi}{2}}\\hat{S}_j^{\\pm} e^{-\\frac{i\\sigma_x\\pi}{2}}=\\hat{S}_ j^{\\mp}
I can't read your post!
[tex] e^{\frac{i\sigma_x\pi}{2}}\hat{S}_j^z e^{-\frac{i\sigma_x\pi}{2}}=-\hat{S}_j^z [/tex]
and
[tex] e^{\frac{i\sigma_x\pi}{2}}\hat{S}_j^{\pm} e^{-\frac{i\sigma_x\pi}{2}}=\hat{S}_ j^{\mp} [/tex]
[tex]\vec{s}=\frac{1}{2}\vec{\sigma}[/tex]
for [tex]\hbar=1[/tex].
So
[tex]
e^{i s_x\pi}\hat{S}_j^z e^{-i s_x\pi}=-\hat{S}_j^z
[/tex]
[tex]
e^{i s_x\pi}\hat{S}_j^{\pm} e^{-i s_x\pi}=\hat{S}_ j^{\mp}
[/tex]
for any [tex]s_x[/tex]. Correct?
Yes, in fact, the relations of #1 hold for any vector, not only for spin for a 180 deg rotation.
First there is no spin 2/3. Second, the operator for higher spins is represented by matrices of dimension (2s+1)x(2s+1). E.g. for spin 1 you get the usual 3x3 rotation matrices.
Hm. I know it past a little time but I'm now confused a bit.
[tex]
e^{\frac{i\sigma_x\pi}{2}}=cos\frac{\sigma_x\pi}{2 }+isin\frac{\sigma_x\pi}{2}=isin\frac{\sigma_x\pi} {2}=
i\sum^{\infty}_{n=0}(-1)^n\frac{{(\frac{\sigma_x\pi}{2})}^{2n+1}}{(2n+1) !}=i\sum^{\infty}_{n=0}(-1)^n\frac{{(\frac{\sigma_x\pi}{2})}^{2n}\frac{\sig ma_x\pi}{2}}{(2n+1)!}
=i\sigma_x\sum^{\infty}_{n=0}\frac{{(\frac{\pi}{2} )}^{2n+1}}{(2n+1)!}=i\sigma_x
[/tex]
I agree that this is rotation for angle [tex]\pi[/tex]. But I want to rotate whole B sublattice. I think that in this case I must use somethink like
[tex]
e^{\frac{i\sum_k\sigma_k^x\pi}{2}}=\prod_ke^{\frac{i\sigma_k^x\pi}{2}}[/tex]
Am I right?
Yes, you have to take this product.
Related to Classical ground state is Ne\'{e}l state:
1. What is the classical ground state?
The classical ground state refers to the lowest energy state of a system in classical physics. It is the state in which the system is most stable and has the least amount of energy.
2. What is the Ne\'{e}l state?
The Ne\'{e}l state is a magnetic ordering in which neighboring magnetic moments are oriented in opposite directions. It is named after French physicist Louis N\'{e}el and is commonly observed in antiferromagnetic materials.
3. How is the classical ground state related to the Ne\'{e}l state?
The classical ground state can be described by the Ne\'{e}l state in systems with antiferromagnetic ordering. This means that the classical ground state of these systems is a Ne\'{e}l state.
4. What are some examples of systems with a classical ground state that is a Ne\'{e}l state?
Some examples include antiferromagnetic materials such as chromium, manganese oxide, and iron oxide. These materials exhibit a Ne\'{e}l state as their classical ground state at low temperatures.
5. How is the classical ground state of a Ne\'{e}l state determined?
The classical ground state of a Ne\'{e}l state can be determined through experiments and theoretical calculations that consider the interactions between magnetic moments in a system. The state with the lowest energy is identified as the classical ground state.
  • Atomic and Condensed Matter
  • Quantum Physics
