How do I calculate forces acting on bicycle axle?
In summary, you would need to calculate the power input from pedaling and the force applied to the ground to find the total force acting on the wheel axle.
SkyblueEagle
Hey everyone,
I am trying to figure out how to calculate how much total force is being applied to the wheel axle on a bicycle. I'm focusing on the rear wheel for the moment. For the sake of simplicity, let's say that the bike and rider together weigh 100kg and that 60 percent of that is going to the rear wheel. Let's also say that the bike is traveling at up to 10 meters per second. I know that 60kg of force is being applied in a downwards direction on the axle , but I am uncertain as to how I calculate the backwards force being applied when traveling at that speed.
I wondered if it were simply the weight × the speed in m/s ? But this would give 660kg of total force on just the rear axle alone, and that seems rather high to me. And what about the traction of where the bicycle tyre touches the ground? Does that make a difference and if so wouldn't different tyre widths and different levels of inflation affect that.
If it's not already obvious, I am an amateur when it comes to engineering, so go easy on me. Any help is much appreciated.
P. S If your curious, I am considering what material other than metal might be used for the wheel axles, and would like to know how much force is being applied to them and hence whether the material would be strong enough.
SkyblueEagle said:
Hey everyone,
Welcome to the PF.
It sounds like you should be looking into torque as well as force. What reading have you been able to do so far online about axle forces and torques?
For linear force (which I guess gives you the shear on the axle at the forks, but I'm not sure how useful that is...), you need to know how much force is required to keep a constant speed. Newton's laws tell you the net force is zero, but that just means the forces sum to zero. So, what are the forces propelling and opposing a bike's motion? How do they vary?
For a simple estimate, you might start by estimating the power input from pedaling and use the definition of work to calculate the force applied to the ground.
Ps: you'll need to pay better attention to units because the calculation you did doesn't work.
Pps: what happens to the force when you hit a bump...?
Related to How do I calculate forces acting on bicycle axle?
1. How do I calculate the weight of a bicycle?
The weight of a bicycle can be calculated by adding the weight of each individual component, such as the frame, wheels, and accessories, together. The weight of the rider and any cargo should also be included in the calculation.
2. How do I determine the force of pedaling on a bicycle?
The force of pedaling on a bicycle can be calculated by using the equation: force = mass x acceleration. The mass is the weight of the rider and the bicycle, and the acceleration is the rate at which the rider is pedaling.
3. How do I calculate the force of friction on a bicycle?
The force of friction on a bicycle can be calculated by multiplying the coefficient of friction (determined by the type of surface the bicycle is on) by the weight of the bicycle and rider. This will give you the force of friction acting against the forward motion of the bicycle.
4. How do I find the net force on a bicycle?
The net force on a bicycle is the sum of all the forces acting on the bicycle. This can be calculated by adding together the forces of gravity, pedaling, and friction, as well as any other forces that may be acting on the bicycle.
5. How do I calculate the torque on a bicycle axle?
The torque on a bicycle axle can be calculated by multiplying the force acting on the pedal by the length of the pedal arm (distance from the pedal to the center of the axle). This will give you the amount of rotational force being applied to the axle.
  • Mechanical Engineering
