How to calculate the uncertainity errors
  • B
  • Thread starter hariprasath
  • Tags
    Errors
In summary: The distribution of poissons can give an estimate of the errors associated with a measurement, but it is not always accurate.
hariprasath
25
do anyone explain me pl. i would like to know the uncertainty error in measuring the specific activity of the primordial radionuclides
Hi there.
I would like to ask you about your grasp of computing uncertainties in general. Are these experimental data points that you are using?
It is impossible to answer anything specific with a question as vague as that.
we have meausred the primordial radionuclides in the sediments using NaI gamma ray detector. we measured the counts of the radionucldies and the activity of the radionuclides such as U, Th and K. we would be adding some uncertainity errors along with the specific activity with + and - sign. i would like to know the uncertainity formula in calculating it.
The uncertainty of the measured activity of a radionuclide is a combination of many uncertainties. As you a probably aware there is an intrinsic uncertainty associated with determining the activity of a radionuclide which is related to the number of events recorded in a given time ( i.e. the uncertainty in N counts is N½. However this is just the lower limit of the total uncertainty of the measurement if you have perfect knowledge of all the factors that affect the measurement. The other uncertainties are related to the imprecision of your knowledge of the experimental parameters of your equipment for which you must correct and each will have an associated uncertainty.
All radiation that passes through your detector may not be recorded as an event so you have an efficiency factor that needs determination.
You will only detect events that enter the detector i.e., only a certain fraction of the total disintegrations of the source will enter the detector. This is a geometric factor You will have superimposed on your data "false" events from other radiation sources for which you must correct. This is the background correction.
You will have events from your source that should not have been detected but were scattered back into your detector that needs to be assessed and corrected for if necessary.
Depending on the nature of the radiation you may need to correct for absorption of the radiation by the source itself.
For high count rates you may need depending on the detector to correct for a period of time in which the detector is not responsive to other events i.e. dead time correction.
Depending on the detector system there may be other corrections so one must totally understand the detector system.
Accurate activity measurements can be very challenging. All the correction will have uncertainties associated with them.
Thus the total uncertainty σ is related to the other uncertainties by σ2 = Number of counts + ∑σi2 where σi's are the uncertainties of all the detector correction factors.
You can simplify the measurement process a great deal if you have a standard calibrated source of the same radionuclide as you are studying. You may be able to combine the above uncertainties into one number equal to that of the standard source provided your source and the standard source are physically equivalent and the background conditions remain the same.
thank you, i had understood the concept behind it. i whole heartedly thank you as i would derive the equation with the uncertainity errors. including the activity, background counts and the time interval for each count.
further on as Th-232 has to be estimated from the soil/sediments. as it is not a gamma ray emitter, the daughter product of Tl-208 is considered. how safe is this approximation, since Tl-208 is of third branch of the decay series, do we need to multiply the amounts by 3. or the counts directly gives the acitivity of the Th-232.
further i have been working on environmental radiation, to estimate the amounts. as per the Bharathidasan Univesity , we need some reviwers who could evaluate the thesis and send back the report. i request to the persons who are willing to do me a a favour regarding this.
whether poissons's distribution give the exact value of the errors associated at same instant of time.
Th-232 → α + Ra-228 → β- +Ac-228 → β- + Th-228
Ac-228 has a reasonable gamma to measure
No. For a decays series in which the parent has a very long half life or small decay constant (λ) the the activity of the parent is related to that of any daughter (n) by the relation
Aparent⋅λparent = Adaughter n⋅λdaughter n
See any modern physics text.
The Poisson distribution give the uncertainty (standard deviation) for the measured number of events (n) recorded as n½. The error in the event rate (r) is given by
σ(r) = (r/t)½ = n½/t
where t is the counting time
Remember that the activity = r⋅correction factors
thank you
Related to How to calculate the uncertainity errors
1. What is uncertainty error and why is it important in scientific calculations?
Uncertainty error refers to the potential variation or inaccuracy in a measurement or calculation. It is important in scientific calculations because it allows us to understand the limitations of our data and results, and helps us make informed decisions about the reliability of our findings.
2. How is uncertainty error different from random error?
Uncertainty error is a measure of the potential variation or inaccuracy in a measurement or calculation, while random error refers to the unpredictable and random fluctuations in a measurement or experiment. Uncertainty error accounts for all possible sources of error, including random error, and is a more comprehensive measure of uncertainty.
3. What are the sources of uncertainty error and how do they impact the calculation?
Sources of uncertainty error can include instrument limitations, human error, and natural variation in the data. These sources can impact the calculation by introducing potential inaccuracies or variations, which can affect the overall result and its reliability.
4. How do you calculate uncertainty error in a scientific measurement or calculation?
The most common method for calculating uncertainty error is through propagation of errors, which involves identifying the sources of error and calculating their individual contributions to the overall uncertainty. This is done by using mathematical formulas and applying them to the data to determine the range of potential values.
5. How can uncertainty error be minimized in scientific calculations?
To minimize uncertainty error, it is important to identify and control all possible sources of error. This can be achieved by using precise and accurate instruments, following standardized procedures, and repeating measurements multiple times to reduce random error. It is also important to properly document all sources of error and their potential impact on the calculation.
