Heard of Another Kind of "Rational" (Fraction) Addition?
In summary, the conversation discusses the addition rule of a/b + c/d = (a+c)/(b+d) and its application in generating a triangle of fractions. It also mentions the properties and uses of the sequence, including its connection to the existence of transcendental numbers. The conversation also touches on the representation of the sequence, suggesting that a colon (a:b) may be a more appropriate symbol than a fraction (a/b).
PMH
I ran across this years ago.
It’s defined by the addition rule: a/b + c/d = (a+c)/(b+d)
(Sounds crazy – until you think of x/y as meaning There’s a pile of x things on one side, and one of y things on the other.)
Applying it in almost a Pascal's Triangle sort of way generates ... er, a triangle (see below)..
..which I think has the properties of the sequence:
1/2, 1/3, 2/3, 1/4, 3/4, ...
(as you see, skipping non-reduced fractions)
Properties: One person put it this way:
"In 1873 Georg Cantor used an argument similar to this to show the existence, not of irrational numbers within every interval, but of transcendental numbers every interval."
Start with 0/1 on the left, and 1/1 on the right of the top line.
To form each item of the next line, rational-add the two fractions - anywhere above - that are closest on either side to its position in the line.
(Hard to articulate: See the first four lines that of the result from that, below.)
(I'm using dashes as separators since so many editors like this one collapse strings of blanks into one.)
0/1---------------1/1
---------1/2
----1/3-------2/3
-1/4-2/5--3/5-3/4
I'm looking to references, but of course first-hand knowledge is great.
Mathematics news on Phys.org
See Wikipedia. It's called the mediant. Problem with it is that it is not monotonic (does not preserve order).
Likes jedishrfu
In addition to what pwsnafu said, this type of addition is sometimes called "baseball arithmetic." If a batter gets 2 hits from 6 times at bat in one game, his batting average for the game is 2/6, which is usually represented as .333. If he gets 1 hit for 4 at bats in the next game, his batting average for the two games is ##\frac{2 + 1}{6 + 4} = \frac 3 {10}## or .300.
Note that this is different from adding ##\frac 2 6## and ##\frac 1 4##, which is ##\frac 7 {12}##.
Likes jedishrfu
One of the issues with this addition (which I denote with ##\oplus##) is that it is not well-defined. For example, we have
[tex]\frac{1}{3}\oplus \frac{1}{2} = \frac{2}{5}[/tex]
While
[tex]\frac{2}{6} \oplus \frac{1}{2} = \frac{3}{8}[/tex]
This is not the same outcome although it should be.
yes instead of the ratio it is much appropriate the vector notation because it is in fact the sum of two vectors ## \binom{a}{b}+\binom{c}{d}=\binom{a+c}{b+d}##...
Likes micromass
from Skipjack at myMathForum.com:
"I've come across it before, this article can serve as a reference for you, and this interesting article makes use of it."
Terms ("keywords"): Mediant, Farey sequence
Thank you.
It turns out that what you - and nearly everyone else, I wager - perceived here, seeing these things that look like fractions, as fractions (ie: that may be reduced or represented as decimals) are in fact not.
(IOW, they are assumed to be ... not reducible)
A better representation than "a/b", IMHO, would be "a:b".the answer I got that was what I had in mind:
Not really.
A ratio can be represented as a fraction, such as a/b, or using a colon, as a:b.
Well, fine. What would you say it should be represented by? (not that that's all that important)
I was just trying to get at the fact that its form should signify that it's not a fraction - ie: one that can be either reduced or multipied by k/k without having its meaning changed.
Related to Heard of Another Kind of "Rational" (Fraction) Addition?
Question 1: What is a "rational" fraction?
A rational fraction is a fraction that can be written as a ratio of two integers. This means that the numerator and denominator are both whole numbers.
Question 2: How is "rational" fraction addition different from regular fraction addition?
"Rational" fraction addition involves adding fractions with different denominators by finding a common denominator and converting the fractions. Regular fraction addition only involves adding fractions with the same denominator.
Question 3: Why is "rational" fraction addition important?
"Rational" fraction addition is important because it allows us to add fractions with different denominators, which is necessary for many real-world applications such as cooking and measurements. It also helps us understand the concept of equivalent fractions.
Question 4: Can you provide an example of "rational" fraction addition?
Sure! For example, if we want to add 1/3 and 1/4, we first find the common denominator, which is 12. Then we convert 1/3 to 4/12 and 1/4 to 3/12. We can now add these fractions to get 7/12.
Question 5: How can I simplify a "rational" fraction addition?
To simplify a "rational" fraction addition, you can divide both the numerator and denominator by their greatest common factor (GCF). This will give you the simplest form of the fraction.
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
