Hypothesis test on transformed data
In summary, to find the mean of lnA, you can use the formula E[lnA] = Integral (over the domain of lnA) ln(x) pdf(x) dx for a continuous distribution, or a summation for a discrete distribution. If the distribution of lnA is normal, you can check its domain to be A >= 0 and use the transformation rules to get the pdf of A.
A_B
93
Say I have a sample A with mean μ, and the log transformation of A, lnA. Is there any way of figuring out the mean of lnA? what if the distribution of lnA is normal?
thanks
Alex
Mathematics news on Phys.org
thanks
Alex
Hello A_B and welcome to the forums.
In this problem you just use the definition of E[h(X)] where h is a function and X is your random variable.
Basically you just have to use the formula that E[h(X)] = Integral (over some domain) h(x) pdf(x) dx for a continuous variable.
The key thing though is because you are using a log function, you need to adjust your domain to suit that. If for example your distribution A was normal, then you couldn't apply your transform over the whole of A (since the domain of a normal is the whole real line). So just be careful when you're defining the range so that ln(x) is valid for this domain.
If your distribution is discrete then instead of an integral, replace that with a summation. If you're confused about what I'm saying grab any introduction statistics book and look at the definition of expectation.
Also if ln(A) was normally distributed then A >= 0 for its domain, so that's something easy to check. One way to get the pdf of A if ln(A) was normal is to use transformation rules with PDF's. Since ln(A) has an inverse transformation (e^(x)), you should be able to use the transformation to get firstly a CDF and then a PDF (differentiating).
Related to Hypothesis test on transformed data
What is a hypothesis test on transformed data?
A hypothesis test on transformed data is a statistical test that is used to determine whether there is a significant difference between the means of two or more groups. This test takes into account the transformation of the data, which is often done to meet the assumptions of the test and improve the accuracy of the results.
Why is it necessary to transform data before performing a hypothesis test?
Data transformation is necessary before performing a hypothesis test because it helps to meet the assumptions of the test, such as normality and equal variances. These assumptions are important for the accuracy and validity of the results, and transforming the data can help to achieve them.
What are some common methods of data transformation used in hypothesis testing?
Some common methods of data transformation include logarithmic, square root, and inverse transformations. These methods can be used to make the data more normally distributed, which is often a requirement for many hypothesis tests.
How does data transformation affect the interpretation of the results?
Data transformation can affect the interpretation of the results by changing the scale and distribution of the data. This means that the conclusions drawn from the results may differ from those without data transformation, and it is important to take this into account when interpreting the results.
Are there any drawbacks to using data transformation in hypothesis testing?
Yes, there are some drawbacks to using data transformation in hypothesis testing. These include the potential for losing information and the risk of introducing bias into the results. It is important to carefully consider the appropriateness of data transformation for a specific test and to use it cautiously.
  • General Math
  • General Math
