Confused with using Proof by Smallest Counterexample
In summary, the conversation discusses the technique of proof by smallest counterexample, where an integer k>1 is assumed to be the smallest counterexample for which a statement is false. It is then shown that Sk-1 implies Sk, leading to a contradiction and proving the statement. This technique is equivalent to proof by induction and is commonly used in combinatorics. The conversation also touches on the difference between this technique and classical induction, where a statement is directly proved for k by assuming it is true for k-1.
RichardParker
23
When proving by smallest counterexample, you assume an integer k>1 where it is the smallest integer for which statement Sn is false. Then you proceed to prove that Sk-1 implies Sk. Where you deduce a contradiction by which k is true.
Can't you prove this directly by assuming Sk-1 is true and showing that Sk-1 implies Sk since you will end up with a true k anyhow?
Mathematics news on Phys.org
I think I get it now...
In mathematical induction you prove that given any k>=1, if Sk, then Sk+1. But in the proof by smallest counterexample Sk-1 is used instead.
Is that okay?
This is really just "proof by induction" isn't it?
In "proof by smallest counter example", of a statement about the positive integers, you are saying "if it were not true, then there would be a smallest counterexample, k. Since k is the smallest counter example the statement must be true for k- 1 (Of course, you would have to check that 1 is not a counterexample!). If you can show that k-1 being true implies k being true, you have a contradiction.
So you must prove (i) that the statement is true for n= 1 and (2) if it is true for k-1 then it is true for k. Yes, that is exactly "proof by induction".
Strong induction comes from the well-ordering of the positive integers. The well-ordering principle states that every nonempty set of positive integers has a smallest element.
When trying to prove the proposition S(n) for all pos. integers n, we consider the set
[tex]
\{n \in \mathbb{Z}^+ : S(n) \, \text{is false}\}
[/tex]
If this set is nonempty, then it has a smallest element k. Since k is the smallest element, then for all n less than k, S(n) must be true.
The principle of natural induction is equivalent to that every non-empty set of naturals has a least element. This is a good beginner exercise in proofs. This fact allows us to always consider the "least counter-example" if it exists.
I'm guessing this is for a combinatorics question, right? The technique to which you are referring is extremely popular in combinatorics, but not really in other areas of math. This is because it isn't *really* a "proof by induction". That is, you don't assume that it is false for k and true for k-1, then show that it is true for k. Instead, you assume that it is false for k and true for k-1. Then, you use this to come up with some sort of contradiction. So, you might never really prove directly that if the statement is true for k-1 then it is true for k.
So, what HallsOfIvy (and the others) have said is partially correct, and partially incorrect. If you end up showing that the statement being true for k-1 implies that it is true for k, then yes, you have just done regular induction, and you need to show that it is true for some base case.
On the other hand, if you do what is usually the case (in my, admittedly limited experience) when using a proof by smallest counter example, you show that the fact that it is true for k-1 and false (by assumption) for k there is some contradiction, somewhere. The contradiction is not necessarily that the statement is, in fact, true for k. In fact, if this is the contradiction, then it falls in the case above and it is just regular induction. Usually the contradiction is that a hypothesis in the theorem fails to hold.
If "k is false" implies a contradiction then by the law of excluded middle it is true for k. This process is logically equivalent to mathematical induction, it has nothing to do with the technique of proof.
True, the two things might be logically equivalent, but the actual process of working through the proofs are much different, IMO.
In one (for lack of a better term, let's call if "classical induction"), you usually use the fact that a given statement is true for k-1 to prove directly from that assumption (and from any hypothesis made in the statement of the theorem/problem) is true for k. It is never assumed that the statement is false for k, and so this assumption is not used during the proof.
Using proof by smallest counter example, you never directly prove that the truth of the statement for k-1 implies the truth of the statement for k. Instead, you use the fact that it is false for k (by assumption), and true for k-1, then you come up with some contradiction.
There are many times in combinatorics where a proof by "classical induction" is much harder than a proof by smallest counter example. Or, many times, a proof by smallest counter example sheds more light on what is actually going on than a proof by "classical induction".
Thanks for all your replies. :)
Especially to Robert.
A proof by "classical induction" may very well assume that the statement for k is false and derive a contradiction. This doesn't change the fact that it's a proof by induction. All you stand with is: the statement is true for 0,1,...,k-1, and what you have to prove is the statement for k, in whatever manner you prefer, directly or by contradiction.
While I agree with you that a direct proof often is more instructive, it doesn't mean that a proof by contradiction isn't induction.
Hi Richard,
If I am getting what your confusion is, then I think this is what you are confused about. In the standard induction method, we do the following:
1) Base case: P(0) true
2) Inductive hypothesis: P(n) true
3) Inductive step: If P(n) true => P(n+1) true.
However, we can make a variation in step 3, by using its contra-positive statement. That is, we show that:
2') Inductive hypothesis: P(n) false
3') Inductive step: If P(n) false => P(n-1) false.
Obviously taking step 1 and 3' together leads to a contradiction since P(0) gives a counter example.
I hope this helped.
Regards,
Sudarshan
Related to Confused with using Proof by Smallest Counterexample
1. What is Proof by Smallest Counterexample?
Proof by Smallest Counterexample is a mathematical proof technique used to show that a statement is true for all natural numbers by finding the smallest number for which the statement is false.
2. How is Proof by Smallest Counterexample different from other proof techniques?
Proof by Smallest Counterexample is different from other proof techniques because it relies on finding a specific counterexample instead of using logical deductions to prove the statement.
3. When should I use Proof by Smallest Counterexample?
Proof by Smallest Counterexample is useful when trying to prove statements about natural numbers, such as proving that a formula or algorithm works for all cases.
4. What are the steps to using Proof by Smallest Counterexample?
The steps to using Proof by Smallest Counterexample are:
1. State the statement to be proven.
2. Assume that the statement is false for all natural numbers.
3. Find the smallest natural number for which the statement is false.
4. Show that this counterexample leads to a contradiction.
5. Conclude that the statement must be true for all natural numbers.
5. Are there any limitations to using Proof by Smallest Counterexample?
Proof by Smallest Counterexample can only be used to prove statements about natural numbers, so it may not be applicable in all situations. Additionally, finding a counterexample may be difficult or impossible in some cases, making this proof technique ineffective.
  • General Math
