Conditional time evolution entropy and the experimenter?
In summary: Now using the second equation:$$\Delta S_R = \frac{1}{2}\Big (\rho' (-) - \rho' (+) \Big )$$In summary, if the experimenter reacts to the outcome of the measurement then the entropy change is bounded by the change in entropy where the experimenter is indifferent.
Someone_physics
Question
So I've done a calculation which seems to suggest if I combine the system of a measuring apparatus to say an experimenter who "reacts" to the outcome of the the measurement versus one who does not. Then the change in entropy in both these situations is bounded by:
$$ \Delta S_R \leq \Delta \bar S_R $$
Where ##\Delta \bar S_R ## is the change in entropy where experimenter is indifferent and ##\Delta S_R ## is the change in entropy where the experimenter reacts.
Are the below calculations correct? Am I interpreting it correctly if I argue the experimenters choice to "react" changes the entropy?
Summary of Calculations
  1. We isolate the experimenter, measuring apparatus and Hamiltonian system.
  2. We start with a Hamiltonian coupled to an electric field whose states are in superposition of spin up and down.
  3. If the experimenter measures state of the system to be up he (reacts and) halves the electric field however if he (reacts and) doubles the electric field.
  4. Using the sudden approximation we can calculate change in the density matrix and also calculate the entropy change.
  5. Since the system is isolated the net change in entropy is 0. Hence, we can also calculate the entropy change for the everything besides the Hamiltonian system.
  6. Now we can also calculate the entropy change when the experimenter is indifferent to the outcome of the measurement and create an inequality.
Calculation
Let's say I have an isolated system containing a measuring apparatus, an experimenter and a Hamiltonian system:
Let the Hamiltonian be:
$$ H_{sys}= H = \begin{pmatrix}
E_0 + \mu \cdot E & - \Delta \\
- \Delta & E_0 - \mu \cdot E
\end{pmatrix}$$
where ##\mu## is the dipole moment , ##E## is the electric field and ##E_0## is the ground state energy and ##\Delta## is the tunnelling element.
Let the energy eigenstates be represented by:
$$ H | - \rangle = (E_0 - \sqrt{(\mu \cdot E)^2 + \Delta^2 }) | - \rangle $$
$$ H | + \rangle = (E_0 + \sqrt{(\mu \cdot E)^2 + \Delta^2 }) | + \rangle $$
Now, the experimenter play the following game, if he measures the energy and finds the energy in the lower of the ##2## energy states he will double the electric field else he will half the electric field. Hence,
$$ H'(\pm) = H + \lambda_{\pm} I(\mu \cdot E) $$
where $I$ is the identity matrix and ## \lambda_+ = - 1/2## and ##\lambda_- = 1##
Let the energy eigenstates of ##H'(\pm)## be represented by:
$$ H' (-) | 0 \rangle = (E_0 - \sqrt{(1+ \lambda_{-})^2(\mu \cdot E)^2 + \Delta^2 }) | 0 \rangle $$
$$ H' (-) | 1 \rangle = (E_0 + \sqrt{(1+ \lambda_{-})^2(\mu \cdot E)^2 + \Delta^2 }) | 1 \rangle $$
$$ H' (+) | \tilde 0 \rangle = (E_0- \sqrt{(1+ \lambda_{+})^2(\mu \cdot E)^2 + \Delta^2 }) | \tilde 0 \rangle $$$$ H' (+) | \tilde 1 \rangle = (E_0 + \sqrt{(1+ \lambda_{+})^2(\mu \cdot E)^2 + \Delta^2 }) | \tilde 1 \rangle $$
Let use the density matrix formalism for a pure state ## |+\rangle + |- \rangle ##:
$$ \rho = \frac{1}{2} \Big (|- \rangle \langle -| + |- \rangle \langle +| + |+ \rangle \langle -| + |+ \rangle \langle +| \Big) $$
OR:
\rho = \frac{1}{2}
\begin{bmatrix}
1 & 1 \\
1 & 1 \\
\end{bmatrix}
Now let's say I measure the state and find it in ##|- \rangle## and the field is changed. Then using the sudden approximation:
$$ \rho' (-) = \Big (|0 \rangle \langle 0| \Big (|\langle -|0 \rangle |^2 \Big) + |1 \rangle \langle 0| \Big (|\langle -|0 \rangle ||\langle -|1 \rangle | \Big) + |0 \rangle \langle 1| \Big (|\langle -|0 \rangle ||\langle -|1 \rangle | \Big) + |1 \rangle \langle 1| \Big (\langle -|1 \rangle |^2 \Big) \Big) $$
OR:
$$ \rho' (-) =
\begin{bmatrix}
|\langle -|0 \rangle |^2 & |\langle -|0 \rangle \langle -|1 \rangle | \\
|\langle -|0 \rangle \langle -|1 \rangle | & \langle -|1 \rangle |^2 \\
\end{bmatrix}
Similarly:$$ \rho' (+) = \Big (| \tilde 0 \rangle \langle \tilde 0| \Big (|\langle -| \tilde
0 \rangle |^2 \Big) + | \tilde 1 \rangle \langle \tilde 0| \Big (|\langle -|\tilde 0 \rangle ||\langle -| \tilde 1 \rangle | \Big) + | \tilde 0 \rangle \langle \tilde 1| \Big (| \langle -| \tilde 0 \rangle ||\langle -|\tilde 1 \rangle | \Big) + | \tilde 1 \rangle \langle \tilde 1| \Big (\langle -| \tilde 1 \rangle |^2 \Big) \Big) $$
OR:
$$ \rho ' (+)=
\begin{bmatrix}
|\langle +|0 \rangle |^2 & |\langle -|0 \rangle \langle +|1 \rangle | \\
|\langle +|0 \rangle \langle -|1 \rangle | & \langle +|1 \rangle |^2 \\
\end{bmatrix}$$
Hence, the new density matrix is given by:
$$ \rho ' = \rho '(+)\Big ( \frac{| \langle - | + \rangle + \langle + | + \rangle |^2}{2} \Big) + \rho '(-)\Big ( \frac{ | \langle - | - \rangle + \langle + | - \rangle |^2}{2} \Big) = p_+ \rho '(+) + p_- \rho '(-)$$
Now, let write down the explicit Hamiltonian of the isolated system:
