Daily Temperature as a function of time
In summary, the conversation discusses the idea of expressing temperature during the day as a function of time using average high and low temperatures. The proposed method is to use a sine wave with the high and low temperatures as parameters. However, other factors such as geographic location, weather patterns, and albedo can affect the temperature curve and may need to be taken into account for a more accurate representation. Overall, the use of hourly weather data and knowledge of specific patterns can help in creating a more precise temperature function.
zzinfinity
47
Hi,
I trying to loosely express temperature during the day as a function of time. Essentially what I want is to be able to take the average high and low temperature for say May 15th, and use those 2 data points to extrapolate a function that gives the temperature as a function of the minute.
Looking at daily temperature graphs, it appears to loosely follow the form of a sign wave. So let's say I knew my high temperature was 10 degrees and my low was -10 degrees. How accurate would it be to say.
Temp(t)= -10Cos(pi*t/720) where t is the number of minutes after the the coldest time of the night.
Is this in any way an accurate representation. Is there a better way to do this with only a little bit of climate data?
Thanks.
Even if it was, maybe only when the day and night cycle is 12-12 hours, the higher the lattitude, the more problems you're likely running into
Weather stations routinely produce hourly data, which can be averaged to compile algorithms like that or google diurnal temperatures.
A sine wave is a good rough approximation, but if you're looking for something more accurate, then you have to take other factors into account than time and min/max temperature.
Here's a graphical hourly forecast for Melbourne, Florida, near their weather forecast office. Any NWS site should allow you to view a similar graphical hourly forecast.
http://forecast.weather.gov/MapClic...51412429&unit=0&lg=english&FcstType=graphical
If you view this any time in the near future from when I posted it, you'll see that this time of year, South Florida has a relatively sharp incline to the near-max from 9am to 1pm, and then gently rounding off to the maximum around 3pm. This is due to the formation of coastal showers and thunderstorms forming along the sea breeze boundaries. From the maximum, it's then a slow linear decline from there to the diurnal minimum.
Some factors I can think of that would alter the pattern from a pure sine wave include:
Geographically-specific repeating weather patterns - I've seen coastal areas in California that have a regular morning fog that "burns off" by a certain time, followed by a jump in surface level air temps. Along the Great Lakes, "lake effect" weather patterns can help slow rapid night-time heat loss in the winter. Coastal storms during South Florida's rainy season certainly alter the temperature curve in the late afternoons as mentioned above.
Albedo - Areas dominated by pavement will absorb heat more than a snow-covered field. The latent heat may later moderate night time temperature loss, particularly around big cities. Albedo varies by season in Northerly climates.
If patterns for the above factors are known, you may be able to more accurately approximate the curve for a specific area.
Related to Daily Temperature as a function of time
What is the significance of studying daily temperature as a function of time?
The study of daily temperature as a function of time helps us understand patterns and changes in temperature over a period of time. This information is crucial for predicting and preparing for future weather conditions, as well as tracking long-term climate trends.
How is daily temperature as a function of time measured?
Daily temperature is typically measured using weather stations or sensors that record temperature data at regular intervals throughout the day. This data is then plotted on a graph to show the relationship between temperature and time.
What factors can impact daily temperature as a function of time?
Several factors can influence daily temperature, including geographic location, elevation, humidity, cloud cover, and atmospheric pressure. Human activities such as urbanization and deforestation can also have an impact on temperature patterns.
What is the difference between daily temperature as a function of time and average daily temperature?
Daily temperature as a function of time refers to the specific temperature readings recorded at different points throughout the day, while average daily temperature is the average of all the temperature readings recorded in a 24-hour period. Average daily temperature can provide a more general overview of temperature patterns, while daily temperature as a function of time allows for a more detailed analysis.
How can daily temperature as a function of time be used in research or practical applications?
The study of daily temperature as a function of time is used in various fields, including meteorology, climatology, and environmental science. It can also be applied in practical applications such as agriculture, energy consumption, and transportation planning to make informed decisions and predictions based on temperature patterns.
  • Earth Sciences
  • Calculus
  • Materials and Chemical Engineering
