Example on spherical coord. and trip. integral
In summary, this conversation discusses an example in a book where the volume of a sphere is being calculated using spherical coordinates. The bounds for the coordinates are given and there is confusion about why the \phi coordinate goes from 0 to pi. It is explained that this is due to one coordinate measuring the pole to pole angle and the other measuring the equatorial angle. A picture is suggested to better understand this concept.
hotcommodity
436
[SOLVED] Example on spherical coord. and trip. integral
Here's the example in the book. They're proving the volume of a sphere using spherical coordinates.
A solid ball T (the region) with constant density [tex]\delta[/tex] is bounded by the spherical surface with equation [tex]\rho = a[/tex]. Use spherical coordinates to compute its volume V.
It says that the bounds are:
[tex]0 \leq \rho \leq a, 0 \leq \phi \leq \pi, 0 \leq \theta \leq 2 \pi[/tex]
The bounds for [tex]\phi[/tex] confuse me. Why does it go from 0 to pi? Wouldn't that only account for half of the sphere?
Any help is appreciated.
One angular coordinate measures pole to pole angle, that goes from 0 to pi. The other measures the equatorial angle, that goes 0 to 2pi. Together they cover the whole sphere.
Draw a picture. If [itex]\phi> \pi[/itex] you would be picking up the same points as with [itex]\phi< \pi[/itex], [itex]\theta> \pi[/itex].
Oh ok, I get it, as theta goes from 0 to 2pi, phi sweeps the entire sphere. Thank you both.
Related to Example on spherical coord. and trip. integral
What is a spherical coordinate system?
A spherical coordinate system is a mathematical system used to describe points in three-dimensional space using angles and distances from a fixed point. It is commonly used in physics, engineering, and mathematics.
How is a spherical coordinate system different from a Cartesian coordinate system?
In a spherical coordinate system, points are defined by a distance from a fixed point, an angle from a reference direction, and an angle from a reference plane. In a Cartesian coordinate system, points are defined by their distances along three perpendicular axes.
What is a triple integral?
A triple integral is a mathematical tool used to calculate the volume of a three-dimensional region in space. It involves integrating a function over the three dimensions of the region.
How are spherical coordinates used in triple integrals?
In triple integrals, spherical coordinates are used to describe the limits of integration and the region of integration. They can be converted into Cartesian coordinates to simplify the integration process.
What are some real-world applications of spherical coordinates and triple integrals?
Spherical coordinates and triple integrals have many practical applications in fields such as physics, engineering, and astronomy. They are used to calculate the volume and surface area of objects, solve problems involving forces acting on a point in space, and determine the electric field around a charged object.