$$ H_{iso} = H \otimes I_{\text{experimenter + apparatus}} + I \otimes H_{\text{experimenter + apparatus}} + H_{\text{int}}$$
Since, we suddenly change the electric field ##H## is time dependent and since this energy is supplied by the apparatus and experimenter (since he will expend energy to "calculate" how much to change the energy field by) along with the interaction between the systems. Note:##H_{iso}## is time independent (as it is an isolated system)
$$ \rho_{iso} = \rho(t) \otimes \rho_R(t) $$
Where $R$ is the rest of the isolated system excluding the Hamiltonian system. Since the ##H_{iso}## is time independent so is ##S(\rho_{iso})##. Comparing before (##t_-##) and after (##t_+##) the field is turned on:
$$ S(\rho_{iso}) = S(\rho \otimes \rho_R(t_-)) = S(\rho ' \otimes \rho_R(t_+) ) $$
Where ##S## is the Von Neumann entropy of both sides:
$$ S(\rho ' \otimes \rho_R(t_+) ) = S(\rho \otimes \rho_R(t_-) ) $$
Hence,
$$ S(\rho ') + S( \rho_R(t_+) ) = S(\rho ) + S( \rho_R(t_-) ) $$
Substituting ##\rho '## and using ##\Delta S_R = S( \rho_R(t_+) ) - S( \rho_R(t_-) ) ##
$$ S(p_+ \rho '(+) + p_- \rho '(-)) + \Delta S_R - S(\rho ) = 0 $$
Using an entropy bound:
$$ p_+ S( \rho '(+)) + p_- S(\rho '(-)) + \Delta S_R - p_+ \ln p_+ - p_- \ln p_- - S(\rho ) \leq 0 $$
Hence,
$$ \Delta S_R \leq p_+ \ln p_+ + p_- \ln p_- + S(\rho ) - p_+ S( \rho '(+)) - p_- S(\rho '(-)) $$
Note the ##p_+ \ln p_+ + p_- \ln p_- = -S_m ## is nothing but the entropy of the Hamiltonian system when measurement is done but the electric field is not changed. We define ##\Delta S_m = S_m - S(\rho )## and ##\rho '(-)## and ##\rho '(+)## are pure states:
$$ \Delta S_R \leq - \Delta S_m $$
Note: if the experimenter is indifferent to the measurement. Then one can show the change in the entropy of the rest of the environment ## \Delta \bar S_R ##is equal to the change in the system:
$$ \Delta \bar S_R = - \Delta S_m $$
Hence,
Since by "react" you mean "change the physical conditions" (in this case the electric field), then of course "reacting" will change the entropy as compared with not reacting, since not reacting and reacting produce different physical conditions (in this case, different electric fields).
(Note that I haven't checked the details of your math; I am simply making an obvious general observation.)
I don't see what the point of analyzing this is, however.
If you consider the experimenter as system A and your system as system B then more (stronger) interactions (the "reaction" is an interaction) between A and B, implies more constraints on the evolution of those system. More constraints means a small number of states available thus a smaller entropy change. This is not rigorous (I know too little to help you with calculations) but I think this is a well studied topic in statistical mechanics/quantum thermodynamics. I think https://arxiv.org/pdf/1305.2268.pdf page 9 could help. There is brief part explaining von Neumann entropy and the "problem" of entangled states. Maybe could give you some insights. I didn't read the paper though.
Anyway, long story short, I didn't check your calculation, but your result seems to be expected from what I know about stat mech. Hope someone else gives a feedback on this to be sure.
Try to answer the following questions. When does the change of entropy happen, is it when the experimenter makes the choice, or is it when the reaction (which finishes some time after the the experimenter's choice) finishes? What if the experimenter decides today to perform the reaction tomorrow, will the entropy change happen today or tomorrow?
Likes berkeman and vanhees71
Related to Conditional time evolution entropy and the experimenter?
1. What is conditional time evolution entropy?
Conditional time evolution entropy is a measure of the uncertainty or randomness in a system that changes over time, taking into account the influence of an external observer or experimenter.
2. How is conditional time evolution entropy calculated?
Conditional time evolution entropy is calculated using the formula S = -kΣpilog(pi), where S is the entropy, k is the Boltzmann constant, and pi is the probability of each possible state of the system.
3. What is the role of the experimenter in conditional time evolution entropy?
The experimenter plays a crucial role in conditional time evolution entropy as they have the ability to manipulate and observe the system, thus influencing its evolution and the resulting entropy.
4. How does conditional time evolution entropy relate to thermodynamics?
Conditional time evolution entropy is closely related to thermodynamics as it is a measure of the disorder or randomness in a system, which is a fundamental concept in thermodynamics.
5. Can conditional time evolution entropy be used to predict the future behavior of a system?
No, conditional time evolution entropy cannot be used to predict the exact future behavior of a system. It can only provide information about the current state and potential future states of the system, taking into account the influence of the experimenter.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
