Differention equation problem, help please
  • Thread starter stelastela
In summary, a differential equation problem is a mathematical equation that involves a function and its derivatives. It can be used to model real-world phenomena and is often used in physics, engineering, and economics. There are two types of differential equations: ordinary and partial, where ordinary equations involve a single independent variable and partial equations involve multiple. The method for solving a differential equation problem varies based on its complexity, and common techniques include separation of variables and using Laplace transforms. Differential equations have many applications in the natural and social sciences, such as describing motion, population growth, and heat transfer. They can also be used to make predictions about the future behavior of a system, but the accuracy of the prediction depends on the initial conditions and assumptions made in the
stelastela
Please help me with this problem :
Show that for any constant A and B the function y= Axr1+Bxr2 is a solution of the differentiol equation ax2y"+bxy'+cy=0 , given that r1 and r2 are both roots of the quadratic equation ar(r-1)+br+c.
Welcome to PF!
Hi stelastela! Welcome to PF! :smile:
Hint: xr1 = er1lnx :wink:
Related to Differention equation problem, help please
1. What is a differential equation problem?
A differential equation problem is a mathematical equation that involves a function and its derivatives. It describes the relationship between a function and its rate of change, and is often used to model real-world phenomena in fields such as physics, engineering, and economics.
2. What is the difference between an ordinary and a partial differential equation?
An ordinary differential equation involves a single independent variable, while a partial differential equation involves multiple independent variables. Ordinary differential equations are often used to describe systems that change over time, while partial differential equations are used to describe systems that vary over space and time.
3. How do you solve a differential equation problem?
The method for solving a differential equation problem depends on its type and complexity. Some common techniques include separation of variables, integrating factors, and using Laplace transforms. In some cases, numerical methods may also be used to approximate a solution.
4. What are some applications of differential equations?
Differential equations have many applications in the natural and social sciences. They are used to describe the motion of objects, population growth, heat transfer, electrical circuits, and many other phenomena. They are also used in economics to model economic growth and in biology to model population dynamics.
5. Can differential equations be used to predict the future?
Yes, differential equations can be used to make predictions about the future behavior of a system. By solving the equation, we can determine the value of the function at any given time. However, the accuracy of the prediction depends on the accuracy of the initial conditions and the assumptions made in the model.
  • Differential Equations
