In summary, the conversation discusses the potential of generating endless energy by using a spring, mass, and magnet apparatus inside a copper coil. However, this idea is considered pseudoscience and is not possible due to the laws of thermodynamics. The forum rules also prohibit the discussion of perpetual motion and free energy topics.
Zachary Samples
Matter can neither be created nor destroyed...but potential energy can be converted into a different kind of energy. Let's say we have a spring with a mass connected to it. This mass is a magnet, and the apparatus is inside a copper coil. It's a horizontal magnet with friction minimized at the bottom. After the spring is pulled back, it is released and thus, it will oscillate for a number of times before it stops. Would it be possible to generate more electrical energy than the work it takes to displace the magnet each time the cycle is restarted? And if so, would it be theoretically possible to create an "endless" energy supply by taking advantage of a significant amount of electromagnetic induction? (Of course this procedure would not be very efficient...)
I think that you could do better with a proper reciprocating linkage (crank and flywheel) - if you want a reciprocating generator. A spring will just be storing some (half of the) energy so that it can induce a similar amount of power on the way back. In fact, the magnet mass / spring arrangement will be a simple harmonic oscillator which would carry on for several cycles once you stop squeezing / pushing regularly - very similar to a rotating flywheel, in its effect.
It is against the forum rules (see Info at the top of the page) to try to discuss free energy or perpetual motion. Thread is closed.
Forbidden Topics said:
Pseudoscience, such as (but not limited to):
Perpetual motion and "free energy" discussions
http://wiki.4hv.org/index.php/Free_Energy_Debunking
http://en.wikipedia.org/wiki/Perpetual_motion
http://www.skepdic.com/freeenergy.html
http://www.skepdic.com/perpetual.html
Related to Elastic Potential Energy to Aid Electromagnetic Induction
1. What is elastic potential energy?
Elastic potential energy is the energy stored in an object when it is stretched or compressed. This energy is due to the object's elastic properties, meaning it can return to its original shape after the force is removed.
2. How does elastic potential energy aid electromagnetic induction?
Elastic potential energy can aid electromagnetic induction by providing the necessary force to move a conductor through a magnetic field, creating a change in magnetic flux and inducing an electromotive force (EMF) in the conductor. This EMF can then be used to generate electricity.
3. Can elastic potential energy be converted into electrical energy?
Yes, elastic potential energy can be converted into electrical energy through the process of electromagnetic induction. As the conductor moves through the magnetic field, the elastic potential energy is converted into kinetic energy, which in turn induces an EMF and generates electrical energy.
4. What are some real-world applications of elastic potential energy aiding electromagnetic induction?
One example of this is in hydroelectric power generation, where the potential energy of water stored in a dam is converted into kinetic energy as it falls through a turbine, which then rotates a conductor in a magnetic field to generate electricity through electromagnetic induction.
Another application is in hand-cranked generators, where the elastic potential energy in a spring or rubber band is used to rotate a conductor in a magnetic field, generating electrical energy.
5. How is elastic potential energy related to the strength of an electromagnetic field?
The strength of an electromagnetic field is directly related to the amount of elastic potential energy being converted into electrical energy through electromagnetic induction. The more force applied to move the conductor, the stronger the magnetic field and the greater the amount of electrical energy generated.
  • Electromagnetism
  • Electromagnetism
  • Electrical Engineering
