How does the atmosphere affect human weight on Earth?
In summary: At a depth of 100 meters, the pressure is equivalent to that at the Earth's surface. So the atmosphere would need to be about 1,000 meters thick to have any significant pressure on us.
blarznik
Does Earth's thick layer of atmosphere push down on us, increasing our weights drastically?
It decreases our weight, very slightly.
So humans are slightly buoyant? If I weighed 150 pounds would it be relieving less than a pound?
Also how thick would our atmosphere have to be to have it exert pressure on us? For instance like how at certain depths water pressure starts to overcome buoyant forces on an object.
Exactly.
Let's assume you have a density of 1 g/cc. Some people float, some sink, so 1 g/cc is about right. Air at sea level has a density of about 1.2 kg/m3, so that means you displace about 2.9 ounces of air.
It it true that in different parts of the Earth the weight of a particular human is different?
That depends on what you mean by "weight" and what kind of scale you use to measure it.
The scale you step on in a doctor's office uses gravity to balance two objects. These scales measure mass. Whether that doctor's scale is used at the north pole, the equator, or some hypothetical station on the Moon, it will register more or less the same "weight". Here, weight is being used in the legal (in the US) and colloquial (almost everywhere) sense: Weight is a synonym for mass, and has units of mass.
The scale you step on in your bathroom measures the force needed to offset the force due to gravity on a rotating Earth. Take that scale to the north pole, the equator, or that hypothetical station on the Moon, it will register different values for your "weight". Here, weight is being used in the sense of what some call scale weight. This weight is a force and properly has units of force. Your bathroom scale displays this force in units of mass assuming that gravitational acceleration is 9.80665 meters/second/second.
The Earth is rotating, so this adds a centrifugal force component (directed outward, so subtractive) to the force measured by a bathroom scale; this varies from zero at the poles to a maximum at the equator. The rotation also makes the Earth have an equatorial bulge, so someone on the equator is further from the center of the Earth than is someone at the north pole. Both effects reduce scale weight slightly at the equator compared to at the poles. For our 150 pound (mass) person, the effect is to reduce the scale weight by about 12.7 ounces-force.
Thank you D H, now it is clear.
"or some hypothetical station on the Moon, it will register more or less the same "weight".
If it is a classic 'balance' with counter-weights, sure, it measures mass minus relative densities' buoyancy correction. But, if it is a spring or force-feedback device then the weight displayed will vary according to local gravity.
D'uh, we had to fully re-calibrate laboratory balances if we moved them to a taller bench, never mind down to the production area...
It is always exerting pressure on us, we are simply adapted to living in this atmosphere.
Related to How does the atmosphere affect human weight on Earth?
1. How does the Earth's atmosphere affect human weight?
The Earth's atmosphere plays a role in human weight by exerting pressure on the body. This pressure is known as atmospheric pressure or air pressure, and it increases as you move closer to the Earth's surface. This increase in pressure can cause a slight increase in a person's weight, usually by less than a pound.
2. Does the atmospheric pressure vary in different locations on Earth?
Yes, the atmospheric pressure can vary in different locations on Earth. This variation is due to factors such as altitude, temperature, and weather conditions. For example, at higher altitudes, the atmospheric pressure is lower, which can cause a decrease in human weight. Conversely, at lower altitudes, the atmospheric pressure is higher, resulting in a slight increase in weight.
3. How does the composition of the atmosphere affect human weight?
The composition of the Earth's atmosphere consists of various gases, including nitrogen, oxygen, and carbon dioxide. These gases have different densities, which can affect human weight. For instance, nitrogen and oxygen are less dense than carbon dioxide, so they contribute less to the atmospheric pressure. Therefore, a person may weigh slightly less in an area with a higher concentration of nitrogen and oxygen.
4. Can changes in atmospheric pressure affect a person's weight?
Yes, changes in atmospheric pressure can affect a person's weight. For example, when the atmospheric pressure decreases, such as during a thunderstorm, a person may feel as if their weight has slightly decreased. This is because the air pressure is lower, causing the body to expand slightly, resulting in a decrease in weight. However, these changes in weight are usually temporary and do not have a significant impact on overall body weight.
5. Are there any health implications of changes in atmospheric pressure on human weight?
There are no significant health implications of changes in atmospheric pressure on human weight. As previously mentioned, changes in weight due to changes in atmospheric pressure are typically minor and temporary. However, high altitude and low atmospheric pressure can cause altitude sickness, which can lead to symptoms such as headaches, dizziness, and nausea. It is essential to acclimate slowly to changes in altitude to avoid these potential health implications.
  • Earth Sciences
  • Earth Sciences
  • Earth Sciences
  • Astronomy and Astrophysics
  • Earth Sciences
16K
